| This is a discussion on Most fuel efficient speed (highest MPG)? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by CharlesJ I am not a fast driver, don't approach the limits much and haven't gotten to 50 ... |
| | #21 | |
Friends: 35 | Quote:
You need to work on anticipating stops and letting off the gas pedal and gliding for as long as you possibly can. Do this on country roads and you will see a big jump in milage. I also do this on residential streets. There are MANY cases where you can accelerate from a stop sign and just lift the gas, reapply a bit of pressure and glide to the next one. Most people just accelerate up to speed then sit there with their foot on the pedal and the ICE running then start applying the brake for the next stop. This is very inefficient. I used to never get over 50mpg but once I started playing around with gliding to stops from as far away as possible my milage shot up and getting 51-53mpg was realitvely easy. I would need to P&G to get over 55mpg though. All that changed when I swapped to new tires and changed my commute which now inclused a 2,000 elevation gain every day.
__________________ 2005 Prius - Upgrades: Kenwood eXcelon KDC-X993, Diamond Audio D9800.2 and D61500.1 (1900w RMS), Diamond Audio D971 7" component set, 2 Diamond Audio D910D4 10" subwoofers (600w/ea). ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. | |
| | #22 | |
| Junior Member Join Date: Sep 2008 Location: London, UK
My Car: 2008 Prius Model: Package: T Spirit Thanks: 13
| | #23 | |
| "Dream" Prius Join Date: Apr 2007 Location: Cincinnati, KY
My Car: 2007 Prius Model: Package: #2 Thanks: 3
Friends: 6 | Quote:
Yes I have and EV switch and and EBH and I use the EV switch to kill the engine in stages 2-3. This helps tremendously. The EBH lets me start with 125-135F at startup. I am not using the temperature sensor hack. If you use the EBH, since I start with such a high temp, I get into stage 4 very quickly. Last edited by bestmapman; 05-27-2009 at 04:25 PM. | |
| | #24 |
| Senior Member Join Date: Jul 2007 Location: White Plains, NY
My Car: 2007 Prius Model: Package: #3 Thanks: 17
Friends: 0 | |
| | #25 |
| non-AARP Member Join Date: Mar 2008 Location: Vegas
Friends: 0 | I still P&G when I can, often i forget though and just drive it. Came in from St.George last weekend and was going 85 on the freeway, I still netted around 43mpg. It's creeping back up towards 46 avg now with P&G and gliding. I still managed to get 479 miles on that tank with aggressive driving. I attribute some of that to the fact I used Shell gas on that tank, my mpg always shoots up easily when using Shell gas. The prius loves it, the new Nitrogen enriched stuff seems even better. driving 50 in a 65 is dangerous around here, likewise going 25 in a 45 is really bad, and will probably get you a ticket. The only time I P& G are on side routes, off the main drags.
__________________ 2007 Prius Black BT Tech Stiffing Plate Weather Tech Mats/Cargo Area Mat DM Bug Guard(rock guard) Full Tint Splash Guards Coastal Tech EV mode(new)& Coastal Auto Door Lock Whistler XTR695 Radar/Laser & Garmin Nuvi 1350 |
| | #26 |
Friends: 0 | if anything shouldnt the Nitrogen decrease gas milage b/c the gas then has a lower % of gas in it and thus a lower energy content? |
| | #27 | |
My Car: 2010 Prius Model: III Package: #1 Thanks: 147
Friends: 20 | Quote:
Folks have been using one of two formulas to express the vehicle performance:
rolling_drag - treated as a constantBob Wilson | |
| | #28 |
Friends: 0 | For all we know it's more energetic than gasoline, but in any case it's a trivial amount of material and will have no significant direct effect on MPGs. Even E10 is only 3% less energetic than gasoline, gallon for gallon. |
| | #29 | |
F = mg*mu m = mass = 1398 kg g = accel of grav = 9.81 m/s^2 mu = coefficient of friction = 0.0105 I forget where I found the 0.0105 but is the difference in the equation. | |
| | #30 | |
Bob Wilson | |
| best speed, fuel economy, fuel efficiency, mpg, speed |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/61884-most-fuel-efficient-speed-highest-mpg.html | ||||
| VN Boards - Why do most Prius owners seem to drive ridiculously slow? | This thread | Refback | 06-01-2009 02:37 PM | |
| Instead of producing more fuel efficient cars, how about a speed limit cap... | burritos | Environmental Discussion | 51 | 06-27-2008 02:27 PM |
| Highest speed driven in Prius | jeff716a | Gen II Prius Main Forum | 31 | 02-05-2007 10:28 PM |
