| This is a discussion on Goodyear Fuel Max tires within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I'm planning on going in to Discount Tire on Monday 6/22/2009 to get a set of Fuel Max tires for ... |
| | #21 |
| Senior Member Join Date: Jan 2006 Location: San Antonio, TX
Friends: 0 | I'm planning on going in to Discount Tire on Monday 6/22/2009 to get a set of Fuel Max tires for the stock wheels. Can anyone else who's bought a set share what they spent for pricing? I saw someone said they got a $20 rebate from Goodyear and Discount matched at $20 off? I just called in today and they quoted me at $87 per tire. Any other suggestions before I go in and have them installed? The only thing I can think of is I'm going to mention the tire pressure sensors in the wheels to make sure they don't damage those taking the tires off and mounting the new ones. Thanks! Looking forward to these tires though, I'll likely start off at stock PSI in the tires and report back on any discernable differences. I still have the stock Goodyear Integrities and about to roll over 40K miles now, tread is very low and typically averaging around 53~54 MPG.
__________________ 2006 Magnetic Grey Pkg. #8, OEM EV Button, 5.1 Nav DVD, All Weather Floor Mats, Cargo Nets, Window Tint. |
| | #22 |
My Car: 2007 Prius Model: Package: #2 Thanks: 166
Friends: 22 | TireRack.com sells them for (prices exclude shipping): Standard Prius OEM size 185/65R15: $75 Standard Prius Alternate size 195/60R15: $81 Touring Prius OEM size 195/55R16: Not Available Touring Prius Alternate size 205/55R16: $99 |
| | #23 | |
I just noticed the $20 Goodyear mail-in rebate offer on TireRack. I wonder if this will also be available through Discount Tire. Last edited by ilusnforc; 06-20-2009 at 02:51 PM. | |
| | #24 |
Friends: 22 | |
| | #25 |
| Junior Member Join Date: Jun 2009 Location: Florida
My Car: 2004 Prius Model: N/A Package: No Package Thanks: 0
Friends: 0 | I got these tires a few weeks ago. Ordered online from Tire Rack and had delivered to my auto shop. Very pleased with them. First couple tanks of gas the car got 50 - 52 MPG. Previous tires, Yokohama, when new dropped MPG down to 44, but by the time they were balding were getting 50 - 54 MPG. They drive fine, but I'm not one to notice performance things. I am very satisfied with the tires and am glad they live up to the fuel max name. |
| | #26 |
| Junior Member Join Date: Jan 2009 Location: Pasadena, CA
My Car: 2010 Prius Model: V Package: Navigation Thanks: 0
Friends: 0 | First, thanks for all the previous reports on this forum about the Fuel Max Tires. I bought four GoodYear Assurance Fuel Max tires at American Tires (Discount Tire outside of California) in Pasadena today. $91 each before tax, title, fees, balancing, disposal, certificates, et al. The Integrities had about 25K on them and were worn enough that there was slippage on wet pavement at acceleration and they were a bit loose on the freeway. Four new tires is cheaper than a hospital stay. The tire installer told me that he had pumped them up to 35/33 and sent me on my way. First thing I noticed was that my Prius rolled very free and long. Second thing I noticed was that I was feeling the road a good deal more than I had expected. Once home, I checked the PSI with my compressor and found the tires at 42 in the front and 40 and 38 in the rear. This was OK because I was going to pump them up to 42/40 in any event. However comma it is also good to note that everything should be checked no matter how trusted or competent seeming the installers. Noted that "Fuel Max" on the tires is denoted by a little gas gauge symbol with "Fuel Max" in tiny letters. Looking forward to driving these and reporting the results. PasPrius
__________________ If we do not invent the future, others will do it for us. B5 |
| | #27 | |
My Car: 2008 Prius Model: Package: #2 Thanks: 112
Just one note on the above your tire pressure should be set when cold ("cold" as in not-recently-driven.) You probably know this, but others might not. If checking it in the first half hour or so after driving the rubber and air inside will be warmer than ambient and they will read higher by a few pounds or so. It's still okay to check pressures just to make sure everything is in a safe range and to approximately set the pressure. The impact of this is that as winter approaches tire pressures begin to decline even without any air loss...and as summer approaches the tire pressure will increase unless air losses offset it. I've not had to add any air for the past several months as the average daily temps have increased by around 50 F. For the remainder of the summer though I expect to lose about 1 psi/tire per month which seems to be a fairly normal loss rate. | |
| | #28 |
Friends: 0 | Ditto that. The best time to measure is in the morning, or before starting the day's driving. This should be done at least once per month. PasPrius, how much did you pay including all that other stuff? |
| | #29 |
| Junior Member Join Date: Jun 2009 Location: Washington State
My Car: 2006 Prius Model: N/A Package: #4 Thanks: 0
Friends: 0 | After getting 52,000 on my original Goodyear Integrities, I put the Goodyear Assurance Fuel Max on my Prius last week. In the summers I get on average 51mpg, and in the winter (using the heater) it drops to 46-48mpg. I will post if the mileage changes with the new tires. |
| | #30 |
Friends: 0 | Richard- Here's the full breakdown of the cost: $364 4 Fuel Max Tires $ 52 4 replacement certificates $ 7 Environmental Fee $ 9 Waste Disposal Fee $ 60 Lifetime spin balancing $ 32 TPMS Rebuild $ 37.46 Tax $561.46 Total Shawn- I took the TP about 2 hours after I got home. Checked again this morning. PasPrius |
| The Following User Says Thank You to PasPrius For This Useful Post: | richard schumacher (06-25-2009) |
| fuel, goodyear, max, tires |
| For Sale Goodyear Integrities (4) tires | Fred Wacksman | Private Sales | 4 | 04-02-2009 10:04 AM |
| Goodyear Tires | floridaprius | Private Sales | 0 | 11-19-2007 10:35 AM |
| Best tires Goodyear Invicta | etyler88 | Gen II Prius Fuel Economy | 3 | 06-23-2007 06:17 PM |
| S.F. Bay Area: OEM Goodyear tires | Recovering Gas Guzzler | Private Sales | 0 | 03-09-2006 12:30 AM |
| Goodyear Integrity OEM tires. | wb9tyj | Gen II Prius Care, Maintenance and Troubleshooting | 10 | 11-21-2004 01:13 PM |
