This is a discussion on Braking. What happens after the battery is full? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by rbarline How can an ICE engine use up any charge? I don't think ICEs can do that. ...
Old 10-15-2009, 04:24 PM   #11
Default Re: Braking. What happens after the battery is full?
Originally Posted by rbarline View Post
How can an ICE engine use up any charge? I don't think ICEs can do that. There must be a better explanation.
MG1 spins the ICE as a big air pump. Moving air creates friction, which burns up energy as heat.
Old 10-15-2009, 05:11 PM   #12
David Beale
David Beale's Avatar
Tom is correct. It doesn't "waste fuel". It DOES use friction brakes more if you are applying the brake (fully friction brake once you reach what the car considers full allowed charge). It also uses EV further up the accelerator pedal travel. The engine is spun with no fuel injected to "dump" excess charge.
Next time you are descending a long hill and are using "B", try applying the accelerator. The engine RPM will -decrease-. Very weird, but correct action.
David Beale is offline
Old 10-15-2009, 07:26 PM   #13
M8s
Retired and Lovin' It
M8s's Avatar
Perhaps you know better than me, but I thought that the MG1 spun the engine. That work puts a load on the MG1 and the MG1 burned up the excess electrons that way.
M8s is offline
Old 10-15-2009, 07:35 PM   #14
fuzzy1
Model: II
That may be a semantic difference.
The ICE is configured for maximum drag as a vacuum pump / air compressor, the combination of both MGs spins it, and the wasted heat energy goes out the ICE exhaust.
fuzzy1 is offline
Old 10-15-2009, 10:51 PM   #15
Exactly what I said. I suppose you explicitly stated that the electric motor uses electricity, but that seems fairly obvious.
battery, braking, full
Never witnessed full battery ('08) amnon Gen II Prius Main Forum 26 12-13-2007 12:28 AM
Charging HV Battery to MFD full SOC Presto Gen II Prius Main Forum 10 08-29-2006 11:02 AM
Regenerative braking and full battery whodat Gen II Prius Technical Discussion 20 07-22-2006 01:00 AM
Battery Status Display; Never full? Here's why. RobertO Gen II Prius Main Forum 20 08-15-2005 09:06 AM
Is Full Green Battery Bad? shocker Gen II Prius Main Forum 12 10-08-2004 04:34 PM
