| This is a discussion on Most efficient A/C mode? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; OK. i'll try 78 and from the sound of it, it should be fine.... |
| | #21 |
| ZEN-style living Join Date: Feb 2008 Location: La Canada
My Car: 2008 Prius Model: N/A Package: #6 Thanks: 1
Friends: 17 | OK. i'll try 78 and from the sound of it, it should be fine. |
| | #22 |
My Car: 2004 Prius Model: N/A Package: #6 Thanks: 93
Friends: 0 | Do note that the battery system draws its cooling air from the passenger cabin. If the cabin is too warm for the average hairless ape then it may be too warm for the battery also. When a battery and its controls are too warm they have to throttle themselves, limiting the charge and disharge rates. It may actually be better for MPGs to use the AC. |
| | #23 |
| Resident Conservative Join Date: Mar 2009 Location: Austin, TX
My Car: 2009 Prius Model: Package: Base Thanks: 1
Friends: 3 | Richard makes a good point. The battery system is cooled from cabin air, so if it's way too hot in there, the battery could be throttled to prevent overheating. I always make the following recommendations for the hot summer months. These are universal for all cars. (adapted for the Prius here) Get your windows tinted! It really helps. Get a shade for your front windshield. It really helps. Use it religiously. It has a secondary benefit of keeping harmful rays off of your dash and other parts of the car. Crack a window. Hot air needs to be able to escape the cabin. Park in the shade where you can. When starting a drive, roll down the windows to let the hot air in the cabin vent out. Leave them open for a minute or two once you start moving. Turn the AC on and set it to vent/fresh air. Run it on fresh until the cabin air is cooler than the outside air. Roll up the windows when the AC has cooled down enough. After a few minutes, turn on recirculate so that the AC is only working to cool down the cabin air, which should now be cooler than the outside air. With the Prius, at this point, edge the temperature setting up until you are no longer comfortable. One or two degrees lower should be the optimum setting for you.
__________________ Wealth is the product of man's capacity to think. Who is John Galt? Last edited by Frayadjacent; 07-02-2009 at 01:19 PM. |
| | #24 |
| Senior Member Join Date: Apr 2009 Location: Nashville, Tennessee
My Car: 2009 Prius Model: N/A Package: #2 Thanks: 45
Friends: 5 | But, but, I want to be comfortable! |
| | #25 |
| Ancient and decrepit Join Date: Apr 2009 Location: Crestview/North Florida
My Car: 2009 Prius Model: N/A Package: #6 Touring Thanks: 160
Friends: 55 | |
| | #26 |
Friends: 5 | Oh, you guys-----just roll your window down and hang your arm out the window....... ha ha |
| | #27 |
My Car: 2007 Prius Model: Package: #7 Thanks: 7
Friends: 0 | Tint the windows! We did our Subaru with black leather interior and it made a huge difference. We have done the Prius with some cheap DIY stuff. It cuts down the heat gain dramatically. We also use a silver windshield cover while parked,, as we usually travel with the dog. Icarus |
| | #28 |
Friends: 55 | My next project! |
| | #29 | |
| awaaay Join Date: Mar 2005 Location: Vancouver, BC
My Car: 2004 Prius Model: Package: Base Thanks: 46
Friends: 63 | Yes, but be aware that when you park under a tree, you may get little droplets of sap all over the car. Quote:
| | #30 |
| Prius Aficionado Join Date: Apr 2008 Location: Union City, CA
My Car: 2009 Prius Model: N/A Package: #5 Thanks: 26
Friends: 4 | Don't dial a high temp (i.e. 80F) into auto setting ... could hurt your FE on a cool morning. see this ... Climate Temp Setting Seemed to Reduce Fuel Economy with Auto Turned Off |
| a or c, efficient, mode |
| "Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors? | bob749prius | Gen II Prius Technical Discussion | 19 | 08-30-2009 08:18 AM |
| efficient headlights | Flying White Dutchman | Gen II Prius Modifications | 23 | 11-18-2008 10:59 AM |
| Efficient Vehicles | skruse | Gen II Prius Main Forum | 0 | 05-04-2008 06:39 PM |
| Prius less efficient at highway speed than two-mode hybrids? | sola | Gen II Prius Technical Discussion | 11 | 06-15-2006 10:20 PM |
| Prius 1/3 as efficient... | texassalsa04 | Gen II Prius Main Forum | 5 | 01-10-2006 12:38 PM |
