This is a discussion on Climate Temp Setting Seemed to Reduce Fuel Economy with Auto Turned Off within the Gen II Prius Fuel Economy forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I always run with the fan set to 1 or 2 or off. I don't trust auto....
Old 07-11-2009, 06:07 PM   #11
Shawn Clark
Shawn Clark's Avatar
Default Re: Climate Temp Setting Seemed to Reduce Fuel Economy with Auto Turned Off
Shawn Clark is offline
Old 07-11-2009, 07:21 PM   #12
cycledrum
Prius Aficionado
cycledrum's Avatar
If running A/C at low fan setting, is it less strain on system to select recirculated air? (since it won't have to cool hot outside air)
I know this has been asked in other threads. My '88 pickup owner's manual says recirc should be used when cooling cabin down, then use outside air.
I know the Prius auto system uses recirc for low temp settings, but switches to outside air at higher temp settings.
cycledrum is offline
Old 07-21-2009, 12:29 AM   #13
alanh
There's actually several degrees of "auto" -- air conditioning available or not, fan speed, and temperature. Each can be turned on or off individually -- in full auto, the computer controls all of them.
1. Manual fan speed: set a fan speed.
2. Manual A/C: deselect A/C button, A/C won't come on.
3. Manual temperature: set the temp all the way down to "LO", heat won't come on.
If you do all three you get a "vent" setting where it doesn't do anything but blow the fan at the speed you select. No heat, no A/C.
alanh is offline
auto, climate, economy, fuel, reduce, setting, temp, turned
"Auto" setting on climate control not working properly krblack42 Gen II Prius Care, Maintenance and Troubleshooting 0 12-10-2008 03:07 PM
Auto/AC default setting DanPatch Gen II Prius Technical Discussion 11 12-01-2008 08:35 AM
Auto Industry FINALY Supporting Fuel Economy Amendment jewelerdave Prius and Hybrid News 9 06-18-2007 10:14 PM
EPA to overhaul fuel economy ratings-reduce estimates for popular hybrids hb06 Prius and Hybrid News 15 12-08-2006 03:49 PM
Best Auto Incentive: Fuel Economy Rancid13 Prius and Hybrid News 5 10-06-2006 12:39 PM
