This is a discussion on I don't understand the passive alarm within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Here is my problem, I do not have a garage (gasp!) and I thought with the passive alarm set, if ...
Old 08-06-2005, 03:44 PM   #1
mswhealer
Default I don't understand the passive alarm
Here is my problem, I do not have a garage (gasp!) and I thought with the passive alarm set, if I forgot to lock the doors, if a door was opened the alarm would go off. So I did the little dance and activated the passive alarm, I thought. However, I guess I don't understand how it works. I shut the doors, waited the 14 or 30 seconds and opened a door.... nothing. I tried it with the SKS close by and then far away. But today when I was loading groceries into the car with the doors open, it went off. Is something screwy or am I just not understanding the way the passive alarm works? I have an 05 package 6 and the active alarm is activated. Can someone help me understand what exactly the passive alarm does and how to make it work?
mswhealer is offline
Old 08-06-2005, 04:12 PM   #2
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
No it doesn't auto lock. What it does is if you unlock the car and don't open the door, it will relock the car for you.
The alarm will activate once all the doors are closed and locked. Once the immobiliser light starts blinking, it's activated. Unlocking the door from inside, forcefully opening the door or hood or disconnecting then reconnecting the battery will sound the alarm.
Tideland Prius is offline
Old 08-06-2005, 05:51 PM   #3
mswhealer
Okay, that's helpful. So what I hear you saying is, just forgetting to lock the door and then having a door regularly opened... like as in someone walking down the street decides to open my door and take my cell phone that I left sitting on the front seat after I forgot to lock the doors, will not sound the alarm even if the passive mode is on? What is the point of the passive alarm then?
Old 08-06-2005, 06:07 PM   #4
wrprice
No, there are two "passive" features.
1. Passive re-lock. If you unlock the car without opening a door in 30 seconds or so, the car will re-lock the doors automatically. I believe this is active on all packages, but someone can correct me.
2. Passive alarm (off by default). If you have the alarm feature, there's a dealership-programmable option for a passive mode (it's in active mode from the factory). In passive mode, the alarm will arm 0, 14, or 30 seconds after the last door is closed -- regardless of whether they've been locked. The time is set by the dealer's scan tool as one of those 3 options (or OFF).
The OP's situation sounds confusing. It should be that simple.
1. Close all doors but do not lock (fob, SKS, or otherwise).
2. If you have SKS, remove the fob from within 30 ft.
3. Wait 45 seconds (to be sure).
4. Open an unlocked door and hear the alarm activate.
I know this works because I had them enable the passive option and then opened my car door at the gas station after refueling. Having the SKS nearby, for me, doesn't deactivate the alarm if the alarm was set passively (with doors unlocked).
Get Firefox and take back the Web!
wrprice is offline
Old 08-07-2005, 02:15 AM   #5
Tideland Prius
Friends: 23
No. 1 is on all Toyotas with keyless entry.
Thanks for the clarification wrprice.
sorry, mswhealer. I guess what I was describing was passive-relock and active alarm lol.
Now I understand =).
Is there any use for passive arm then? I would think it'd be annoying to have the alarm go off because you left the doors unlock and you open them thinking the alarm isn't set.
Old 08-07-2005, 10:30 AM   #6
mswhealer
Default Re: I don't understand the passive alarm
It makes total sense with my problem. I don't have a garage and sometimes forget to lock my car. Someone has taken to checking my car and taking stuff out of it. Won't he/she be surprised when he/she goes to do this and the alarm goes off. I guess I could remember to lock the car, but despite my best efforts that doesn't always happen.
Old 08-07-2005, 01:14 PM   #7
Tideland Prius
Friends: 23
Ahh okay, makes sense. It won't work for me cause I wash the car with the doors unlock heh. So if the car's unlock and the alarm is set, how do you disable it before you enter?
Old 08-07-2005, 03:58 PM   #8
wrprice
If the doors have been shut for 30 seconds or more while unlocked and the Prius is OFF, I have to remember to press the unlock button on the fob or risk Yeesha blasting her horn at me. I don't always remember, but she does, which is reassuring. :-)
wrprice is offline
Old 08-09-2005, 04:30 PM   #9
DanMan32
You can set or unset the passive feature without the scantool. I had the dealer set it, they charged me $30 and took 2 hours to do it, so they said. Found it annoying, and wanted it off, but didn't want to pay $30 to have it undone. Found a dance in the repair manual. I believe I posted it around here somewhere.
Note to self: write letter to dealer, CC service manager, general manager, and owner.
DanMan32 is offline
Old 10-28-2005, 01:55 AM   #10
kk6yb
kk6yb's Avatar
[snapback]114960[/snapback]
I had the dealer set the passive feature also, and I hate it. It alarms when it shouldn't and doesn't lock when it should. I tried the dance but can't get it to respond. Does the "dance" work for the '05?
I did get the reverse beep disabled, that I like. I've never put gas in the car, I like that too. Of course, that won't last too much longer (odo: 330).
Gary
kk6yb is offline
Prius Alarm Passive Mode DanMan32 Knowledge Base Articles Discussion 0 12-31-2006 11:46 PM
How do you set and configure passive alarm mode? Sean05Opt6 Gen II Prius Audio and Electronics 0 08-15-2005 08:23 PM
passive alarm insurance discount ? syncmaster Gen II Prius Main Forum 3 07-14-2005 03:46 PM
Passive alarm question ScottY Gen II Prius Main Forum 9 07-14-2005 03:21 PM
Security Alarm too quiet? Does alarm trigger shut down? crtolin Gen II Prius Main Forum 4 06-20-2005 05:09 PM
