| This is a discussion on Pulse / Glide within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by bwilson4web So the average speed was ~22 mph. Not bad since the peak mileage speed range is ... |
Pulse / Glide
| | #31 |
My Car: 2005 Prius Model: Package: #2 Thanks: 7
Friends: 6 | That of course includes time stopped for red lights and stop signs. I have 47 total lights (if I've accounted for all of them) and five stop signs on this route. I try to time the lights to avoid having to stop completely (some good luck with the lights on this day helped), but invariably I'll have to stop for several -- and for the stop signs of course. |
| | #32 |
My Car: 2010 Prius Model: III Package: #1 Thanks: 347
Friends: 23 | One word of caution, apparently it is OK for us guys to wait on the gals, the other way around is not so true. I probably wouldn't let the future Mrs. know that it takes about an hour and 20 minutes to make a 30 mile drive ... <GRINS> The stop lights and signs explains why you didn't but 99.9. Your model in good tune and that close to the peak speed should in favorable weather and driving sustain 99.9 MPG all day long. ... Ethanol area too? Bob Wilson |
| | #33 |
| Member Join Date: Feb 2007
My Car: 2004 Prius Model: Package: #8 Thanks: 0
Friends: 0 | After having a Prius for almost four years, I had to inquire about "Pulse and Glide" as I didn't know what it was. After applying the techniques, I just achieved my first tank average of 50+ mpg, and it was actually easier than I thought. Even with a heavy mix of city/highway driving. I know if I was was one of those serious hyper milers, I could get better numbers, but I'm not one of those "too serious" Prius owners. |
| | #34 | |
Friends: 6 | Quote:
Yes to the ethanol. And there are two segments on this route of about a mile apiece where those following won't tolerate speeds in the 20s or 30s: two-lane, 45 MPH, moderate traffic. | |
| | #35 |
| Senior Member Join Date: May 2008 Location: Philadelphia
My Car: 2010 Prius Model: IV Package: No Package Thanks: 3
Friends: 0 | Someone please really define the pulse part for me. When I pulse, no matter what I do, I get in the teens or 20's for mpg until I'm back to the speed I want. There basically isn't acceleration if I let go of the pedal anymore. Is that right? Mind you, I was on pace to get about 56mpg on this tank before a long drive hauling lots of furniture and people for about 100 miles. I would like to set the record for quickest to 60mpg, though. I'm only on my second tank ever. |
| | #36 | |
| No Exit Join Date: Aug 2008 Location: Connecticut
I am on my second tank: 65mpg. Last edited by jps000; 08-21-2008 at 07:18 AM. | |
| | #37 | |
Friends: 6 | Quote:
How quickly you pulse will determine how efficient it is. I recommend watching your instantaneous MPG and keeping it at least half your vehicle speed. This will avoid both battery boost and pushing the ICE into inefficiently high ranges. For the teens & 20s you refer to, is that your instantaneous MPG during the pulse? If so, you're in the ballpark for most low speed pulses. Obviously during acceleration your iMPG is low. The key is to make it as efficient as possible then follow it with an efficient glide. The low pulse iMPG averaged with the infinitely high MPG of a properly executed glide will give impressive results. See this thread for more in depth discussion on technique, including pics of what to look for on the MFD during each phase. | |
| | #38 |
| Rambling Man Join Date: Jun 2008 Location: Chicago Illinois
My Car: 2008 Prius Model: Package: #6 Thanks: 23
Friends: 19 | I do not have the scan gauge. Previously, I was trying to use the Consumption monitor as a way to assess my MPG's and tailor my driving habits but it seems like I should use the energy monitor which is somewhat confusing to me to monitor while driving. I found today that I achieved no arrows on the Energy monitor and the MPG's were the highest but I could not prolong the (glide?) I am still having difficulty maintaining high MPG's for any prolonged time without losing too much speed and causing problems for drivers behind me. Questions: why doesn't the Prius have an RPM gauge to tell the driver when the car is operating most efficiency? Does using the the scan gauge actually manipulate the engine systems so the driver can sustain glide or stealth? If so, wouldn't the scan gauge void out the Toyota warranty? Also, I drive such short distance when I drive to work from my City condo to my City office I know my MPG's suffer. When I go to work 30 miles in the suburbs I can sometimes manage 50 MPG + interstate and country road driving. When I see the posts about 60 + MPG's I am amazed. Also, I just past the 3 k mark on my 2008 Prius. I am not sure a scan gauge would be worth it because I mostly drive 6 - 8 mile commute most days in the City. Any recommendations? Terry
__________________ ![]() |
| | #39 |
Friends: 0 | The ScanGauge simply reads data from your car via the OBD (Onboard Diagnostic System). It doesn't DO anything TO the car. The Scangauge helped my mileage, but Teddy Girl of longest tank fame did not have a Scangauge (at least on one of her first great runs--I don't know about the rest). So, you don't need it to do well, very well. Getting to stage 4 of the Prius and pulse and gliding is the key. Sounds like you are doing all that, so not sure what to recommend beyond pulsing and gliding; if you are annoying other drivers, use a more narrow range for pulsing and gliding. It is normal to lose speed, in glide, stealth, warp stealth... |
| | #40 | |
My mileage is only 920 miles total. Should the glide be a little more efficient after another 1,000 miles or so? I'm getting about 52mpg on average between my first two tanks. 12 mile commute each way, lots of stopping and starting. Lots of hills. I probably should be pretty satisfied with 51, but I'd like to do better. | |
| glide, pulse |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/52182-pulse-glide.html | ||||
| Pulse / Glide - Latest Toyota Prius News - Toyota Prius: Blogs and News - Newsbeet | This thread | Refback | 09-12-2008 09:20 AM | |
| Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums | This thread | Refback | 08-16-2008 06:39 PM | |
| Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums | This thread | Refback | 08-16-2008 05:07 PM | |
| Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums | This thread | Refback | 08-16-2008 04:01 PM | |
| Week of August 11th- August 17th (Nat Avg: $3.85) - Page 11 - CleanMPG Forums | This thread | Refback | 08-16-2008 02:29 PM | |
| Pulse and Glide | surfacinglove | Gen II Prius Fuel Economy | 14 | 05-08-2007 12:44 PM |
| Glide, yes. Pulse? What's that? | harper42 | Gen II Prius Fuel Economy | 17 | 08-21-2006 01:39 AM |
| Pulse & Glide mod? | MikeSF | Gen II Prius Modifications | 18 | 08-17-2006 08:54 AM |
| Pulse and glide | Tadashi | Gen II Prius Fuel Economy | 3 | 06-19-2006 09:17 PM |
| Pulse & Glide *-*101 | rufaro | Gen II Prius Fuel Economy | 21 | 06-13-2006 12:27 PM |
