This is a discussion on Pulse / Glide within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Life without a Scangauge, how bleak it would be. The Scangauge helps train you, is quite entertaining, and pays for ...
Pulse / Glide
LinkBack (5) Thread Tools
Old 08-16-2008, 05:37 PM   #21
jps000
No Exit
jps000's Avatar
Default Re: Pulse & Glide help?
Life without a Scangauge, how bleak it would be. The Scangauge helps train you, is quite entertaining, and pays for itself over time (NO doubt). That said, drive 50 - 60 mph and hit Cruise Control. When hilly and no cars behind, turn off cruise control and let car slow down.
If you don't want cruise control, I would drive to 55-60 and then on the flat, lightly feather back on the pedal but hold it steady (i.e. try to get Super Highway Mode); gas will be consumed (orange arrows). You can also Warp Stealth it: Feather back. When you see all arrows yellow, you are in Warp Stealth (Which is a 'glide' above 41mph, when you can achieve all arrows off).
jps000 is offline
Old 08-16-2008, 05:40 PM   #22
diamondlarry
EPA MPG #'s killer
diamondlarry's Avatar
Friends: 6
Originally Posted by Pegasus_ View Post
Wow, that's nuts.
I average 53MPG on the highway, more with hills. This using the "lifting" technique: I gently accelerate to speed, then lift off the accel pedal a bit at speed for a boost in economy while maintaining speed.
I can't seem to get P&G right though on the highway. Every time I try, my average creeps down rather quickly. I don't have a ScanGauge or anything so I can't tell where the engine's most efficient RPM is without knowing what it's supposed to sound like.
Any pointers?
P&G on the highway is slightly different than around town or in the country. On the highway, it's more like Pulse & Bleed. By that I mean pulse up to speed then let off the pedal just enough to let the speed bleed down very slowly. Without a Scangauge, you just want to get the instant mpg bar(on the "consumption" screen) as high as you can while keeping it there for as long as possible. I have gotten as high as 76.6 on a 255 mile trip from Elkhart, IN to Ft. Thomas, KY back in May.
Best tank: 101.1 mpg over 867.4 miles from 8/9/08-9/6/08
Longest tank: 1184.2 miles from 6/15/09-7/13/09
"Fear exists for one purpose: to be conqured!"-Catherine Janeway
diamondlarry is offline
Old 08-16-2008, 09:52 PM   #23
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Default Re: Pulse / Glide
Originally Posted by JimboK View Post
I do my driving mostly in urban and suburban areas with occasional hills, whereas his is mainly on lightly traveled flat rural roads. I am confident I could come close to replicating his results if I had his driving conditions.
Actually, who needs his driving conditions? 93 MPG this afternoon, from my part time job site to my fiancee's house through the middle of Richmond, VA. To the point of this thread, this is with extensive use of pulse & glide, and keeping speeds almost entirely below 40 MPH. A major part of my strategy is seeking routes favorable for P&G. Here's the route I use for this commute, and here's the final screen shot from CAN-View to help convince the skeptics:
Jim
Click here for car details.
JimboK is online now
Old 08-16-2008, 10:00 PM   #24
diamondlarry
EPA MPG #'s killer
Friends: 6
Awesome job Jim!
Old 08-16-2008, 11:06 PM   #25
dwreed3rd
Package: #3 Touring
Originally Posted by diamondlarry View Post
You can get that much into a tank with that rated capacity the same way you can get more than rated capacity in just about any vehicle tank. There is room for expansion of the bladder inside the steel tank. This would not be possible during the winter when the temps would cause the bladder to contract. And, speaking of blinking pips, my pip was blinking for just over 150 miles this time. As for stuffing the tank without damaging the emissions controls, there is room for some expansion before damage would occur. Granted, on a Prius, there isn't as much as other cars. I believe that as long as you don't cram the tank full and go park it in the sun for the rest of the day without driving more than a mile or two that there won't be any damage done. As I already mentioned, I have over 22K miles with no codes/problems. I also live ~14 miles from the station I fill up at.
State sues Sunmart over gas pump overcharges
dwreed3rd is offline
Old 08-16-2008, 11:17 PM   #26
diamondlarry
EPA MPG #'s killer
Friends: 6
Originally Posted by dwreed3rd View Post
Nice try. The pumps in our area are inspected every year usually in June or July.
Old 08-17-2008, 11:57 AM   #27
dwreed3rd
Package: #3 Touring
I didn't understand you comment, "Nice try". I wasn't trying anything! There has been several articles in the news recently about spot checks of gas pumps. A number had been found to be inaccurate and usually, although not always, in favor of the gas station. Some also implied that it seemed to occur more often with some brands than others. I don't know if it's true or not. That's why,, if you noticed I didn't make any opinion other than , which BTW means "no idea", only passing on some information.
Old 08-17-2008, 12:34 PM   #28
diamondlarry
EPA MPG #'s killer
Friends: 6
I would like to publicly apologize for that. I guess I was letting the other comments get to me too much. It's hard to hear people question your honesty as the other poster was after working as hard as I did on that tank; it took me over a month. Again, I am sorry.
Old 08-17-2008, 12:55 PM   #29
dwreed3rd
Package: #3 Touring
Back to you! I apologize for over reacting. I need to throw it away and take a deep breath. I'm ashamed for the way I allow myself to get emotionally involved with some of these posts that are flying around lately, not your's. And unfortunately I allow it to carry over into the next post.
Thank you.
Old 08-17-2008, 02:41 PM   #30
bwilson4web
03 and 10 Prius
bwilson4web's Avatar
Package: #1
Friends: 20
... 93 MPG this afternoon, from my part time job site to my fiancee's house through the middle of Richmond, VA. ...
So the average speed was ~22 mph. Not bad since the peak mileage speed range is in the 18-20 mph range.
bwilson4web is offline
glide, pulse
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/52182-pulse-glide.html
Pulse / Glide - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet This thread Refback 09-12-2008 09:20 AM
Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums This thread Refback 08-16-2008 06:39 PM
Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums This thread Refback 08-16-2008 05:07 PM
Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums This thread Refback 08-16-2008 04:01 PM
Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums This thread Refback 08-16-2008 02:29 PM
Pulse and Glide surfacinglove Gen II Prius Fuel Economy 14 05-08-2007 12:44 PM
Glide, yes. Pulse? What's that? harper42 Gen II Prius Fuel Economy 17 08-21-2006 01:39 AM
Pulse & Glide mod? MikeSF Gen II Prius Modifications 18 08-17-2006 08:54 AM
Pulse and glide Tadashi Gen II Prius Fuel Economy 3 06-19-2006 09:17 PM
Pulse & Glide *-*101 rufaro Gen II Prius Fuel Economy 21 06-13-2006 12:27 PM
