| This is a discussion on Navigation Screen within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; This might be a really stupid question but can driving with the navigation screen off for a long period of ... |
Navigation Screen
| Member Join Date: Jun 2008
My Car: 2001 Prius Model: Package: N/A Thanks: 0
Friends: 0 | This might be a really stupid question but can driving with the navigation screen off for a long period of time allow you to get more MPG? |
Friends: 0 | When you say the NAV screen do you really mean the MFD?. I don't see how a moving map could effect your gas mileage. And the MFD is the nerve-center for all the features of the car. Is it realistic to turn it off for long periods of time.? Just turn the whole car off and save alot of gas. Gimme-a-break. Yeah it would save you some gas, about 100/th of a MPG. Someone quantified how many watts of electrical power used would impact a single MPG. It's a whole lotta Watts. Learning how to drive your Prius, to exploit it capabilities, will have a far greater impact on your MPG. Last edited by 9G-man; 08-19-2008 at 08:09 AM. |
My Car: 2007 Prius Model: Package: #6 Thanks: 1
Friends: 0 | I think a reasonable average energy density for gasoline is about 36.6 kWh/gal. US. So if you drive 50 MPH for one hour and get 50 MPG, you've gone through 36.6 kWh of gasoline. In the mean time the Nav system and display probably draw less than 400 Watts altogether. After using them for that same hour, you'll have "wasted" less than 400 Wh. This works out to something less than 0.011 gallons. Assume triple that for various conversion inefficiencies (gasoline to motive to electrical) and you're looking at somewhere less than 0.033 gallons extra for 50 miles. So if you eliminate the NAV and display I suppose you might have achieved, at best, 50.03 MPG saving you 1 gallon of gasoline for every 1,500 miles. If you drive 12,000 miles per year, eliminating the NAV and display might manage to save 8 gallons per year. Anyone want to check my math? For some reason I'm not feeling confident about it. I expected it to come out quite a bit less than 8 gallons. |
| Senior Member Join Date: Oct 2007 Location: Gilbert, AZ
My Car: 2008 Prius Model: Package: #6 Thanks: 1
Friends: 1 | Quote:
If the entire system pulls 200 Watts, then divide in half. Perhaps 4 gallons per year, and an improvement from 50MPG to 50.017MPG? | |
Friends: 0 | Well, I'm referring to both the NAV and MFD screen. I'm not technical with cars and this hybrid system so I don't know. I've never owned a vehicle with a navigation screen before, but essentially in my mind, the MFD screen is a computer and it would need power to run/turn on all the time. I assume it would need power to run the computer to help you calculate the MPG you are getting at the current moment...? And all those animations from the trip information screen? And I'm "assuming" it needs more power when it connects to the orbital satellites from the GPS to locate your position. And I also assume that it would need more power to pull data from the navigation DVD and render the images...? Then again, that's just my little theory, with no proof to back myself up, I just wanted to see if it's true, but I guess you don't get a lot of savings when you turn the monitor off. |
Friends: 1 | Quote:
You make another good point about the Nav DVD. When using the DVD of my laptop to watch a movie on the plane it does drain my laptop battery much faster... but that's reading a movie sequentially off the disk non-stop. Not sure how much power the Nav DVD pulls when sporadically updating maps for the screen... part of this would probably depend on how much map info is cached elsewhere in the system. Mike | |
I doubt that the total of these computers (MFD display generation and NAV) plus the MFD screen itself adds up to more than 400 Watts (and is likely quite a bit less), but I don't have any reliable information to provide on which to base that assumption. It's mostly just an educated guess. | |
| navigation, screen |
| Mfd Screen Goes Dead During Navigation | rochesteruser | Gen II Prius Main Forum | 14 | 01-18-2009 09:42 AM |
| Bread crumbs on my navigation screen | Ichabod | Gen II Prius Main Forum | 4 | 08-26-2006 07:42 PM |
| Navigation Screen | BarryM | Gen II Prius Audio and Electronics | 5 | 03-04-2006 08:02 PM |
| 2006 Prius Navigation welcome screen | suebeegrl | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 01-23-2006 08:37 AM |
| 3-D Navigation Screen | TonyPSchaefer | Gen II Prius Care, Maintenance and Troubleshooting | 11 | 08-22-2004 11:42 AM |
