| This is a discussion on Rain or high humidty effects on mpg within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; With fog (liquid water) the actual density of the fluid you are pushing thru increases, so drag increases.Same story with ... |
| | #11 |
| Member Join Date: May 2006
Friends: 0 | With fog (liquid water) the actual density of the fluid you are pushing thru increases, so drag increases.Same story with actual rain-you have to push air aside, and actual liquid water(tires and car body have to displace liquid water, so on the ground, some just hanging/floating in the air while it slowly falls or evaporates). I don't know how much weight/mass of water drops is in a cubic foot of fog, but air is pretty light- 29 grams in 22.4 liters-I think 30 liters is about a cubic foot. Charlie |
| effects, high, humidty, mpg, rain |
| Electronics and its effects on MPG | allentu | Gen II Prius Fuel Economy | 10 | 05-05-2008 12:18 AM |
| A/C switch effects on ICE shutdown | David Beale | Gen II Prius Main Forum | 6 | 02-22-2008 01:19 PM |
| Cold effects on ICE only? | lagreca | Gen II Prius Fuel Economy | 17 | 01-21-2008 03:02 PM |
| Low low milage in cite, high high on high way | gemiao | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-23-2007 06:30 AM |
| running out of gas after effects | feethanddooth | Gen II Prius Fuel Economy | 19 | 08-13-2005 04:33 PM |
