This is a discussion on Radio Reception within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have a 2006 package 6 and the radio reception is terrible. It is so bad that if I park ...
Radio Reception
Old 06-22-2006, 07:45 PM   #1
goody
Arrow
I have a 2006 package 6 and the radio reception is terrible. It is so bad that if I park close to a building I will lose the radio station. I was wondering if this is normal for the Prius or if something is wrong with mine. I live three hours away from my dealer, so I don’t want to take it that far just to have them to tell me nothing is wrong.
So is this normal reception for the Prius?
goody is offline
Old 06-22-2006, 07:56 PM   #2
B Rad
B Rad's Avatar
<div class='quotetop'>QUOTE(goody @ Jun 22 2006, 06:45 PM) [snapback]275531[/snapback]</div>
I was wondering if this is normal for the Prius or if something is wrong with mine. So is this normal reception for the Prius?
I can only tell you that I live way out in the boondocks and my Prius radio gets much much better reception than my previous Jetta.
B Rad is offline
Old 06-22-2006, 11:26 PM   #3
Three60guy
Package: #8
Mine is quite sensitive.
You do realize you can take your Prius to ANY Toyota dealer don't you? You are not obligated to take your Prius back to the dealer you purchased it from. I personally have taken mine to two different ones depending on my schedule.
Have a close Toyota dealer check that radio out.
Cheers
Three60guy is offline
Old 06-23-2006, 01:15 AM   #4
bsd43
bsd43's Avatar
It's probably your specific car. I get pretty good reception. I think our "fuba-style" antennas are amplified, since it's shorter than 1/2 wavelength.
bsd43 is offline
Old 06-23-2006, 01:28 AM   #5
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
You may have some sort of radio or antenna problem. Why not find a place where reception is poor and then have a friend put their car in the same place and see what difference there is.
I have found the Prius radio is about the same as the one in my previous car and it may be a bit better than the one in my pickup truck.
tumbleweed is offline
Old 06-23-2006, 11:30 AM   #6
richard schumacher
Destination: Eschaton
Is the external antenna installed? There should be 16" of black rubberoid-coated fat wire sticking up from a cone in the middle of the back of the roof. It can be removed by unscrewing it from the cone.
richard schumacher is offline
Old 06-23-2006, 07:15 PM   #7
goody
The radio reception is worst than any car I have ever owned or own. I live in a rural area and only have two local stations one AM and one FM. They are the only stations that come in static free. As I leave the area I loose them a lot sooner that I do in my other vehicles. I wasn’t sure if something was wrong or not since the radio does work, and i do have my antenna.
And yes I know I can take it to any dealer but my closest dealer is an hour away and I really don’t want to go to them. My next closest dealer is about two hours away. It does sound like something isn’t right so I guess I can take a ride (good excuse to drive the Prius).
goody is offline
Old 07-09-2006, 02:06 AM   #8
Alnilam
The One in the Middle
Alnilam's Avatar
Package: #8
Not 100% applicable, but get a SAT radio and your reception will be perfect coast to coast (unless you park under a bridge.) XM has every type of programming you could hope for. (Sirius even has Howard Stern, but I never hoped for him!) You'll get NYC/LA quality programming in Butte, Montana. It's the future but available now for not all that much.
Alnilam is offline
Old 07-09-2006, 10:50 AM   #9
daniel
Cat Lovers Against the Bomb
daniel's Avatar
I get better reception in my Prius than on the radio in my house. Not surprising, since the Prius is out in the open. But still, it suggests that my Prius's radio is working fine.
daniel is offline
Old 07-09-2006, 11:34 AM   #10
MarinJohn
MarinJohn's Avatar
Friends: 7
The AM on my radio sucks. If I cruise along and get static I can shift into neutral and the static goes away. I believe there is interferance coming from the electric engine. I have brought it in for replacement which worked perfectly for about a week before it got just as bad as the original. I gave up.
MarinJohn is offline
Radio Reception Problem ovni Gen II Prius Technical Discussion 4 08-03-2007 04:44 PM
Northern NJ radio reception jimmyrose Gen II Prius Modifications 2 04-10-2007 12:04 PM
Radio Reception babsrocks Gen II Prius Audio and Electronics 3 03-14-2005 09:34 PM
Ideas to increase radio reception? MarinJohn Gen II Prius Main Forum 5 02-27-2005 04:26 PM
very poor radio reception -AM pkg konakahuna Gen II Prius Audio and Electronics 2 02-24-2005 10:50 AM
