| This is a discussion on I'm not a hypermiler, but.... within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(Winston @ Aug 17 2007, 02:21 PM) [snapback]497935[/snapback]</div> I am getting ready for a trip down to LA and ... |
| | #11 | |
Friends: 6 | <div class='quotetop'>QUOTE(Winston @ Aug 17 2007, 02:21 PM) [snapback]497935[/snapback]</div> Quote:
| | #12 |
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Hi, I have great respect for Wayne's work and feel you won't go wrong with his simulator. I would recommend his latest version. My approach to the same problem has been based upon a series of benchmarks either I've done or others have done. Then about a year ago, Ken@Japan pointed to a Toyota reported drag formula. This graph shows my best understanding of NHW11, 2001-03 Prius performance with some NHW20 data points: ![]() This has already resulted in a 'thermistor hack' that solves a great deal of the cold weather driving problem. Other folks have gotten similar if somewhat limited results using block heaters. My current efforts are aimed at understanding ICE efficiency and mapping that back to the variable loads found in driving: ![]() This effort is aimed at mapping high speed performance to map out the knee in the curve. With my vehicle, 65 mph is the highest 'sweet spot' that hits the knee at 70 mph. Speeds above 70 mph are the pits in an unmodified vehicle. My plan is to look at this speed range, 65-75 mph, and see what various modifications might achieve. These range from drag reduction to power plant modifications. As I get results, I will be sharing but for now, understand that this is one of two 'bleeding edge' areas of investigation. Bob Wilson |
| | #13 | |
| Senior Member Join Date: Jun 2007 Location: Toronto, Canada
Friends: 0 | <div class='quotetop'>QUOTE(Winston @ Aug 15 2007, 06:20 PM) [snapback]496436[/snapback]</div> Quote:
| | #14 | |
Friends: 1 | <div class='quotetop'>QUOTE(ken1784 @ Aug 17 2007, 12:42 PM) [snapback]497886[/snapback]</div> Quote:
| | #15 | |
Friends: 0 | <div class='quotetop'>QUOTE(Bill Merchant @ Aug 17 2007, 12:35 AM) [snapback]497680[/snapback]</div> Quote:
LOL!!!!!!! | |
| | #16 |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Model: Package: #5 Thanks: 1
Friends: 25 | Congratulations Winston !!!! 50 is great !! Looking at your info, looks like your car is an '07, so I don't know how many miles you have on it, if its broken in yet or not (usually around 5000 miles), or your experience level driving the car. Regardless, over time you car will break in, and your driving patters will improve and mileage will increase. Just think about all your previous vehicles, and realize how really great 50 is !! If you really want to increase your mileage, search the forums for "pulse and glide" and learn the techniques, especially at 40-41 mpg and under, and your mileage will skyrocket !!
__________________ ******************************* Rangerdavid Boone, North Carolina 2006 Silver Pine Mica, Package #5 All weather mats, mud flaps, PC front window heat shield ScanGauge II BT Stiffening Plate Engine Block Heater (installed by FireEngineer) Rear Bumper Protector Wheelskins Two-Tone Leather Steering Wheel Cover Belkin cup holder unit for PDA/mp3 Player Winter front grill wind blocker ![]() |
| | #17 | |
Friends: 6 | <div class='quotetop'>QUOTE(ScottY @ Aug 17 2007, 05:37 PM) [snapback]498039[/snapback]</div> Quote:
| | #18 | |
| P719 of ??? Join Date: Nov 2006 Location: South Jersey
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 0
Friends: 2 | <div class='quotetop'>QUOTE(Winston @ Aug 15 2007, 06:08 PM) [snapback]496429[/snapback]</div> Quote:
In a rally the conditions are the same so the game is between the two drivers. | |
| | #19 |
Friends: 0 | I find that time I avoid the freeway and take the surface streets. With the freeway going 70 and the surface streets at 45, it only takes a few more minutes on a typical drive, yet I get much better MPG. |
| Sat, Dec. 8th, Houston Hybrid and Hypermiler's Club | Dan. | Local Clubs, Events, and Road Trips | 1 | 12-06-2007 11:44 AM |
| Sat, Oct. 13th, Houston Hybrid and Hypermiler's Club | Dan. | Local Clubs, Events, and Road Trips | 0 | 10-06-2007 11:45 AM |
| Sat, Sept. 8th, Houston Hybrid and Hypermiler's Club | Dan. | Local Clubs, Events, and Road Trips | 1 | 09-07-2007 12:38 PM |
| Not a hypermiler yet, but gosh darn happy with the MPG | JeffHart | Gen II Prius Fuel Economy | 4 | 08-12-2005 09:09 PM |
