This is a discussion on EV and Steath Mode within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hello All: I am new to this community as I just been an owner of a 2008 with package #2 ...
EV and Steath Mode
Old 04-10-2008, 03:37 PM   #1
dex20000
Wink EV and Steath Mode
Hello All:
I am new to this community as I just been an owner of a 2008 with package #2 for a week. So far noting that calculated MPG of 41.3 and 42.9 on the first two tanks. They were about 3 MPG less than the computer stated. I've read about the bladder, but is the accuracy really that good on the computer. I'm an engineer and quite impressed with the car. But, I have trouble believing that an instantaneous sensor as the Prius has is able to accurately measure MPG over a long period of time without having at least a 5% margin of error. From experience, precision sensors are extremely expensive. Any insight here? Is the computer really that accurate?
I've also see discussion on EV and Steath Mode. What are they, and do people have modifications to control these modes? Are they from Toyota?
dex20000 is offline
Old 04-10-2008, 03:58 PM   #2
Highly ImPriused
Impressive Member
Highly ImPriused's Avatar
Package: #1
Default Re: EV and Steath Mode
I have just over 19,000 miles on mine and my MFD is just about 3% higher than calulated mileage (miles driven/gallons pumped) for the life of the car. Most people find there's in a similar range, around 2 - 5% I think. So, it's not too shabby.
EV is electric vehicle mode and stealth mode basically refers to the same thing. You can engage EV on any Prius when under 42 MPH if it's fully warmed up. Basically, you just let up on the accelerator until you see arrows on the energy display only going from the wheels to the battery (regenerative breaking). Then you lightly apply pressure on the accelerator until there are only arrows going from the battery to the wheels (none from the engine).
There is an aftermarket mod where you can install a switch to force EV mode any time under around 35 MPH (I think). It's debatable whether you can save any gas doing this because whatever energy is used from the battery will be regenerated ultimately by the gas engine.
The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man. - George Bernard Shaw
Highly ImPriused is offline
Old 04-10-2008, 04:13 PM   #3
dex20000
Thanks for the good info Highly Impriused. I am glad to see some differential in MFD vs. Calc because some of these posts suggest that the calc figures are not very accurate.
I'll try your tips. For the past days, I find myself very distracted trying to recharge that battery while coasting and trying to hold the car in EV mode as long as possible. I am trying to be more aware of driving efficently. I think many of the tips help.
I am very happy with the purchase as are so many people here!
dex20000 is offline
Old 04-10-2008, 04:13 PM   #4
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Agreed with Highly. Fuel economy and usage are calculated by the car mainly by monitoring fuel injector duration and operating frequency. Those of us who have tracked the difference between MFD MPG and calculated MPG over several tanks have found differences in the 2-4% range, so you're right in the ballpark.
Welcome to PriusChat and Prius-dom!
JimboK is offline
Old 04-10-2008, 04:19 PM   #5
JimboK
JimboK's Avatar
Friends: 6
We must have hit "Submit" simultaneously.
It might seem counterintuitive, but to deliberately try to use the battery will cost you fuel economy. As Highly suggests, that energy must be replenished via the ICE, and with replenishment comes conversion losses. Better for normal driving is to use only ICE power for propulsion.
JimboK is offline
Old 04-10-2008, 05:11 PM   #6
Danny Hamilton
M0D3RAT0R
As you've probably figured out by now from the posts above, a calculated average mpg over many (10+) tanks of gasoline is likely to be more accurate than the MFD displayed average over the same number of tanks. On the other hand, the MFD is likely to be more accurate on any one tank or on an average over a few tanks.
This is largely because timing the fuel injectors gives a more accurate esimate of the amount of fuel used for one tank than trying to guess based on measuring the amount of fuel required to fill the bladder, whereas the largest likely error in figuring fuel used by measuring fuel added to the bladder is spread out having a decreasing affect on the calculation as the number of refills increases.
Danny Hamilton is offline
Old 04-10-2008, 05:19 PM   #7
dex20000
I can appreciate your comment about using the battery as counterintuitive. I've been thinking the same thing...there are too many losses involved: generator losses, battery losses, generator again, along with the drive losses. Leaving the car to do the thinking doesn't seem so bad.
When I first saw the regeneration symbols, I thought it showed 1 car = to 50 KWH...I was really super duper impressed, then realized that it is only 50 watts-hours...lol. Not a whole lot, but better than nothing! My guess is that the battery/generator/brakes contributes 15% to efficiency and that improved driving habit helps another 5-10%. I am willing to bet that if the Prius did away with the electrical system, the car can still get 35-40 MPG.
I am glad that the Prius has a CVT. I don't feel a transmission shift, but the engine (on/off) takes its place basically. I wonder what it is like on another hybrid that has a 4 or 5-speed trasmission...bet that it feels like a lot of shifting going on.
dex20000 is offline
Old 04-10-2008, 09:17 PM   #8
Highly ImPriused
Impressive Member
Package: #1
I wouldn't go that far. The ICE is only a 1.5L Atkinson cycle. It would be extremely sluggish and underpowered without the electric motors and its fuel economy would surely suffer substantially as a result. The beauty of the Prius is that it recaptures and uses a lot of the energy losses of a conventional ICE-powered vehicle. It's great that the Prius re-uses that energy when possible, but just don't go to extremes and draw the battery down excessively to try to get better MPG.
I think the best advice is to just let it do its thing for a while until you get used to it and can easily transition in and out of EV mode. Then you can decide if you want to start incorporating more advanced techniques, like pulse-and-glide.
Old 04-10-2008, 09:42 PM   #9
miscrms
Plug Envious Member
Just a clarification:
While EV mode and Stealth mode are similar, they are distinctly different modes. EV mode can only be activated with a switch, which is missing on US spec vehicles. They can however be modified to add one, as the software is all still there. Stealth mode is also an electric only mode, but one that the car will naturally select under certain conditions. The EV mode has a hard limit of 34 mph, and is tolerant of harder acceleration and lower battery levels before the ICE will start. Stealth mode can be run to higher speeds, but unless the battery is very high you have to be very light on the accelerator to stay in stealth mode. The typical way to "select" stealth mode is to let all the way up on the accelerator then depress slightly. You should see just regen, then no arrows at all (glide mode) then electric only drive (stealth).
As mentioned before, using these modes in general will not help your MPGs, and will sometimes hurt. They are fun to play with though. There are a few situations when they can be handy. If you are gliding up to red light and need a little more boost to make it but don't want to start the ICE for example. I'll also use stealth on a long gentle down hill if I have a green battery after a long uphill. Feels like you can just coast forever! The real EV mode is really not good for much. Its handy if you want to move the car without starting the ICE. I believe the Toyota docs actually refer to this as ICE warmup delay mode, and thats pretty much all its for, moving the car around a parking lot or the like. About the only time I would actually use it is if you're coming home with a full battery, and know that you will get a good charge up in the morning due to a hill or the warmup cycle in cold weather. Of course its also good for sneaking up on people, as has been noted here:
Rob
miscrms is offline
Old 04-10-2008, 10:08 PM   #10
hobbit
hobbit's Avatar
MFD and MPG accuracy are discussed a little bit in the New Car
Features documents, which are available here. As an engineering
type you'll probably sit there for the next two weeks devouring
this stuff, because it's definitely a good read.
_H*
hobbit is offline
EV mode @ 40 MPH AndreJ Gen II Prius Main Forum 17 06-06-2007 10:19 PM
EV Mode Kit PrincetonPrius Gen II Prius Technical Discussion 2 05-14-2007 11:14 AM
What's the best way to use EV mode Sailfish11 Gen II Prius Modifications 1 01-24-2006 03:25 PM
Let's re-name the EV mode. Prius Maximus Gen II Prius Main Forum 12 12-21-2004 07:52 PM
Ev mode mod SyZyGy Fred's House of Pancakes 1 10-18-2004 11:11 PM
