This is a discussion on Why 99.9 MPG more than 5 minutes? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Just noticed this after getting home. The last leg of the commute was local roads between 25 and 45 MPH. ...
Old 05-19-2009, 10:53 AM   #1
2009Prius
2009Prius's Avatar
Friends: 19
Question Why 99.9 MPG more than 5 minutes?
The last leg of the commute was local roads between 25 and 45 MPH. I am sure the ICE was on some of the time. There were no long stops. I don't understand how it got more than 5 minutes of 99.9 MPG.
2009Prius is offline
Old 05-19-2009, 11:00 AM   #2
NYPrius1
NYPrius1's Avatar
Default Re: Why 99.9 MPG more than 5 minutes?
Were you going down hill?? They battery was sure kicking in.
NYPrius1 is offline
Old 05-19-2009, 11:09 AM   #3
2009Prius
2009Prius's Avatar
Friends: 19
Post Re: Why 99.9 MPG more than 5 minutes?
Originally Posted by NYPrius1 View Post
Were you going down hill?? ...
There are some gentle up and down hills, but most of the route is pretty flat. Again I am sure the ICE was on at least some of the time.
Old 05-19-2009, 11:22 AM   #4
Matt Herring
Matt Herring's Avatar
Friends: 9
99.9 mpg is just the max the MFD displays for mpg. In EV mode my SGII typically reads 3500-4000 mpg while I'm in EV. In neutral coast my SGII reads 120-200 mpg until I get back into the ICE. So, 2 bars of 100 mpg on the MFD over 10 minutes is entirely possible...great job!
Matt Herring is offline
The Following User Says Thank You to Matt Herring For This Useful Post:
2009Prius (05-19-2009)
Old 05-19-2009, 11:35 AM   #5
a priori
Canonus Curiosus
a priori's Avatar
Model: V
Package: Adv. Technology
Friends: 18
The ICE could have been on for a large portion of the time. The 5-minute bars are averages across each 5-minute period.
Don't be fooled or confused by the 99.9 reading. The readout shows only 00.0 to 99.9. Anytime the mileage reaches or exceeds 99.9 MPG the readout registers 99.9.
Let's take a quick look at how some of this could happen. I'll make some assumptions that may never happen in reality, but still serve to illustrate a point. We'll set you up to run a loop that covers one mile in five minutes. Each minute you cover the exact same distance (1,056 feet). Because you go up and down and either push on or let up on the accelerator, the ICE will turn on and off.
First time around: Let's say you have a machine that registers mileage each minute, and it tells you you've had steady MPGs for each minute at 74.3, 34.6, 98.2, 22.9 and 121.6. If you had the MFD screen give these readings, you could easily see the first four numbers but not the fifth, because it would register as 99.9. If you were steadily covering the same ground in each of those five numbers for one minute each, the 5-minute bar would show at about 70 MPGs.
If you had the same first four numbers for the next four minutes, but the final minute was at 275.1, the next 5-minute bar would show 99.9, instead of the actual 101. If on the next try you had a the same numbers for the first four minutes, but the fifth and final minute was when you were moving but the ICE was on for only the first couple of seconds, you could have had something like 1,235 MPG for that minute. The true 5-minute average would be 293, but the 5-minute bar would show 99.9.
Hope this helps!
Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles.
Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG
Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09)
Lifetime City Mileage: . . . . . . . 57.7 MPG
Lifetime Highway Mileage: . . .56.8 MPG
Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles
Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG
a priori is offline
The Following User Says Thank You to a priori For This Useful Post:
Old 05-19-2009, 03:45 PM   #6
nooaah
nooaah's Avatar
Yup, 99.9 is the max it will display, but you were doing better than that (clearly). For the last 10 minutes of my commute, I'm able to do battery to regen to battery without the ICE ever coming on. Even after I've driven 200 miles it still can raise my total MPG by over 1.
nooaah is offline
The Following User Says Thank You to nooaah For This Useful Post:
2009Prius (05-20-2009)
Old 05-19-2009, 07:54 PM   #7
donee
Hi 09Prius,
Traffic pattern probably was accidentally in a Pulse and Glide, with the glides on some long down hills, and the pulses on short uphills and you hit the green lights. My drives to and from work each day, this time of year (50's to 80's F) show at least one period of 100 plus mpg. A good drive home will have up to 3 of them.
donee is offline
The Following User Says Thank You to donee For This Useful Post:
Old 05-21-2009, 01:03 AM   #8
CharlesJ
CharlesJ's Avatar
So then, does the car computer computes MPG with that 99.9 as max to calculate MPG or does it use the actual what you read on the scan gauge, 3500, etc as well? I have been wondering about that.
CharlesJ is offline
Old 05-21-2009, 01:05 AM   #9
Trevor
My bars typically look like that when I'm on my way home from a road trip. take the Verrazano bridge from Brooklyn into Staten Island, I get a really long downhill to the toll booth which tops off the battery, then it's all local streets, so if get all the lights then I get a pair of 99.9 bars at the end.
Trevor is offline
Old 05-21-2009, 10:13 AM   #10
2009Prius
2009Prius's Avatar
Friends: 19
Smile Re: Why 99.9 MPG more than 5 minutes?
I bet the computer uses the actual fuel consumption, not the artificial display limit.
100 mpg, 99.9 mpg, ev mode
First five minutes are the worst! john_dough Gen II Prius Technical Discussion 9 09-18-2008 11:02 PM
# of minutes the A/C will run w/o ICE Air Gen II Prius Main Forum 41 03-16-2008 11:54 AM
Your worst first five minutes? brad34695 Gen II Prius Main Forum 8 06-06-2007 09:29 PM
20 minutes at 100 mpg! PriusRos Gen II Prius Main Forum 9 08-14-2006 11:26 PM
60 Minutes Cameron Prius and Hybrid News 7 04-10-2006 04:54 PM
