This is a discussion on 2008 and 2004 different mpg! within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; hi, i just purchased a 2008 prius and have a 2004 with 97,000 miles. the new one has nitrogen tires ...
Old 08-10-2008, 03:43 PM   #1
indpocket
Smile 2008 and 2004 different mpg!
hi,
the new one has nitrogen tires and is getting around 45 mpg--although
on a trip to colo. and nm it got about 48mpg. the 2004 has just had its
95,000 mi service and is getting 38 -40 mpg. my question is ,why the
difference? i notice in the forum tires,oil and ethanol are popping up in explaning lower mpg. is there any hard data on any of these factors? any indication that age per-se has an effect ? note it IS 100-110 degrees daily
where i live!
thanks.
indpocket is offline
Old 08-11-2008, 07:38 PM   #2
a64pilot
Default Re: 2008 and 2004 different mpg!
I can tell you that filling the tires with nitrogen is silly at best. Worse if you paid for it. There is no advantage to filling your tires with N2.
a64pilot is offline
Old 08-11-2008, 07:46 PM   #3
mshore6k
mshore6k's Avatar
actully there is an advantage to filling tires with nitrogen. Less times to the air station to fill up.
mshore6k is offline
Old 08-11-2008, 07:52 PM   #4
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 36
Maybe your 2004 has a bad auxilary battery?
F8L is offline
Old 08-12-2008, 08:33 AM   #5
jdenenberg
jdenenberg's Avatar
Are both used for the same driving conditions? Short trips lower your MPG significantly.
JeffD
jdenenberg is offline
Old 08-12-2008, 12:40 PM   #6
brick
brick's Avatar
This is a very good suggestion. I know for sure that Honda hybrids will suffer when the 12V battery gets weak because more energy is wasted charging it. While I haven't read much about it here, I can't think of a good reason why the same shouldn't apply to Toyota.
brick is offline
Old 08-12-2008, 01:50 PM   #7
ctbering
Rambling Man
ctbering's Avatar
Friends: 19
My Prius came with tires filled with nitrogen at an nominal cost, of course. The purpose of the nitrogen versus air is to reduce the deflation that commonly occurs in weather fluctuations, specifically warm to cold. I wasn't told there would be an increase or decrease in MPG's. I was told the nitrogen molecule is larger and does not escape somehow like the air molecule from the tire. It sounded like it was good advice at the time of the buy.
ctbering is offline
Old 08-12-2008, 01:54 PM   #8
mingoglia
I know the local Jeep dealership in tow offers lifetime Nitrogen for $39 I believe. Pay once and you can bring your vehicle back to have your tires adjusted for free. It's a bit on the expensive side, but convenient for many people that want to check their air pressure a bit less frequently.
mingoglia is online now
Old 08-14-2008, 12:08 PM   #9
richard schumacher
Destination: Eschaton
richard schumacher's Avatar
What are the tire pressures?
richard schumacher is offline
2004, 2008, mpg!
For Sale Bisque Toyota OEM Floor mats 2004-2008 echase Private Sales 3 02-04-2009 09:38 PM
generation 3 technology in 2004-2008 Prius ctbering Gen II Prius Technical Discussion 8 07-05-2008 11:44 AM
FW: 2004-2008 grey carpet cargo mat exbauer Private Sales 0 05-01-2008 04:52 PM
FS: 2004-2008 rear grey cargo cover exbauer Private Sales 0 05-01-2008 04:36 PM
For Sale: 2004-2008 Prius NAV/MFD SunShade Raider Private Sales 0 11-21-2007 05:22 PM
