| This is a discussion on Tire replacement dilemma. within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by FishHawk Well, I 'm not sure what replacement tires I'll get after the OEM's wear out but ... |
#11 | |
| Member Join Date: Jan 2008 Location: Misty mountains of Oregon
If you figure most tires are somewhere in the middle of the sticky high perf. and the low resist. tires, then the difference is even more minimal. And then compare the prices of the ultra low vs. the standard All-season, whatever you save in gas may be eaten up by extra cost. At any rate, some interesting info: http://www.tirerack.com/tires-techpage-1/29.shtml | |
| | #12 | |
| Member Join Date: Jul 2006 Location: Rural area called Powdersville, 10 miles out of Greenville, SC
My Car: 2006 Prius Model: Package: #9 Thanks: 0
I have ordered Michelin PRIMACY MSV4'S,like you I read all the info and found I could not get better. Paid $106 installed and balanced at Piedmont Tire, Piedmont SC and will get them some time next week. Let me know what you thiink when yours arrive. After approx 1000 miles I can say I do have at least a 2 mpg loss in mileage. I agree the car drives better and less tire noise. I have increased air pressure to 42/40 but still the 2 mpg loss. Last edited by A. B. Hair; 02-02-2008 at 09:29 AM. Reason: Michelin Primacy after 1000 miles | |
| | #13 |
My Car: 2007 Prius Model: Package: #2 Thanks: 163
Friends: 22 | I don't know why you think you will take a 5-10 mpg hit with better gripping (but higher rolling resistance) tires. A lot of us have gotten wider and better gripping tires and only experienced a 0-3 mpg hit. Personally, I like the Goodyear Assurance TripleTreds. I have them in the wider 195/60/15 size, and as far as I can tell, I'm only experiencing about a 1-2 mpg hit. Meanwhile, they grip like glue on dry and wet roads, and grip about as well as an all season tire is going to grip on snow and ice. Besides the Goodyear Assurance TripleTreds, there are lots of passenger all season tires available like the Goodyear Assurance ComforTreds you mentioned, the Michelin HydroEdge, the Michelin Harmony (called Destiny at Discount Tire), which perform much better and longer than the Integrity, and which should not result in much of a mpg hit. If you haven't done so already, I recommend checking out nyprius' excellent thread on the subject, entitled "Tire Upgrade: Lessons Learned". You should at minimum read nyprius' excellent initial post on the subject. Here's a link to the thread: http://priuschat.com/forums/prius-mo...e-upgrade.html Good luck.
__________________ Best regards, Tom 07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads. Last edited by Boo; 01-12-2008 at 07:56 PM. |
| | #14 |
| Junior Member Join Date: Jan 2008 Location: North Georgia
Friends: 0 | I am having a similar dilemma!! I would like some feedback from folks on whether I should upgrade to a larger size (195/60). I really need new tires and am looking at Good Year Assurance Triple Tread, Kumho Solus KR21 and Michelin Primacy MXV4. I have read most of the previous threads on the topic of tires and am still totally confused! ![]() Does anyone have experience with these brands at the larger size 195/60? Was gas mileage or road clearance compromised? I need something that is good in wet and dry. We get a little snow and ice ocassionally here in North Georgia. Thanks. gena |
| | #15 |
| Senior Member Join Date: Nov 2004 Location: Northern CA
Friends: 0 | I have 1k on my Michelin Primacy MXV4+, stock size, same 37 psi. About 70k total miles on my 2006 Compared to the Goodyear CT (lasted 68k ! Michelins "rumble" more below 55mph (I'm checking for a bent rim tonight). Michelins steering slowness is about the same. Michelins dart around more on grooved highways. Michelins are a MILLION times quieter, like about 15 dB using my PDA sound pressure software(very approximent). Gas mileage : maybe a 1-2 mpg hit, it's hard to tell with the weather going from 32 -62 F in a few days over the last 2 weeks. |
| | #16 |
| Member Join Date: Dec 2007 Location: central Indiana
My Car: 2008 Prius Model: Package: #4 Thanks: 0
Friends: 0 | I've been researching the tire issue the last couple of weeks also. My prius is brand new (2800 miles). I made the decision to ge ahead and invest in a top notch tire. I just stopped in at Discount tire today to order them. Michellin is offering a $60 rebate on a set of tires. They are also giving me $25/tire for my existing GY Integreties that came on the car, which is one reason I decided to purchase now, while my existing tires were worth something. My total investment will be under $400 for Michelin Destinies. Given the importance of the tires relative to safety and driving experience, I believe it is a no-brainer to invest in a decent tire. I went with the same size, 185/65. Maybe next set I'll try the 195/60, but I wanted to see how these do with mpg first. I can't wait to get them on. |
| | #17 |
| Senior Member Join Date: Dec 2007 Location: houston
Friends: 1 | Yet another reason to take mileage with a grain of salt. Different tire sizes produce different mpg readings despite using the same amount of gasoline. I believe the 195/60 gives a mpg reading closer to the actual. |
| | #18 |
| Junior Member Join Date: Apr 2006 Location: Phoenix, Arizona
Friends: 0 | Just took the plunge today after a week or so of casual shopping. Had just under 36K on originals. Didn't need replacement right away, but have an upcoming trip to LAX from PHX and back over a 3 day period and didn't want to push my luck. Evaluated the Goodyear Comfrot Treads because of positive things read here. Discount Tire had them, but felt that the Michelin Destiny was comprable, (in fact they told me the Goodyear product was a direct response to the Destiny tire) but better suited to our summer weather because of the silicon base. With the full Discount Tire lifelong replacement for road hazards and the regular Michelin warranty I was out the door for $524 total including all taxes and still have a $60 dollar rebate coming from Michelin. I thought it was a pretty good deal. Just got the 6/100K warranty through Troy so I'm betting this will be the last tire I need on this Prius. Will provide input on how I like them and what, if any effect on mileage. Anyone have ideas on optimal tire pressure? |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/41166-tire-replacement-dilemma.html | ||||
| TinyURL.com - shorten that long URL into a Tiny URL | This thread | Refback | 02-07-2008 05:08 PM | |
