This is a discussion on New Prius pulls to the right within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have just had my Prius for about 3 weeks and notice two things: 1. When I am driving, the ...
Old 02-24-2006, 10:01 AM   #1
actuary32174
1. When I am driving, the car pulls to the right. I mentioned this to the dealership and they are having me come in for an alignment. Has anyone else experienced this?
2. When the gas engine comes on, the car kind of "shudders" and then runs fine. Again, anyone experience this>
Thanks for the help
actuary32174 is offline
Old 02-24-2006, 10:12 AM   #2
pshady
On #1, are you sure the road isn't slightly inclined to the right (most are for drainage purposes)?
On #2, sometimes when the car is "cold" it will shudder slightly, but it definitely shouldn't be a huge shudder. I would have it looked at in either case.
mike
mwang.org
Thanks for the help
[snapback]215819[/snapback]
pshady is offline
Old 02-24-2006, 10:21 AM   #3
M. Oiseau
6sigma this
M. Oiseau's Avatar
See this thread for suggestions:
2006 PULLS TO THE LEFT ON BRAKE, MCHANICAL ISSUE ON NEW 2006
M. Oiseau is offline
Old 02-24-2006, 11:56 AM   #4
Wildkow
Package: #8
Friends: 11
It's all Bush's fault!
Wildkow is offline
Old 02-24-2006, 12:32 PM   #5
unruhly
unruhly's Avatar
I just got back yesterday from having my alignment checked. I've got 1200 miles on my new 2006.
The car did not pull, but the steering wheel was not centered when going straight.
When the service writer returned my car to me, he said that the toe was out of spec. Both tires were toed-out.
In case you don't know, there is toe-in and toe-out. Toe out = \--/ Toe in = /--\.
He also mentioned about how the sensors have to be reset after an alignment. There is a yaw sensor and the computer uses the readings of this sensor and the position of the steering wheel to determine Vehicle Stability Control.
So a warning to all. Don't get an alignment somewhere without having the sensors reset.
06 Black Pkg-7, Dk Grey Interior. Took delivery 02/02/06.
To date: 54.1 MPG avg.
Best trip: 350 Miles R/T at 61 MPG.
unruhly is offline
Old 02-24-2006, 01:18 PM   #6
KTPhil
KTPhil's Avatar
The spec allows zero toe, which will make the car wander on the freeway. You want a little toe-in, within spec.
Be sure you align the steering wheel to the HORIZON, not the DASH. The dash is canted and not square with the horizon.
KTPhil is offline
Old 02-24-2006, 01:24 PM   #7
200Volts
You want a LOT of toe in for the front. It won't hurt mileage.
I've had 3 alignments and it tracks best when the front toe in was 50-100% of allowable toe IN.
Have them check the rear toe in-out as well. They can order shims if it is out of spec. I had this corrected and is now almost zero toe-in or out (I had the right toe out exceeding specs).
200Volts is offline
2006 PULLS TO THE LEFT ON BRAKE icemanjrperu Gen II Prius Main Forum 39 03-12-2008 03:10 PM
Toyota Pulls Anti-Fresno Prius Ad Arroyo Prius and Hybrid News 5 11-17-2007 03:31 PM
my 07 steering off center and pulls to the right bad CheapChic Gen II Prius Care, Maintenance and Troubleshooting 4 03-03-2007 08:48 PM
GM Pulls Plug on '08 Line of Cars Tideland Prius Fred's House of Pancakes 8 03-22-2005 01:50 PM
my 07 steering off center and pulls to the right bad CheapChic Gen II Prius Main Forum 0 12-31-1969 07:00 PM
