This is a discussion on FE with Steel v. Alloy Wheels? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; With the winter season coming back, does anyone have more insight into this issue? I'm trying to make a business ...
Old 09-29-2009, 12:56 PM   #11
Philosophe
2010 Prius owner
Package: Premium (Canada)
Default Re: FE with Steel v. Alloy Wheels?
With the winter season coming back, does anyone have more insight into this issue? I'm trying to make a business case to buy or not a second set of cheap alloy wheels for winter tires.
I still have to asks for prices to know what kind of price difference we're talking about.
So, the question is: which costs more:
1. Paying a premium for alloy wheels and rise FE; or
2. Paying less for steel wheels and lower FE?
Philosophe is online now
Old 10-01-2009, 12:53 PM   #12
uart
uart's Avatar
Hi Philosophe, do you have any data on just how much extra weight we are talking about here (for just the rims - steel versus alloy).
As for the impact of adding rotational mass, be careful about what you read, the following quote for example is very misleading.
I found this little tidbit out on the web-
"The use of light-weight alloys in wheels reduces rotational mass. This means that less energy will be required to accelerate the wheel. Given that each pound of rotational mass lost provides an equivalent performance gain as a 10 pound reduction in vehicle weight, the benefits of light alloy wheels on vehicle performance cannot be overlooked.
For example:
A reduction in the weight of the rim/tire assembly of 5lbs x 4 (all around the car) is equivalent to a 200lb weight reduction in vehicle weight"
This is complete nonsense. To look at the real situation we first have to consider that the effect of extra rotational mass has three different components (not considering the unsprung versus sprung issue here as that is more related to handling and ride rather than FE). The three separate issues are.
1. Increased (rotational) mass increases rolling resistance (all other factors being equal). This is in direct proportion with 1 times the extra mass, there is no "multiplication factor" due to rotating mass here!
2. Increased (rotation) mass increases the fuel required to climb hills. This is again in direct proportion to 1 times the extra mass, once again there is no "multiplication factor" due to rotating mass here!
3. Increased rotation mass increases the fuel required to accelerate your vehicle. Now this is the only one of the three where rotation mass is worse than non-rotation mass. The "multiplication factor" of just how much worse this rotational mass is (compared to a static mass) depends on exactly how the rotation mass is distributed radially.
For example the absolute worst case scenario is where the extra mass is entirely concentrated at the rolling radius in which case the multiplication factor is 2x (each extra kg of rotational mass is equivalent to 2kg of static mass). For a set of car rims however this worst case is completely impossible, because the tire occupies approx the outer 33% of the complete wheel radius. So for a rim a crude "ball park" approximation would be to take the extra mass as if it where concentrated at say 50% to 60% of the overall wheel radius. This give an increase in energy due to rotation of only about 25% to 36% (multiplication factor of approx 1.25 to 1.36).
So in summary. If you used rims that were each 3kg heavier, giving a total increase in mass for all four wheels of 12kg, then the adverse effect would be equivalent to :
1. Adding 12kg of static weight (eg luggage) for impact on rolling resistance.
2. Adding 12kg of static weight for impact on hill climbing.
3. Adding about 16kg of static weight for impact of acceleration.
Considering the three above factors I would say that for the Prius factor one (rolling resistance) is probably the biggest concern because it's happening all the time and is never recovered. Factors two and three above both involve larger forces than that of rolling resistance, but they don't happen all the time and are both mitigated in a Prius by the regenerative energy recovery system. If you where to take an "overall average" of those three factors to determine the net equivalent mass then it would depend on your driving style and terrain covered, but honestly I doubt that it would amount to more than an extra 14kg (for that example of 12kg added rotational mass).
uart is offline
The Following User Says Thank You to uart For This Useful Post:
Philosophe (10-01-2009)
Old 10-01-2009, 01:42 PM   #13
JimboPalmer
Tsar of all the Rushers
JimboPalmer's Avatar
Wheel Tech - Road Wheel Weights Can Affect Your Vehicle's Show...and Go
So in this example they saved almost 1/2 MPG with lighter wheels and the same tires.
JimboPalmer is offline
The Following User Says Thank You to JimboPalmer For This Useful Post:
Old 10-01-2009, 03:59 PM   #14
Philosophe
2010 Prius owner
Realizing things are more complex than that, if I oversimplify things just to get the order of magnitude we're talking about:
17lbs wheels @ 10,9L/100km
27lbs wheels @ 11,1L/100km
an increase of 2%. I then (wrongly) assume the same percentage of difference apply to my Prius.
If I keep my car 250 000km, having 4 months /12 with the winter wheels, this is 85 000km with them on. At a theoretical 6L/100km (don't know yet with Montreal's winters), this is 5000L of gas, at a conservative 1,50$/L (average of next 8-10 years), this is CAN$7500 of gas.
2% of that is CAN$150.
Therefore, I can spend a max of CAN$37,50 more on an alloy wheel that would be 10 lbs lighter than a plain steel wheel. I can get steel wheels at about CAN$55-65.
Simplistic conclusion on this simplistic calculations: I probably won't find light alloy wheels that would be cheap enough to justify their premium over the TCO of the car... or will I...
And then I do not consider the fact that a steel wheel is probably better suited to go through the winter here...
I'm heading to a tire reseller... We'll see...
2010 Prius.
Lifetime average: (yet to be calculated)
Current tank average: 4.7L/100km
Old 10-01-2009, 07:26 PM   #15
uart
uart's Avatar
One unknown factor in that test (linked by jimbo) is that we don't know how (or if) the aerodynamics of the two wheels differs. This could definitely have an impact on the results which is quite seperate to the weight issue.
If all other factors are equal then I'm pretty confident that the overall impact on a Prius will be no more than that of adding about 20% more (than the extra mass of rims) in static weight. So Philosophe how about you try a simple test and drive a tank with 48Lbs of added dead weight to your Prius (40 Lbs + 20%) and see how this effects your fuel economy.
Taking the weight of car plus driver/passenger at approx 3200Lb then 48Lb is exactly a 1.5% increase. My best guess is that an (x)% increase in weight would probably only give about an (x/2)% increase in fuel consumption (because not all aspects of fuel consumption are related to weight, aerodynamimc losses for example are independant of weight).
I'd be interested to see the results of that test, as I said though I wouldn't expect you to see more than about 1% difference on the Prius FE.
uart is offline
Old 10-01-2009, 07:36 PM   #16
uart
uart's Avatar
If I keep my car 250 000km, having 4 months /12 with the winter wheels, this is 85 000km with them on. At a theoretical 6L/100mm (don't know yet with Montreal's winters), this is 5000L of gas, at a conservative 1,50$/L (average of next 8-10 years), this is CAN$7500 of gas.
Yes I think that's a fairly sound assessment of the situation. Personally I think it will be more like a 1% difference than a 2% difference so more like $19 extra per wheel by my estimation.
uart is offline
Old 10-01-2009, 08:03 PM   #17
Philosophe
2010 Prius owner
The choice is even easier than I expected: the tire reseller gave me prices: steel wheels are CAN$55 and alloy wheels start at around CAN$150.
So, for me this is a case closed: steel it will be.
Old 10-01-2009, 09:10 PM   #18
BAllanJ
BAllanJ's Avatar
Package: C
you might want to hop off to Canadian Tire for some ugly, cheap, plastic wheel discs to help the aerodynamics and hide the steel rims.
BAllanJ is offline
alloy, steel, tires, wheels?, winter
WTB 4 - 2008 Prius 15" oem alloy wheels earthman Private Sales 3 09-01-2009 04:07 PM
Rotate Tires with Alloy Wheels rpg51 Gen II Prius Care, Maintenance and Troubleshooting 9 10-24-2008 03:30 AM
Question about steel wheels / rims? (For winter wheels and tires)... AdamKPL Gen II Prius Main Forum 2 09-02-2008 05:41 PM
Prius 2005 Alloy Wheels, a full set Dianne Private Sales 0 01-19-2006 07:14 PM
Steel Wheels? ededed112233 Gen II Prius Main Forum 20 08-03-2005 02:49 PM
