| This is a discussion on How much would a scanguage help me? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My commute: 80% highway, 20% <45 mph On the highway if I go at the speed limit it's practically suicidal. ... |
| Member Join Date: Mar 2008 Location: Washington State
My Car: 2004 Prius Model: Package: N/A Thanks: 0
Friends: 0 | My commute: 80% highway, 20% <45 mph On the highway if I go at the speed limit it's practically suicidal. I'm wondering what scanguage can do for me? If I go 70/60 in the appropriate mph zones. Right now I'm hovering between 47 and 51 mph depending on the outdoor temperature. I know everyone says to go slower. I once got 75mpg on a trip so I know it can be done (taking back roads and such). But I have an hour commute and I don't want to prolong it any more than I have to. (Ie I am unwilling to spend much more time on my commute than I have to). I would assume SG would help with acceleration and such. I guess I don't fully understand why it's go great. |
Friends: 35 | Quote:
Does any of this matter? Not really but I like knowing the "how and why" of things like this. My conclusions may be incorrect but that is part of the fun with the SGII. I get to learn more about how my car actually works.
__________________ 2005 Prius - Upgrades: Kenwood eXcelon KDC-X993, Diamond Audio D9800.2 and D61500.1 (1900w RMS), Diamond Audio D971 7" component set, 2 Diamond Audio D910D4 10" subwoofers (600w/ea). ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. | |
| Senior Member Join Date: Mar 2007 Location: Albuquerque, NM
Friends: 1 | Two of the best SG readouts are rpm and SOC. RPM tells you if the ICE is running or not, sometimes you can't tell and the MFD says its not even if it is; it also tells you if your rpms are higher than you like for better mpg. State Of Charge gives you much more accurate info than the bars on the MFD, you can learn how the rate of increase of charge relates to different stopping/slowing rates. For highway, this info might not be as valuable as stop-and-go. Unless your highway is stop-and-go. I also display 12v battery voltage and ice coolant temperature. |
| Member Join Date: Feb 2008 Location: Macomb, MI
Friends: 1 | Hi After Hybridfest, I think I will want one. (Everyone else has one--some people have 2!) The most important thing to me would be watching the RPMs for peak acceleration. It would also be helpful for info when you have the nav system on, so you don't have to go back and forth in the MFD. Actually, I may be getting a "trial" time; my son will be testing the kiwi (it's a more graphical-user friendly device from juicedhybrid.com) and he's going to loan me his scangauge. My 2 cents. Donna |
| C'Mere Sheepie! Join Date: Mar 2008 Location: Sanford FLorida
Friends: 6 | The kiwi is colorful but appears to be minimal info. The Scan Gauge is much more about info than colorful smiley faces. To each his own I guess... |
| D-Man Join Date: May 2007 Location: Cleveland
Friends: 0 | Another useful gauge on the ScanGuage II is water temp, so you know what stage of warm up you're in. On the highway, the most important gauge I monitor is TPS (throttle position). I use it to make sure I'm giving it only enough throttle to maintain speed or slowly lose speed on a flat or an incline. I've found that TPS of 21 starts giving you 70 MPG or better, and I try never to go above that unless I'm going up a steep incline and I don't want to lose TOO much speed. I drive from Cleveland to Cincinnati every other weekend, and I've been averaging 66 MPG on the all-highway trip!
__________________ 2007 Prius, package 6, driftwood pearl EV mode ScanGauge II Upper grill blocked, lower grill 3/5 blocked Tires 42/40 Mudflaps All weather mats Front seat covers Disabled backup and seatbelt beeps Removed cheesy Toyota hubcap rims |
| A young senior member Join Date: Mar 2006 Location: Chicagoland, IL USA, Earth
My Car: 2006 Prius Model: Package: #1 Thanks: 12
Friends: 3 | Quote:
It helps some people get the high mpgs, but they're also willing to change their commute (have you thought about a different job or a different house so you don't have to go so far?). OTOH, TonyPSchaefer achieves >60mpg all summer without a ScanGauge. I have one, mostly to get more information from my wife's Accord (ancient technology in that car doesn't allow for real-time mpg feedback!). But after reading up on it, I'll be using it in the Prius for my upcoming roadtrip. In a week, I should have some data as to if it helps or not. Some swear by keeping the IGN timing value at 14 (degrees off TDC) as much as possible, that's not possible to see without something like the SGII, but I'm thinking just keeping a light foot on the accelerator would do much the same.
__________________ "We must be the change we seek" - Gandhi | |
| Junior Member Join Date: Sep 2006 Location: Florida
My Car: 2005 Prius Model: Package: Thanks: 0
Friends: 0 | Hi Kinare, For me, ScanGauge was worth about 15% improvement overall and my tanks are typically 70% highway, 30% rural/city. I bought one about two years ago and my tank mileage immediately improved from a consistent 60-62 to the high 60's. I pushed several tanks to 72 mpg before ethanol fuel blend and a tire change. Scangauge allowed me compare different driving techniques, routes, and the effects of wind/rain and road surface. Very small gas pedal changes create very large IMPG changes and Scangauge gives you instant feedback on how your decisions affect mileage. Based on feedback from SG I now drive a shorter but lower speed route to work to reduce my highway miles. I found out very quickly how rapidly the mileage drops off at higher speeds so now I rely on my city miles to boost tank average. For comparison I've turned the MFD display off, covered the SG then drove bonzai style to work like everyone else. Commute took 1:15 instead of 1:24 and I used 1.7 gallons instead of 1.0 gallon. I saved 9 minutes, used 70 percent more fuel and exposed myself to a potentially expensive meeting with the cops for miles on end. My moving average was higher but I also spent significantly more time sitting at stop lights versus timing them from the back of the pack and rolling through. I use RPM,IGN,MPG and FWT. Once coolant temp reaches 157F I switch to LOD. Based on fuel savings I figure the gauge paid for itself after 15k miles. See ya, Brian |
| Senior Member Join Date: May 2008 Location: Marietta, Ga
Friends: 1 | Hi Kinare; It looks likes you have already received a number of good replies. I'll just add that we are already saving about 10% on our gas costs thanks to the information revealed by using the ScangaugeII and we don't even have our Prius yet. We've improved the mpg on our 2000 Avalon by ~2 mpg. |
| fuel economy, scanguage |
| Scanguage questions | Danny Hamilton | Gen II Prius Technical Discussion | 29 | 09-19-2008 07:27 PM |
| ScanGuage | Cacti | Gen II Prius Main Forum | 1 | 10-18-2007 11:54 AM |
| Scanguage II upgrade | PA Prius | Gen II Prius Main Forum | 5 | 10-04-2007 04:06 PM |
| scanguage II | desertbriez | Gen II Prius Modifications | 6 | 06-15-2007 01:10 PM |
| Do you recommend the Scanguage? | windstrings | Gen II Prius Modifications | 18 | 11-27-2005 02:22 AM |
