This is a discussion on Fuel Inclination meter reset within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; if it ain't broke, don't try and fix it for the sake of tinkering. the inclination sensors correct for the ...
Old 11-13-2008, 09:38 PM   #11
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
Default Re: Fuel Inclination meter reset
if it ain't broke, don't try and fix it for the sake of tinkering. the inclination sensors correct for the car being on an incline when calculating what to display on the fuel gauge. you could throw off their calibration if you're not on a level surface when you do it. they recommend doing this on an alignment rack...
galaxee is offline
Old 11-14-2008, 12:07 AM   #12
hobbit
hobbit's Avatar
At one point over the summer I parked on a fairly steep slope
to the right, leaving the system powered on, to take a quick stop
into a store. A little while later I noticed that the MFD
average had reset itself. Apparently the strong tilt had been
interpreted as a refueling event.
I also went over some washboard sand roads over the summer that
were bouncing the whole instrument binnacle up and down so hard
I can't imagine how the sensors would be able to hold on to any
concept of reality under that kind of punishment.
I've never reset my sensors since the gauge and the sender seem
pretty well matched, but I might play one of these days.
_H*
hobbit is online now
Old 11-14-2008, 05:41 PM   #13
brick
brick's Avatar
In my case I thought that the gauge might have been off its calibration since my standard "fill" is maybe 7 gallons, less if it's cold. It would have been nice to find that there was an extra usable gallon or two sloshing around in there, but unfortunately that isn't the case. Instead I just run it down a bit farther since I have the ScanGauge giving me enough resolution to be comfortable.
brick is online now
Old 11-14-2008, 08:21 PM   #14
xsmatt81
non-AARP Member
xsmatt81's Avatar
meh.
this must be for older models like 2004.
don't work. Unless Iam just not getting it.
I think I will leave it alone
xsmatt81 is offline
Old 11-14-2008, 08:39 PM   #15
Friends: 37
Originally Posted by xsmatt81 View Post
meh.
Didn't work on my '04 either.
efusco is online now
fuel, inclination, meter, reset
Odd digital fuel gauge performance - reset? quixotequest Gen II Prius Fuel Economy 4 01-18-2008 03:33 PM
Auto Reset of Avg Fuel Consumption Readout ekpolk Gen II Prius Technical Discussion 30 08-02-2007 07:53 PM
Fuel Mileage Doesn't Reset jstern Gen II Prius Fuel Economy 13 01-22-2006 12:33 AM
Fuel Tank Gauge Didn't Reset jchu Gen II Prius Care, Maintenance and Troubleshooting 10 12-29-2004 03:04 PM
Auto reset fuel guage. (Rick) Frank Hudon Gen II Prius Care, Maintenance and Troubleshooting 0 02-09-2004 10:48 PM
