This is a discussion on Need help with Homelink for garage door within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just can't seem to get the homelink to work on my garage doors. I have gotten it to work ...
Old 02-26-2006, 12:51 PM   #1
fredmertz
fredmertz's Avatar
I just can't seem to get the homelink to work on my garage doors. I have gotten it to work on my other cars but for some reason it doesn't work on the Prius.
I have a Genie mechanism with rolling codes. I followed the steps in the manual by using the handheld opener then by using the lear button on the Genie unit.
I also found some other instructions on this site that I followed but could not get it to work.
The light on my %1 homelink button flashes fast now but doesnt seem to connect to the Genie. I tried the other buttons too, but was unsuccessful.
I know this problem is vague, but does anyone have a tip or trick that could possibly help me?
fredmertz is offline
Old 02-26-2006, 01:06 PM   #2
mssmith95
"I think my Dad's gone CRAZY!"
mssmith95's Avatar
I just programmed mine for the first time yesterday. It took a few tries, but it finally worked. These are the steps I followed:
1. I tried to program it as a rolling code model, just like the instructions said...but it did not work
2. I then erased (accidentally) all of the codes from the garage door...so that all of my other remotes did not work as well
3. I then tried to program it again, and it worked.
My only conclusion is that erasing the old codes somehow fixed the issue. I used to install car alarms, and found this same issue with the car alarm remotes. Although the alarm was supposed to accept more then 2 remotes, sometimes it would get "stuck" and needed to be competely reset before I could program the new one.
To program it, I did the following:
1. I pushed the learn button on my opener (note: I have a Craftsman, and all you have to do it push the learn button once...if you hold it down it erases all of the codes after 6 seconds...yours may be different...but may have a similar reset feature).
2. Within around 10 seconds, and with the car in the driveway, around 10 ft in front of the garage, I pushed the left-most homelink button 2 times. This did not activate the garage, so I pushed it one more time and the garage blinked, indicating it had accepted the programming.
3. Tested it...unlike the garage door remote, you have to hold the homelink button for a second or two before the garage activates...there is a longer delay then with my remote.
4. I reprogrammed my other remotes by pushing the learn button again and then pushing the button on the remote.
Let me know if this helps!
"mssmith95" stands for Mike / Suzy Smith 1995 (year we were married) - and Mike's got the Prius </span>
2006 Silver Package #7
<span style="color:#663300">Sigma Hood Deflector, Metro Moldings, Coastal EV,
Rear Bumper Protector, BT Stiffening Plate
ABS Prius Hood MFD Shade, Mud Flaps,
Cargo Net, No wheel Rings
mssmith95 is offline
Old 02-26-2006, 01:46 PM   #3
fredmertz
fredmertz's Avatar
I tried that procedure, but to no avail.
I did assume that you meant to say "press the learn button on the main unit" after you erased all your codes. I proceeded to have it learn my other cars and handheld remote which worked for them.
I wonder why the Prius is different. Anyone?
I'm at a loss. I have been meaning to replace my chain driver garage door openers with belt drive units. Maybe its time I do that.
Old 02-26-2006, 05:05 PM   #4
AlphaTeam
AlphaTeam's Avatar
You know mine was a pain in the butt also.
It did work in the end.
let me find the post that helped me.
EDIT:
Ok here it is.
But it was this post in particular.
Originally posted by anagle09@Dec 11 2005, 09:03 AM
This might also seem like an obvious one, but I messed it up.  While programming, like the manual says, make sure the batteries in the garage door opener remote are facing away from the homelink.  Mine wouldn't work until I faced the batteries away from the homelink.
[snapback]171704[/snapback]
I have no idea why the batter thing would matter, but I farted with mine for a couple days and when I turned the battery away it did the trick?????????????
AlphaTeam is offline
Old 02-26-2006, 05:25 PM   #5
dreichla
After programming, the one thing I've noticed is I have to press the button for several seconds before my garage door opens.
dreichla is offline
Old 02-26-2006, 06:03 PM   #6
walt
walt's Avatar
I had just about given up trying to follow the directions in the manual for my '06 prius. Then I went to the garage door opener's web site - downloaded their "how to program" section - found a couple "minor" differences from what the prius manual said - followed the opener's directions - and bingo, it works now. As mentioned above, I have to hold my prius opener button for two full seconds to get the door to open/close, and the original opener required only an instantaneous touch of the button to function, but I am slowly getting my fingers retrained.
front dome LED x 3, door edge LED x 2, rear dome LED
alloy wheel trim mod (free)
rear wiper lift mod (free)
walt is offline
Old 02-26-2006, 09:08 PM   #7
fredmertz
fredmertz's Avatar
Well, I tried every possible combination including holding my left foot up in the air while rubbing my belly. That didn't work either.
I ended up installing all new belt drive units in the garage. The chain drive units were on their last leg anyway and I was concerned about the chain snapping and crashing on to one of the cars.
After installing the new units, I pressed the learn button and the Homelink worked like a charm.
It was much more work and money than I expected for a leisurely Sunday but in the end, its all good.
Thanks for all the great advice.
Old 02-26-2006, 09:23 PM   #8
hdrygas
[snapback]217105[/snapback]
Did you replace the batteries?? You need to hold down the button on the remote for a "long long time" and if your battery is the least bit down you will not program the car. Follow the directions very correctly, get help to do this.
hdrygas is offline
Old 02-27-2006, 09:45 AM   #9
fredmertz
fredmertz's Avatar
[snapback]217116[/snapback]
Yes, I replaced the batteries, tried different remote units, tried different main units, tried holding the batteries away from the homelink system, reset the homelink, reset the main system(s), researched the Homelink website and followed all other directions, researched the Genie site and followed all of their directions, researched this site and tried all the variations recommended. Bottom line, there seemed to be some compatibility issue.
I replace the units and was able to setup the Homelink in 2 minutes with the new units. I am good to go.
Once again, thanks for all the advice given on this site. Everyone that frequents this site seems to be very personable and helpful. You don't find that often when people don't have to show their true identity.
Old 03-19-2006, 06:20 PM   #10
yuanja
yuanja's Avatar
i agree, i have a genie and it does not do anything. my other car works just fine with the genie garage door opener.
i first left the car in the drive way - but no way. maybe distance. so i parked the car just underneath the garage opener motor.
does my car need to be in running mode? i simply press power (w/o my feet on the break) and the auxilary power came up. my programing attempt was based on this mode.
next, i've followed the instruction on the manual:
located the learn button on my garage door, press it. a light start to flash on the opener.
then, i went inside my car, press the first button twice. a red light blinks once each time i pressed. i then press the button the third time. nothing happens. DOES THE LIGHT NEED TO BE FLASHING?
anyways, i am about to give up. i wonder if toyota's service reps is any help. wish me luck.
yuanja is offline
Hatchback VS. Garage Door (Garage Door Wins) - Advice needed kkirk2 Gen II Prius Main Forum 29 01-28-2009 01:33 PM
Garage door opener Uh-Oh Gen II Prius Main Forum 11 07-04-2005 06:49 PM
Homelink issue. Two Prius. Can both operate garage door? Ray Moore Gen II Prius Care, Maintenance and Troubleshooting 10 05-17-2005 04:23 PM
HomeLink for Garage Door Opener braitman Gen II Prius Care, Maintenance and Troubleshooting 6 12-30-2004 02:41 PM
Garage Door Opener Canuck Gen II Prius Audio and Electronics 2 09-08-2004 11:38 PM
