This is a discussion on Prius Performance Query within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally posted by Brian K @Oct 24 2005, 07:30 PM OK, now that you all have discussed the stock Prius, ...
Old 10-24-2005, 08:03 PM   #11
agill
agill's Avatar
Model: II
Originally posted by Brian K@Oct 24 2005, 07:30 PM
OK, now that you all have discussed the stock Prius, I'll go in another direction.
As far as I know Prius now holds the land speed record for a hybrid. That may have changed without my notice, but if so it just changed recently.
Toyota added more cells to the battery to goose the voltage and I don't know what else, probably rewrote a few lines of the software too. Anyway, they got 130 mph out of it.
[snapback]145040[/snapback]
Thats cool
Just wondering why the US brochure does not specify the max speed, while the UK brochure does. Guess someone did not think about it.
agill is offline
Old 10-24-2005, 08:09 PM   #12
priusham
Location: Michigan - land of everlasting snowflake icon!
Frankly, if you are worried over maximum speed, I'm not so sure that that the Prius is the right car for you. No offense! It really is not the car for everyone.
If you do choose to go through with purchasing a Prius, you'll soon enough get Prius MoJo and quit stressing about maximizing your speed and start stressing over maximizing your MPG.
priusham is offline
Old 10-24-2005, 08:15 PM   #13
engunneer
Prius Hacker
Probably a liability thing in the US. There isn't anywhere I know of that you're allowed to go over 100mph. The fastest Highway I've been on was 80. Just imagine the lawsuit...
Person: "The brouchure said I could go, over 100"
Judge: "The speed limit sign said 60!"
Person "But the brochure! It's Toyota's Fault"
Judge: "I see... well, no more Toyotas in the US. You are free to go. Court Adjourned"
Isn't the US legal system great?
engunneer is offline
Old 10-24-2005, 11:07 PM   #14
rutafox
[snapback]145059[/snapback]
There is no speed limit... it's just posted how fast you can drive for free. Anything over that just costs more.
rutafox is offline
Old 10-24-2005, 11:37 PM   #15
agill
agill's Avatar
Model: II
[snapback]145055[/snapback]
Its not like i am really "worried" about max speed. As i had mentioned in the opening post, it was just out of curiousity because i had seen the posted upper speed of the Prius in the UK brochure, but not in the US brochure. And i am quite sure i have made the proper choice by opting for the Prius. I am not much of a speeder myself, and i quite agree with you that i will pay close attention in achieving max MPG once i start driving the Prius. In fact even now I try not to go over 75 since it reduces my mileage.
Ordered a 2005 in Sept, 2005.
Took Delivery of Black 2006 Pkg #3 on Jan-24-2006
Enjoying driving my "Black Beauty" ever since....
agill is offline
Old 10-24-2005, 11:41 PM   #16
Wayne
Wayne's Avatar
[snapback]145141[/snapback]
I personally wouldn't even go 75, unless that's the speed limit in your state. My recent mileage tests showed almost a 1:1 relationship between MPG and MPH at highway speeds, so driving 5 MPH less will net you 5 MPG more. Driving 10 MPH less is even better!
Wayne is offline
Old 10-25-2005, 01:39 AM   #17
oly_57mpg
oly_57mpg's Avatar
Originally posted by PeteB+Oct 24 2005, 05:56 PM--><div class='quotetop'>QUOTE(PeteB @ Oct 24 2005, 05:56 PM)</div>
The software limits the top speed to 106 mph (99 mph for the Classic) to protect the electric motors and ICE from exceeding an rpm limit specified by Toyota engineers.
Is there a record of that in the FSM? I've taken mine up around that range easily...
Originally posted by PeteB@Oct 24 2005, 05:56 PM
European Prius speedometers tend to be about 7% over reading (e.g. at a true 70 mph, speedo reads 75 mph).  European law dictates they MUST over read by a certain amount (not 7% though), but this error rate is common in cars over here.  Several owners have reported seeing 113-114 mph indicated which equates to about 106 with this error factor taken in account.
114+-3 MPH on the spedo is about right...
Because it is an artificial limit, the car produces strong acceleration right up to its top speed.
and then some...
<!--QuoteBegin-PeteB
It seems European spec Prius have a stiffer suspension than US models, and they are reported to be acceptable stable at this speed.
The 05 USA model handles just fine at high speeds. Better than most US car manufacturers that I have driven.
oly_57mpg is offline
Old 10-25-2005, 01:56 AM   #18
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
I think this is what Brian K. was refering to.
http://www.toyota.com/hybridsynergyview/20...bonneville.html
Dosen't sound like they did all that much to it. With more extensive modifications it could (will) be much faster.
tumbleweed is offline
Old 10-25-2005, 04:40 AM   #19
Strong Bad
Strong Bad's Avatar
The Bonneville Prius's modifications were limited to the inverter, HV ECU, final drive (differential) and ICE...no battery modifications were made. Actual top speed during the week was 139.xxx mph , record is at 134.xxx mph by the Prius. There is to my knowedge only 1 other Prius in the US capable of those speeds, all others are limited to 106 by the ECU. That speed is limited purely by the ECU and not physics ie: more speed is there, the ECU just won't let it happen
Strong Bad is offline
Old 10-25-2005, 12:05 PM   #20
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
[snapback]145180[/snapback]
You can read more about the mods at
http://hybridcars.about.com/od/news/...slandspeed.htm
aaf709 is offline
CAN Query / Response PIDs Dan. Gen II Prius Technical Discussion 10 08-15-2007 02:24 AM
Yet Another Bluetooth Phone query jfschultz Gen II Prius Audio and Electronics 2 07-19-2006 01:41 PM
TAX QUERY PetersPrius Gen II Prius Main Forum 1 11-10-2005 11:38 PM
Eficiency Scenario Query PhilCase Gen II Prius Fuel Economy 5 05-22-2005 02:42 AM
Security system query knowledgeseeker Gen II Prius Main Forum 1 05-02-2004 12:42 AM
