This is a discussion on Most efficient A/C mode? within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Setting the climate control to 80F causes the engine coolant to flow and heat up the heater core... Thus warming ...
Old 07-10-2009, 03:07 PM   #31
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
Default Re: Most efficient A/C mode?
Setting the climate control to 80F causes the engine coolant to flow and heat up the heater core... Thus warming up the air... and cooling down the engine... Thus forcing the engine to run all the time to generate heat...
Bob64 is offline
Old 07-10-2009, 07:23 PM   #32
ETP
Ancient and decrepit
ETP's Avatar
Friends: 57
Originally Posted by cycledrum View Post
Don't dial a high temp (i.e. 80F) into auto setting ... could hurt your FE on a cool morning.
see this ...
Climate Temp Setting Seemed to Reduce Fuel Economy with Auto Turned Off
yep! I wondered what that burnt wire smell was.
ETP is offline
Old 07-10-2009, 08:15 PM   #33
Rangerdavid
Rangerdavid's Avatar
Friends: 25
Originally Posted by patsparks View Post
Pussies!
I drove across the Nulabour Plain in my Prius, the temperature outside was a lovely 48 degrees celsius. (118.4 f)
Yeah, but there was no humidity!!!
never mess with an aussie when it comes to heat
RD
Rangerdavid is offline
a or c, efficient, mode
"Doggie in the car Mode"-- READY Mode, AC On & Remotely Lock doors? bob749prius Gen II Prius Technical Discussion 19 08-30-2009 08:18 AM
efficient headlights Flying White Dutchman Gen II Prius Modifications 23 11-18-2008 10:59 AM
Efficient Vehicles skruse Gen II Prius Main Forum 0 05-04-2008 06:39 PM
Prius less efficient at highway speed than two-mode hybrids? sola Gen II Prius Technical Discussion 11 06-15-2006 10:20 PM
Prius 1/3 as efficient... texassalsa04 Gen II Prius Main Forum 5 01-10-2006 12:38 PM
