| This is a discussion on ICE loss vs. conversion loss - use or not use ICE from dead stop? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Someone suggested starting a new thread to continue a diversion from another thread. The question is for max MPG whether ... |
| Senior Member Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: Package: #2 Thanks: 246
Friends: 19 | Someone suggested starting a new thread to continue a diversion from another thread. The question is for max MPG whether to use ICE from a dead stop (assuming car is warmed up and SOC is enough). It seems to me a compromise between ICE loss (ICE not most efficient at very low speed) and conversion loss (ICE -> battery -> motor is lossy process). We need more data. Thanks! |
Friends: 0 | Hi 2009P..., Depends on traffic. If you cannot get the engine up above 1800 rpm for your accelleration, its best to use the electric lightly, until a big gap develops, then go to engine at 1800 to 2400 rpm. It also depends on if you have allot of hills. Since you entered your location as "USA" its not possible to know if your location has allot of hills. If you have hills, then the energy to climb the hill goes into the battery on the way down. And so , your going to have the conversion loss whether you want it or not. If you do not use that energy up, then the car will free wheel the engine with Motor Generator 1 (MG1) until the battery SOC comes down. The Prius is not an electric car. As such, the motors, cables and batteries are do not have the low resistance pure EV cars have. Heavy accelleration in EV mode is going to waste allot of energy due to the electric system high power inefficiency. I believe under such conditions the Prius only converts 60 some percent of the battery energy to car motion. The best way to use stealth mode is when you want to keep going along at the same speed, but not start the engine. |
| The Following User Says Thank You to donee For This Useful Post: | 2009Prius (05-28-2009) |
Friends: 6 | For background, here is the other thread. Donee, with all respect, the problem with the less-than-1800 rule is that most won't know their RPM. Furthermore, I have come to believe that low RPM at low speed is not inefficient. The subject of how much go-pedal to give during ICE-on conditions of course is a matter of substantial discussion. Low-RPM conditions are thought by many to be inefficient, and the theoretical power curves of the Prius seem to confirm this. But anecdotally, many hypermilers (me included) have reported good results with keeping RPM as low as 1200 or 1300 at low speeds. I have done some preliminary testing comparing various acceleration rates during pulse and glide, and the results suggest rates in the range of 1300 are at least as efficient as those in higher ranges. The key word is preliminary, however; the test environment was less than ideal (traffic disrupted my glides on the two-lane rural road I was using), and I'd like to repeat the tests in a different environment. Meanwhile, Hobbit recently has experimented using fuel injector timing as a surrogate indicator of engine load. The ICE really is inefficient when it's not running under load, and his view is that as long as injector timing has reached a certain operational plateau, the ICE is loaded. Quoting him: "Even a fairly gentle startoff from the line yields injector times of high sixes or 7.x at ridiculously low RPMs like 1250, as high torque is produced to help takeoff."My own recent experience applying this and using injector timing as my load criterion (monitored in CAN-View) suggests that in ICE-on conditions at low speeds it's actually difficult for the ICE not to be under load. Especially from a dead start, after "goosing" the go-pedal just enough for the ICE to light, I show injector timing levels well above the "loaded" threshold even with these low RPM. So that has become my approach for "normal" acceleration purposes from a dead start. I agree that for short-duration, low-demand situations it is probably more efficient to run in EV mode; those are the "abnormal" situations: around a parking lot or driveway, or as you suggest, extending a glide. For those without added instrumentation, I describe a rule of thumb for efficient ICE-on conditions here, (from which much of this post has been copied and pasted). Last edited by JimboK; 05-27-2009 at 10:14 PM. |
| The Following User Says Thank You to JimboK For This Useful Post: | 2009Prius (05-28-2009) |
Friends: 59 | I agree with JimboK with the ICE high efficiency at those low RPMs. If you plot hp from the graph below, 15 hp to 20 hp are around 1,200 RPM to 1,600 RPM. Prius ICE is 35-36% efficient at those low RPMs. Otto cycle ICE can not touch it even at their peak. ![]() To answer OP's question, I accelerate with the battery 10-15 MPH before the ICE kicking in. The reasons are: - A chance to use the power captured by the regen brake. - Minimize conversion loss from ICE. Below 10 MPH, most of the ICE power goes to the generator. At 0 MPH and if ICE runs at 1,500 RPM 100% of the power (~18hp) goes to the generator to power the MG2. If the ICE were to kick in at 15 MPH, 56% of the power goes through conversion and 44% goes through directly to the wheels. Note: My style is adapted to fit traffic here in NY.
__________________ Prius shaped the form of future cars. Hybrid Synergy Drive is the engine of change that moved us forward. Kyowa KR206 17" Black Chrome Lips | Sherwood Wood Dash (Birds Eye) | Infinity 6020CS Front | Kappa 62.7i Rear | B-Quiet Ultimate | LED Interior+License Plate | EV Button | Auterra Dyno Scan | Professionally Self-Installed Leather |
| The Following User Says Thank You to usbseawolf2000 For This Useful Post: | 2009Prius (05-28-2009) |
| Senior Member Join Date: Mar 2009 Location: Queens, NY
My Car: 2009 Prius Model: N/A Package: #2 Thanks: 73
Friends: 1 | |
Friends: 10 | wow... what a complicated way to say... JUST DRIVE IT, BUT DRIVE IN CONSERVATIVELY!! by considering the option of using EV, you have already conquered the beast. no sudden acceleration (since EV wont allow it) anticipate traffic flow by keeping a little extra following distance, timing lights, etc... and that is all you need. as far as what mode to use during this?? that is not your job. let the millions of investment dollars behind the technology work for you!! |
| The Following User Says Thank You to DaveinOlyWA For This Useful Post: | 2009Prius (05-28-2009) |
However, if you accelerate slowly enough to prevent the ICE from starting, then you are drawing from the battery and adding in battery losses. Therefore your best bet for accelerating from a stop is to do so briskly enough that the ICE starts. Avoid jackrabbit starts, but also avoid crawling starts. In a pure EV, the more gently you accelerate the better. But the Prius is a horse of another color altogether because it's a gasoline car getting all its energy from gasoline via the ICE, but allowing the ICE to operate in a more efficient range since ICE speed is almost completely decoupled from vehicle speed: The ICE can turn at any speed the computer likes, regardless of vehicle speed. So much so that the ICE turns forward while the car goes backwards, without using a reverse gear.
__________________ Daniel Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph. Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power. Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius. "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | |
| The Following User Says Thank You to daniel For This Useful Post: | 2009Prius (05-28-2009) |
Friends: 59 | Quote:
Majority (80%) of my daily miles are @ 65-70 MPH in the HOV lane. Average at these speeds is probably 45 MPG. The remaining 25% are low speed local or highway traffic congestion and they bring up the overall MPG. If I leave a little earlier from home, I take HOV lanes just to avoid a few jam exits. This way I can go slower (@55-60 MPH) in the right lane. I averaged 55 MPG in last summer this way. My best tank was 65 MPG with unusually heavy traffic jams on LIE. My favorite part is the congestion section on LIE after HOV lane end. I get 75 - 99.9 MPG until I exit at 22B to home. | |
| New Prius Owner Join Date: Aug 2008 Location: Ilirska Bistrica, Slovenia
My Car: 2008 Prius Model: Package: N/A Thanks: 0
Friends: 1 | Well, the driver is still the boss and can influence greatly. Computer just takes care of other details. Like others have observed. I see quite good fuel economy driving around 1300 rpm. Regarding acceleration, on lower speed ranges, accelerating in range between 1800 - 2300 rpm gives me best fuel economy results. On highway I have to push the rpm above 2500 to accelerate and keep it in range around 2800 - 3300 rpm to still be efficient. Above that rpm value, fuel economy is more or less getting quite efficiently killed. |
| battery, conversion, efficiency, ice, mpg |
| Nissan reports first annual loss in a decade, but sees smaller loss this year | cwerdna | Other Cars | 0 | 05-13-2009 03:13 AM |
| Loss of acceleration from a stop! | ZC1 | Gen II Prius Main Forum | 9 | 12-07-2008 05:16 PM |
| How do you deal with the loss of a pet? | livelychick | Fred's House of Pancakes | 51 | 03-17-2007 01:32 PM |
| Total Loss | skruse | Gen II Prius Main Forum | 44 | 10-28-2006 03:51 PM |
| Loss of oil pressure | bluedogpoker | Gen II Prius Main Forum | 33 | 06-24-2005 03:37 PM |
