This is a discussion on Gasoline Quality Requirements for Prius within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I won't worry about the brand - like everyone here said - they are all very similar. But I do ...
Old 02-09-2006, 01:54 PM   #21
yauman
I won't worry about the brand - like everyone here said - they are all very similar. But I do worry about where you are buying the gasoline. Buy from a gas station that is busy and has a quick turn-over of their stock. Stale gas sitting in the underground tank for a long long time is what is bad.
yauman is offline
Old 02-09-2006, 01:54 PM   #22
Rancid13
Cool Chick with a Black Prius
Rancid13's Avatar
Package: #8
Originally posted by Frank Hudon@Feb 9 2006, 11:50 AM
better yet methane from dog doo, decomposted and captrue the methane and compress it and use a gas mixer carb to burn it in your Prius. I won't bother but if you want to spend your weekends picking up dog doo go for it Bob
[snapback]206440[/snapback]
One could hang out at the local dog parks and offer to collect the dog-doo so the owners don't have to. Could get a lot of it that way if you pulled an 8-hour shift doing that.
Rancid13 is offline
Old 02-09-2006, 01:58 PM   #23
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
[snapback]206444[/snapback]
That's what I do. About 95% of the time I fill up, I'm using the same station and most of the time the same pump.
aaf709 is offline
Old 02-09-2006, 02:37 PM   #24
tomdeimos
Originally posted by SomervillePrius@Feb 9 2006, 11:12 AM
I don't understand how you can compare FE this way! There is simply too many varients!
A car gets different FE tank to tank! Look at the data over at greenhybrid.com as a reference. Big factors are of course how many long/short trips you do but the temperature makes a big difference as well and the drop you are seeing could simply be the temperature getting colder (as your good tank was in september).
So no, I don't see how 3 "random" tanks of gas proves anything. If you used 1 gas station for several tanks and then (the next year) used another one for the same period then maybe you could tell if there was a difference
[snapback]206327[/snapback]
This is true only for tankfuls. That is why you have a display. All you need to check for is temp wind, etc that are obvious variables, and test with car warm. Gas varies far more than the other variables. Just read your mpg meter!
Forget looking at tank averages. Don't bother. The important thing is the instant readout, at a known place and speed, and the average over a short 15 to 30 mile test loop under conditions you can easily repeat.
For me Shell works best every time. Exxon and Mobil are close enough I can't say they are worse.
But I've had other brands that cut my mpg by over 8 mpg. This is very visible just driving at a constant speed on level road, on a day there is no wind.
Temp variations you can calculate or use Wayne's palm device to compensate for. You can use that to correct for wind too if it is steady and from a known direction. Easier to pick days where temps match and wind is negligible.
The instand readout is especially useful if you can use your nav or something to know when road is level. Bad gas for me was reading under 50 mpg at 55 mph no matter what I did!
Good gas at that speed is virtually always up toward 60 or more, unless really cold outside.
tomdeimos is offline
Old 02-09-2006, 06:27 PM   #25
jayman
Originally posted by Frank Hudon@Feb 9 2006, 11:31 AM
wrecked my ankle, in physio trying to get to walking on it again.
[snapback]206331[/snapback]
Frank:
Oops sorry to hear that. I'm sure missus is looking after you.
I wasn't goofing off today too much. I always bring along my personal notebook computer, which has a Rogers Wireless internet card in it. The tower is on the next building, so I can usually expect DSL speeds.
jay
jayman is offline
Old 02-09-2006, 06:29 PM   #26
jayman
Out of alturistic feelings and perhaps too many wine samples from the couple down the hall, I hearby offer all my cat's used litter. Feel free to pick it up anytime. Please.
jayman is offline
Old 02-09-2006, 07:57 PM   #27
Frank Hudon
[snapback]206680[/snapback]
got 3 don't need another.
Frank Hudon is offline
Old 02-09-2006, 08:26 PM   #28
HNDRICKS10
My Car: 2002 Prius
I have read somewhere that Toyota recommends the usage of top tier gasoline products in their autos.
According to what I read they consider Conoco and Shell to be the ones to use.
Today I filled up at a Conoco station in Northern Minnesota and noticed the same statement
posted above their pumps. They also included the Honda brand
Months ago I decided to test out this idea on a set route for 100 miles each fillup.
I am a Courier so putting on 100 miles easy and I do a defined route each day.
I drive at least 250 to 300 + miles each day. so fillups come quick.
I can attest to the fact that using Shell and Conoco will improve your mileage slightly.
I realized a improvement of 3 to 6 miles mpg.
As a futher test I filled up using Super America gas one day, my mpg dropped 4 mpgs
the next day( after driving 325 miles) i filled up at Conoco using their 90 OCTANE FUEL
MY MILEAGE JUMPED BACK UP TO THE PREVIOUS TOP TEIR GAS LEVELS.
I own both a 2002 and a 2005 Prius and have noticed a difference in both cars using top
teir gas. The 2005 is still being broken in at 8000 miles, the 2002 has 60,000 miles on it.
HNDRICKS10 is offline
Old 02-10-2006, 10:18 AM   #29
jayman
[snapback]206728[/snapback]
Frank:
I meant used poopy cat litter, not the actual cat. You can pry BooBoo out of my cold dead fingers.
jay
jayman is offline
Old 02-10-2006, 05:00 PM   #30
richard schumacher
Destination: Eschaton
Top Tier gasoline website http://www.toptiergas.com/retailers.html
If this is true it's just one more reason not to buy from those Exxon-Mobil b@stards.
richard schumacher is offline
Consumer Reports: Toyota quality slipping, Ford quality improving JackDodge Other Cars 20 10-17-2007 04:29 PM
15K maintenance requirements for 2006 Prius satsuke Gen II Prius Care, Maintenance and Troubleshooting 6 03-17-2007 08:54 PM
New Passport Requirements for International Travelers hb06 Fred's House of Pancakes 1 11-18-2006 05:27 PM
list of tax credit "requirements lynnno1 Gen II Prius Main Forum 4 05-28-2006 08:16 PM
What speakers will satisfy impedance requirements of amp? Chucka Gen II Prius Audio and Electronics 0 06-23-2005 12:38 PM
