This is a discussion on Most fuel efficient speed (highest MPG)? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by Midpack It's not just you, I accelerate slowly, drive the speed limit, keep my tires inflated, keep ...
LinkBack (1) Thread Tools
Old 05-30-2009, 08:21 AM   #31
9G-man
Default Re: Most fuel efficient speed (highest MPG)?
Originally Posted by Midpack View Post
It's not just you, I accelerate slowly, drive the speed limit, keep my tires inflated, keep the windows rolled up and AC off (as much as possible) - and while I get good mileage, I never see the high numbers others post. My Prius mileage averages about 47. I don't understand how they do it...
That's all good, but do you know how to consciously stop the gas engine (ICE) , at will, and attain a glide below 41 MPH, or warp stealth above that speed? If you don't do that, or are not aware that you can, you won't get the stellar mileage that you read about here.
Turn you A/C back on. set it for about 76-78. Running the A/C has little impact on MPG, infact you need to run it when it's hot, to keep the battery cool, which will result in better MPG by allowing you to better glide and warp stealth. If you are feeling hot, so is the battery.
What do you inflate you tires to? I'd suggest 42/40 psi as a minimum if striving for great gas mileage.
I leave my A/C at 78 deg. and never get hot. I regularly get 60 MPG and over 600 miles to a tank.
9G-man is offline
Old 05-30-2009, 09:36 AM   #32
donee
Hi Bob,
That "EPA Approach" is just a polynomial expansion. Its common for experimentalists to use a polynomial expansion to describe a measured curve, rather than an theory based equation, that is incomplete (such as the what you call "traditional") and thus does not match the measured curve exactly.
Hi Best....,
Well, when I was using the MYCANSCAN, I saw failures to auto-stop with the car as hot as 90 C (194 F) and with speeds greater than 35 mph. So, the car is well into stage 4, had been for 10 minutes or more, and still would fail to auto stop. The 70 C (158 F) limit just gets you into to a point where it will auto stop if you go for a glide above 35 mph. It still has a whole bunch of warm-up tricks to do before it locks in the auto-stop during with a 35 mph speed, let along at low speeds. Possibly your not noticing this because your driving in an area where the car rapidly transistions from 70 to 90 C . In suburban traffic, its common to have the car up and down between those two numbers before it will finally stays up at 90 C. When the car gets above 73 C, it will stop auto-stoping (at speeds greater than 35 mph). Then it will start back up when it gets above 76C. Additionally, I forget the actual temp, but somewhere in the mid-80s, the temp will do a little drop , and during that time (presumably when the thermos is being filled with hot coolant), the car will not auto-stop at speeds above 35 mph. This comfounded my mileage on one route, because that happened just where there was a nice shallow 2 mile long glide road. Everytime you glide its down below that 80 something temp, and then back up near that 80 something temp, and the car is going to no-auto-stop mode. They need to make that action more asyncronous, such that it happens once, and is done with it. The effects there are dramatic - if auto-stop is working 100 mpg plus for that section, if not, 60 mpg.
That last paragraph is all about the 35 mph plus autostoping. Sub 35 mph autostoping is not even noticed till the car has been running about twice as long.
SO, now I am more than 1/3 the way through my commute and the car is now reliable at auto-stopping above 35 mph, and the temp is 88 C or above. But lately, due to a deviation to avoid construction, there is a long shallow 30 mph glide I am doing, and after that there is a hill. With the normal route on this hill the car reliabley autostops above 35 mph. Not with the new route and the 1 mile 30 mph glide (after peaking at 35 mph briefly) just before it, even after climbing the 35-40 mph hill. Without the Mycanscan I cannot tell you temps, and also without it I am not risking more grill blocking than 1/3 on the bottom and full on the top. This happens with temps in the mid 70's F. I have never been able to correlate these actions to cat temps on the Mycanscan, but I did not know what to look for. The temps get above 400 C rather quickly and stay up in the 500's C most of the time.
Its this issue that prevents me from getting over 70 mpg on a tank. Somedays it will be flawless, others it will not develop the no-auto-stop syndrome.
I have no modifcations to my car other than some aero-mods, and the above mentioned grill blocks.
I am loathe to try the thermistor hack, without some sort or more smarts in the modifications. Something like a PIC controller, which would present the true temps to the ECU, after a certain temperature is reached (90 C?). I am also loathe to use a scan-gauge due to poor operational ergonomics of this legal device. The MYCANSCAN resolves the operational egonomics of an almost full (does not have injector pulse width) featured dash board. But, its illegal here in Illinois as its implemented on a PC platform. If it was a stand-alone, even with the same 7" diagonal screen, single purposed device, it would be legal. Without the temp gauge, I cannot run more sumertime grill blocking. From when I was running with the temp gauge, I could tell that for my routes, a good grill block in temps above 60 F at the beginning of the trip, was too much at the end (to the point where autostop was not occuring, as the engine wanted to run the water pump to stay cool). A variable grill block is really needed.
BTW, finished this latest tank at 66.6 mpg.
donee is offline
best speed, fuel economy, fuel efficiency, mpg, speed
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-fuel-economy/61884-most-fuel-efficient-speed-highest-mpg.html
VN Boards - Why do most Prius owners seem to drive ridiculously slow? This thread Refback 06-01-2009 02:37 PM
Instead of producing more fuel efficient cars, how about a speed limit cap... burritos Environmental Discussion 51 06-27-2008 02:27 PM
Highest speed driven in Prius jeff716a Gen II Prius Main Forum 31 02-05-2007 10:28 PM
