| This is a discussion on Tires. Tires, Tires! within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi group, I wrote week before last regarding a 15,000 mile lifetime of 34-38 mpg milage on my Blue package ... |
Friends: 0 | Hi group, I wrote week before last regarding a 15,000 mile lifetime of 34-38 mpg milage on my Blue package #9 2005, and the relative ineffectiveness of dealer advice and the driving skills I had accumulated over 40 years of driving. The common thread of the many (thanks!) responses, centered on tire pressure. As I reported, I checked my Pirellis (17 inch) and found them to be inflated to a whopping 25 psi all the way around. I set them all at 40 and promised to report the effects of the higher pressure on fuel economy after our recent road trip from Orlando to Ocean Isle Beach (NC) and back. We're back, and here are the astounding results. Milage on the way up at 65 mph in cruise control with AC on auto at 74 degrees was (no s**t)! 48 and a fraction mpg!!!!! I know this is a 28% increase in fuel efficiency, which stunned me. The other data point that I found interesting was that the calculated milage and the onboard cumulative computer result were virtually identical. This is another piece of dealer misinformation, as I was assured when I first complained, that I "couldn't go by that." lastly, the ride was not noticeably stiffer than before. On the way back, I drove at my normal turnpike speed of 73-74 mph, (still in cruise and auto ac) and got 43 plus. After a refuel I drove the rest of the way right at the speed limit and hit my driveway at 45 mpg even. I would have flatly refused to believe tire pressure could make such a difference if I hadn't proven it to myself over 2 and 1/3 tanks of gas with me doing all the driving under controlled conditions. The question now is why the dealer let a car leave their lot with tires so woefully underinflated. (And by the way, on these 17 inch low profiles it's almost impossible to tell by visual inspection if the tire is underinflated!) I suspect it is to give the customer a smoother ride, but what a price to pay! I will have a serious heart to heart with my service manager tomorrow, rest assured. Again, thanks to all, since it's this forum where I found the answer, not my dipshit dealer! Mike |
| Senior Member Join Date: May 2006
Friends: 0 | Were the wheels and tires a dealer installed option. If so it seems they would have told you not to expect as good of results as with the stock 15" set up. That being said, I think your trip results were great concidering 17" wheels, what brand/type are they ? I just made a similar trip at similar speeds and got 47.4 mpg. with stock tires set at 42/40 lbs. |
Friends: 0 | <div class='quotetop'>QUOTE(B Rad @ Jul 29 2006, 07:03 PM) [snapback]294399[/snapback]</div> Quote:
Yes, as usual, we took the car the way they shipped it. I certainly didn't want the 17 " $1200 wheels, lol! There was no discussion as to better or worse milage with the 17s (Pirelli tires, a much better tire than stock) What frosts me is that they apparently also failed to ,measure tire pressure and make sure the car was ready for delivery, as the tires should have been at 36 and 38 or thereabouts, and were as I said in reality at 25, which is sorta like trying to run in sand. The other problem is they don't really look much different at 40 than at 25, since they're low prpofile tires anyway. I'm seriously considering trading at my tire dealer who also sells wheels for a sporty set of 15s to replace the 17s and then using the stock 185s. Do you find that yt onboard cumulative computer mpg is accurate compared to the miles/gals calculator method? Mine is almost dead on. Mike | |
Friends: 0 | <div class='quotetop'>QUOTE(bubblehead1026 @ Jul 29 2006, 09:04 PM) [snapback]294445[/snapback]</div> Quote:
__________________ B Rad Silver Pkg#3 Arrived 6/21/06 metalic tint,mud flaps,side molding, clear bra,Wet Okoli. 17" Centerline Wheels + 205/45-17 Falcon tires | |
Friends: 0 | <div class='quotetop'>QUOTE(B Rad @ Jul 30 2006, 04:13 PM) [snapback]294718[/snapback]</div> Quote:
| Senior Member Join Date: Jan 2006 Location: Lexington, MA
Friends: 0 | Thank you for the powerful illustration of the importance of not underinflating tires. For better or worse, I don't trust dealerships too much. I've taken delivery of new cars with tires inflated above the maximum sidewall denoted pressures, despite their handwritten recommended pressures on their pre-delivery inspection list. Over 15,000 miles, you could have easily lost some tire pressure. You'll probably want to check your tire pressure yourself monthly, using your own pressure gauge now. In the southern states, 17 wheels and other high markup options are installed at the port. These options are often specific to the South. Before moving back to 15" or 16" wheels, read reviews by others here who observed very modest increases in fuel consumption moving from the lightweight OEM 15" wheels to 17" wheels. I agree that you might easily find someone near you who is happy to trade their 15" wheels and tires for your 17" wheels and tires. Pirelli tires are often less fuel efficient that other tires of the same size and performance level. When it's time to replace them you might find this post or this rolling resistance data helpful in finding more fuel efficient tires in whatever size. |
Friends: 0 | Just picked up my Prius on Friday. Drove around 110 miles and finally got to check my tire pressure today. 25 psi all around!!!! These are the stock 15 inch rims and tires. Can this be the way the cars are shipped and then the dealer does not even check the tire pressure? Pumped'em up to 40/38 psi. Still on the first tank of gas, but even with the 25psi the computer mpg was low 40's. Hopefully this will help the mpg go higher. By the way, I love my new Prius!! |
| Tires | pejohn | Newbie Forum | 5 | 12-19-2006 07:55 AM |
| Rotating Tires/ can't get rear tires off | filiberti | Gen II Prius Main Forum | 18 | 08-31-2006 02:59 PM |
| OEM Tires | heliotropehead | Gen II Prius Care, Maintenance and Troubleshooting | 6 | 02-22-2006 09:26 PM |
| tires | MarinJohn | Gen II Prius Care, Maintenance and Troubleshooting | 3 | 10-11-2005 04:08 PM |
| Stock tires ok tires? | Bob Allen | Gen II Prius Modifications | 5 | 04-30-2004 01:50 PM |
