| This is a discussion on Battery gauge bars - misleading? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Today my warning indicators, ie. triangle with !, car with ! and check engine, all came on. When I accessed ... |
| | #11 |
| Member Join Date: Feb 2004 Location: Shoreview, MN
Friends: 0 | Today my warning indicators, ie. triangle with !, car with ! and check engine, all came on. When I accessed the battery gauge, there were only two pink bars. I turned off the engine, restarted and drove for about 2 minutes and everything but the "check engine" light went away. The battery gauge bars changed from pink to blue and soon were increased from two to 6 or 7. Then they momentarily changed from blue to green. I couldn't find any explaination for the colors in the manual. Is this a common "glitch?" Should I take it in immediately? What do the colors mean? What caused this?
__________________ 2004 Silver #9 "Amanda B. Green" 02/12/04 67,000 miles so far 1973 Datsun 240Z |
| | #12 |
Friends: 0 | you probably need the computer flashed, this is a fairly common complaint and well known. When the dealer pulls the codes it'll say engine failed to start. |
| | #13 |
Friends: 0 | I called the dealer and he said they couldn't do anything if the warning lights were not there as the diagnostics had reset themselves. Hadn't heard af this as a problem, either. |
| | #14 |
Friends: 12 | Bull. First, the Check Engine is still on? So the problem hasn't "cleared" and may not clear. Second, the Prius has Freeze Frame and will grab 5 frames to assist in troubleshooting. More than likely, you need the reflash done. |
| How many battery bars do you usually have? | PriusOwner004 | Gen II Prius Main Forum | 6 | 09-03-2007 06:11 AM |
| Bars on battery | dborovay | Gen II Prius Main Forum | 2 | 08-01-2006 09:30 PM |
| battery bars | elecblue | Gen II Prius Main Forum | 5 | 11-05-2005 08:05 PM |
| My fuel gauge suddenly lost 3 bars | mootmom | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 04-18-2005 01:19 PM |
| Fuel Gage Bars - Misleading? | sdgeiger | Gen II Prius Fuel Economy | 1 | 02-22-2005 08:38 AM |
