This is a discussion on MPG seems impacted by heat and cold within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; So we are approaching 10K miles since Oct 08. We are getting 48.9 MPG over life of the car. During ...
Old 06-24-2009, 01:44 PM   #1
spidey
Default MPG seems impacted by heat and cold
So we are approaching 10K miles since Oct 08. We are getting 48.9 MPG over life of the car. During spring, less AC and no heat, we were getting almost 52MPG but once the hot/humid weather came to NC we have dropped back to 48.8. Not complaining but seems AC also impacts the MPG specifically during that first 5 minutes and we seem to be doing more of those short trips of late.
spidey is offline
Old 06-24-2009, 02:21 PM   #2
JimboK
One owner, low mileage
JimboK's Avatar
Friends: 6
Default Re: MPG seems impacted by heat and cold
Correct. Without climate control, fuel economy improves with temperature. Climate control in summer gives a small hit with highway driving, a bigger hit with city driving, and potentially huge with stop-and-go conditions.
JimboK is offline
Old 06-24-2009, 02:54 PM   #3
Sandy
Hippi Chick
Sandy's Avatar
Friends: 8
Mine last tank was 38MPG think because of all the short trips, everything is 1/2 mile or less
Sandy is offline
Old 06-24-2009, 03:06 PM   #4
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
A/C (both heating and cooling) takes energy to use, and that energy is generated with gas...
mpg also takes a hit from air density when cold, and a boost from hot air (less dense).
Bob64 is offline
Old 06-24-2009, 03:33 PM   #5
a priori
Canonus Curiosus
a priori's Avatar
Model: V
Package: Adv. Technology
Friends: 18
Originally Posted by spidey View Post
. . . Not complaining but seems AC also impacts the MPG specifically during that first 5 minutes and we seem to be doing more of those short trips of late.
You may want to reconsider your use of A/C on those short trips, unless your car interior already is cooled. Also, when using A/C you may want to set the temp higher (say 75 or 76) and limit the fan speed instead of using Auto. Each of these steps saves energy! The first five minutes also is highly critical, so you could consider limiting the fan a bit more for those few minutes.
Originally Posted by Bob64 View Post
. . . mpg also takes a hit from air density when cold, and a boost from hot air (less dense).
And that humid Carolina air is even less dense. This helps, to a point: when the dew point is high enough to approach the ambient temp, the condensation formed on the car's surface can start interfering with those "gains" from lower density air!
Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles.
Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG
Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09)
Lifetime City Mileage: . . . . . . . 57.7 MPG
Lifetime Highway Mileage: . . .56.8 MPG
Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles
Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG
a priori is offline
The Following User Says Thank You to a priori For This Useful Post:
ETP (06-24-2009)
Old 06-24-2009, 04:04 PM   #6
Shawn Clark
Shawn Clark's Avatar
Adding to the above, the battery is "happy" at roughly the same temperatures as the occupants. In mid winter the car is inclined to charge the HV battery to double green bars at times until it is up to temperature. There are some specific temp threshholds it targets (if I correctly recall what others reported.)
At some point the battery can get too warm and require cooling. I've not noticed this happening yet and don't know how the battery cooling fan sounds. But apparently it could also be counterproductive to try to be Spartan and soldier along at 110 F in the cabin.
The battery temperature mileage effect is one that conventional vehicles don't experience. It is pretty noticeable at times when the temps are at/below the teens.
Shawn Clark is offline
The Following User Says Thank You to Shawn Clark For This Useful Post:
ETP (06-24-2009)
Old 06-24-2009, 05:32 PM   #7
ETP
Ancient and decrepit
ETP's Avatar
Friends: 57
looks like our 100+ weather has died for awhile but I still drive with the AC off. Do you get some sort of warning if the battery is too hot?
ETP is offline
Old 06-24-2009, 07:18 PM   #8
JimboK
JimboK's Avatar
Friends: 6
No direct warning. You might hear the battery fan cut on, though I've never heard it either. If you're really attuned to the car's operational nuances, you might notice a change like I describe here.
Pardon the cliché, but prevention is the best medicine. The battery can easily get to 100F+ after baking in the sun all day, and its large thermal mass makes it slow to cool (and warm in the winter). I have tinted windows, I use a sunshade, I crack the windows, and IMHO most important, I park in the shade when possible.
JimboK is offline
The Following User Says Thank You to JimboK For This Useful Post:
ETP (06-26-2009)
Old 06-24-2009, 08:01 PM   #9
JimN
P719 of ???
JimN's Avatar
It has been reported that the battery fan sounds like a turbofan on a jet. I believe the car will turn on the AC automatically to cool the cabin to cool the battery. Yes, the car doesn't like too cold and too cold. It seems to run best in the 60's.
JimN is offline
Old 06-24-2009, 10:32 PM   #10
Shawn Clark
The temperature extremes at the battery also limit or prevent transfers to/from the battery as I understand it. (If someone here has better/more detailed information the please correct this.) When the battery control system is unable/unwilling to allow the HV battery to be used as intended, your mileage will tend to suffer as the engine will be on more. That is what I meant about it being counterproductive not to use the AC when it is getting very toasty in the cabin.
ETP (06-26-2009)
cold, heat, impacted, mpg
Heat or A/C? p1cfl01 Newbie Forum 4 10-27-2008 09:06 PM
No heat! boriqua9719 Gen II Prius Care, Maintenance and Troubleshooting 4 02-07-2008 07:25 PM
Hows the heat in cold temps. FishHawk Gen II Prius Main Forum 9 11-06-2006 09:37 AM
AC and Heat lbligh Gen II Prius Main Forum 1 02-19-2006 08:42 PM
Heat and AC tbstout2 Gen II Prius Fuel Economy 9 12-09-2005 05:14 PM
