This is a discussion on Why 99.9 MPG more than 5 minutes? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Trevor My bars typically look like that when I'm on my way home from a road trip. ...
Old 05-21-2009, 10:14 AM   #11
2009Prius
2009Prius's Avatar
Friends: 19
Smile Re: Why 99.9 MPG more than 5 minutes?
Originally Posted by Trevor View Post
My bars typically look like that when I'm on my way home from a road trip. take the Verrazano bridge from Brooklyn into Staten Island, I get a really long downhill to the toll booth which tops off the battery, then it's all local streets, so if get all the lights then I get a pair of 99.9 bars at the end.
I don't have such long downhill so I guess it was just one off pure luck.
2009Prius is offline
Old 05-21-2009, 10:24 AM   #12
Matt Herring
Matt Herring's Avatar
Friends: 9
Default Re: Why 99.9 MPG more than 5 minutes?
Originally Posted by CharlesJ View Post
So then, does the car computer computes MPG with that 99.9 as max to calculate MPG or does it use the actual what you read on the scan gauge, 3500, etc as well? I have been wondering about that.
The car calculates infinite mpg while calculating the lifetime/tank mpg you see on your mfd...there is no limit. Based on my SGII readings I have never seen over 4550 mpg on the display so that is what I consider my max mpg (that is while in EV mode at 40-40.9 mph).
Matt Herring is offline
Old 05-23-2009, 06:59 PM   #13
CharlesJ
CharlesJ's Avatar
Originally Posted by 2009Prius View Post
I bet the computer uses the actual fuel consumption, not the artificial display limit.
Well, that would be logical but then I wonder why the average mpg especially soon after a fill-up doesn't change faster to the high side when you calculate with 2500mpg, even for that 1/2-1 mile or so?
CharlesJ is offline
Old 05-24-2009, 11:38 PM   #14
2009Prius
2009Prius's Avatar
Friends: 19
Question Re: Why 99.9 MPG more than 5 minutes?
Not sure if I understand the question. More details?
Old 05-24-2009, 11:46 PM   #15
Matt Herring
Friends: 9
Well first of all when you restart the car it's going to pop into ICE for at least a short time in the start up cycle keeping your mpg under 99.9 briefly. If you are at a gas station at the top of a large hill with a half mile or mile coast possible right out of the station with no cars in your way you can easily register 99.9 on the MFD by utilizing coast down the hill (but you still have to be in ICE briefly at start up and while accelrating to get up to speed).
It is entirely possible to record 99.9 mpg on the MFD...just difficult without perfect driving conditions or hymotion plug-in kit. Next time you're at the top of a huge hill reset the mfd and coast it down the hill and watch the mfd (and your SGII if you have one).
*76.0 mpg 2nd place Hybrid/Diesel Division at 2009 AMEC Economy Competition in Fonda, NY (104 mile run on 8/23/09)
* Best Tank (400+ miles): 66.0 mpg over 402.6 miles from 8/10-21/2009
My Facebook: http://www.facebook.com/photo.php?pi...?id=1268001941
My Twitter: http://twitter.com/bone1124
www.ecomodder.com
Old 09-08-2009, 03:53 PM   #16
Prius2009
Prius2009's Avatar
Can you help me? What does or how does the information help me get better mpg. I have a 2009 for almost a year and my best tank has been 50.5 mpg.
Prius2009 is offline
Old 09-08-2009, 03:58 PM   #17
Matt Herring
Friends: 9
This information is helpful because you can see on the instant mpg bar where the sweet spots for mpg are on your car. With varying degrees of throttle position/pressure on the throttle you will notice subtle changes in the mpg bar (higher or lower). As you slowly back off the throttle the mpg bar will go up. Obviously, you need some amount of throttle to continue propelling the car but you will find a sweet spot of enough power and good mpg (good mpg meaning the highest you can get the bar while still maintaining a decent speed).
With a Scanguage II there is alot more information you can monitor so finding those sweet spots is much easier.
100 mpg, 99.9 mpg, ev mode
First five minutes are the worst! john_dough Gen II Prius Technical Discussion 9 09-18-2008 11:02 PM
# of minutes the A/C will run w/o ICE Air Gen II Prius Main Forum 41 03-16-2008 11:54 AM
Your worst first five minutes? brad34695 Gen II Prius Main Forum 8 06-06-2007 09:29 PM
20 minutes at 100 mpg! PriusRos Gen II Prius Main Forum 9 08-14-2006 11:26 PM
60 Minutes Cameron Prius and Hybrid News 7 04-10-2006 04:54 PM
