This is a discussion on oil type and fuel economy within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I am a new Prius owner (may 08) and just performed first oil change myself (3.3 liters Pennzoil standard grade ...
LinkBack (1) Thread Tools
Old 09-02-2008, 04:00 PM   1 links from elsewhere to this Post. Click to view. #1
pdriley
Default oil type and fuel economy
I am a new Prius owner (may 08) and just performed first oil change myself (3.3 liters Pennzoil standard grade 5/30). I notice a significant drop in fuel economy - about 10% - from low 50s to mid 40s. Is it reasonable to think this is just because of the oil? Other variables: temp, city vs highway, tire pressure, type of fuel - are the same as far as I'm aware. I am not sure what a new Prius has in it for oil. I did not put synthetic in because I plan to change the oil every 5K and it is twice as expensive. Any thoughts welcome...
pdriley is offline
Old 09-02-2008, 08:47 PM   #2
sandman
sandman's Avatar
Default Re: oil type and fuel economy
Check the oil level.. DO NOT OVERFILL..If you overfill it will hurt your MPG's
sandman is offline
The Following User Says Thank You to sandman For This Useful Post:
ETP (07-02-2009)
Old 09-02-2008, 08:53 PM   #3
FL_Prius_Driver
FL_Prius_Driver's Avatar
My Car: 2001 Prius
The short answer is that little difference is seen between oil changes by most PC members. The variation in gas pump shutoff point has usually been the biggest factor. While most of the things you said were unchanged, this one can cause a short term effect. No significant mileage differences have shown up between syn and conventional oil over quite a few threads.
FL_Prius_Driver is offline
The Following User Says Thank You to FL_Prius_Driver For This Useful Post:
ETP (06-23-2009)
Old 09-02-2008, 09:31 PM   #4
JimN
P719 of ???
JimN's Avatar
It's your turn to entertain the evil spirits.
JimN is offline
Old 09-03-2008, 12:50 AM   #5
edthefox5
edthefox5's Avatar
Pennzoil dino oil...that stuff is crap...makes me shudder...
Why don't you put in Mobil 1 and change every 10,000 miles. Lot less used oil. Some people go 15,000 no problem.
edthefox5 is offline
The Following User Says Thank You to edthefox5 For This Useful Post:
ETP (06-23-2009)
Old 06-22-2009, 06:30 PM   #6
ETP
Ancient and decrepit
ETP's Avatar
Friends: 55
Just put in Mobil 0W30 and the car is very quiet. Checking the MPG with the AC off this week. Man it is freaking hot. Any test results on 0w30 and 0w20 and 5w30?
ETP is offline
Old 06-22-2009, 08:00 PM   #7
Frayadjacent
Resident Conservative
Frayadjacent's Avatar
I'm at about 3500 on the odometer (had the car since March) and I'm thinking about changing to a synthetic - either Amsoil or Royal Purple. Then I'll probably keep my interval at about 5000 miles, which should work out to twice a year for me.
As said, be VERY careful about the level. It's been observed that overfilling can cause issues. Better to fill with a bit less than the recommended, drive until warm, then check the oil level and bring it up as needed.
Frayadjacent is offline
Old 06-23-2009, 02:57 PM   #8
spitinuri
spitinuri's Avatar
I use Mobil 1 0W-20 and get a 2-3 mpg boost vs. a dino 5W-30. I still change every 5000 though could probably go 7500 to 10000 safely.
spitinuri is offline
The Following User Says Thank You to spitinuri For This Useful Post:
ETP (06-23-2009)
Old 06-23-2009, 06:29 PM   #9
ETP
ETP's Avatar
Friends: 55
May try that next oil change. Has Toyota officially allowed 0W20 for 2009 models?
ETP is offline
Old 06-23-2009, 07:40 PM   #10
paprius4030
paprius4030's Avatar
Another post a few months ago restated that 5W-30 is the correct oil for the Prius
paprius4030 is offline
economy, fuel, type
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/53026-oil-type-fuel-economy.html
How to Change Oil on 2007 Prius on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback 07-03-2009 09:11 AM
Sudden Drop in Fuel Economy After Service - Ethanol additive in fuel????? nick63 Gen II Prius Fuel Economy 32 04-27-2009 08:49 PM
Fuel Economy nhalber Gen II Prius Fuel Economy 22 02-24-2009 05:36 PM
Bye Bye Fuel Economy! Bill Lumbergh Gen II Prius Fuel Economy 82 12-30-2006 01:18 AM
Fuel Economy Walker1 Gen II Prius Fuel Economy 2 01-17-2006 06:17 PM
fuel economy tara Gen II Prius Fuel Economy 8 01-14-2005 12:04 AM
