This is a discussion on Disabling the Tire Pressure Monitor within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; For a while I had no problems but now I get that annoying yellow light on my dash saying I ...
Old 08-05-2006, 07:02 PM   #1
georgekessel
georgekessel's Avatar
Model: V
Package: Adv. Technology
For a while I had no problems but now I get that annoying yellow light on my dash saying I am having tire pressure issues.
This is because I put on custom rims/tires without the monitoring system on them.
Does anyone know how to disable the monitor?
georgekessel is offline
Old 08-05-2006, 07:32 PM   #2
Friends: 41
I don't have an '06, but isn't there a button under the steering wheel that disables or resets it?
efusco is offline
Old 08-05-2006, 08:12 PM   #3
walt
walt's Avatar
<div class='quotetop'>QUOTE(Ecojosh @ Aug 5 2006, 07:02 PM) [snapback]298411[/snapback]</div>
what Evan says - on the 2006 - button under steering wheel - next to the "turn off SKS" button.
walt is offline
Old 08-05-2006, 10:27 PM   #4
georgekessel
Model: V
<div class='quotetop'>QUOTE(walt @ Aug 5 2006, 05:12 PM) [snapback]298440[/snapback]</div>
All that does is reset it - and then it immediately turns back on
I want to disable it somehow or is there a way to get to the bulbs to yank that one?
Old 08-05-2006, 11:55 PM   #5
galaxee
resident lab rat
galaxee's Avatar
Friends: 26
electrical tape. put some over the indicator.
galaxee is offline
Old 08-06-2006, 10:36 AM   #6
georgekessel
Model: V
<div class='quotetop'>QUOTE(galaxee @ Aug 5 2006, 08:55 PM) [snapback]298527[/snapback]</div>
To to that right I'd have to remove the plastic clear cover that is offset from the indicator, then put the tape over the indicator direct, then replace the clear plastic cover. Anyone ever done that?
Old 08-06-2006, 12:20 PM   #7
David Beale
David Beale's Avatar
The other option (easiest but not least expensive up front) is to buy the valve stem senders from Toyota and put them in your custom wheels. Or just move the senders from the stock wheels over.
If you're going to start messing with the dash, this may be less expensive, as you may end up destroying an expensive part!
David Beale is offline
Old 08-06-2006, 12:37 PM   #8
georgekessel
Model: V
<div class='quotetop'>QUOTE(David Beale @ Aug 6 2006, 09:20 AM) [snapback]298620[/snapback]</div>
Too late, I had them on the factory rims/tires that I sold. Wouldn't know how to remove them anyway it seemed like they were part of the rim?
Old 08-06-2006, 01:37 PM   #9
stanleyjohn
stanleyjohn's Avatar
You bring up a good point Ecojosh!Im planning on getting snow tires for the winter and now it looks like ill need tires with pressure monitors.I Dont know how the whole thing works and how many tires have the monitor equiped.Is it built into the rim ,tire or both?Ill need to see if there is a cost factor and if only the dealer knows how to adjust them correctly.The manual has a section on the tire monitor.It does say non equiped tires disable the warning light.It also says other conditions may cause the light to be active.Hope you get an answer!i may be dealing with the same thing this winter!
Buy clean and effient to save the world.
2006 Prius,Package7,Driftwood Pearl
extras!>window glazing,scotchguard and pinstripes
Saw and Bought!on the spot June 17 2006
stanleyjohn is offline
Old 08-06-2006, 02:06 PM   #10
jbarnhart
jbarnhart's Avatar
Lordy, whoever bought those tires and wheels got a steal. Those pressure monitors go for over $100 EACH. Yikes!
jbarnhart is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Gen II Prius Care, Maintenance and Troubleshooting 32 04-08-2009 11:57 PM
Tire Pressure Monitor nicoss Gen II Prius Modifications 4 10-03-2006 09:29 PM
Tire Pressure Monitor Question Alan&#39;sRedPrius Gen II Prius Main Forum 3 03-21-2006 09:27 PM
Tire Pressure Monitor, where is the sensor? DocVijay Gen II Prius Main Forum 28 12-19-2005 06:08 PM
Tire Pressure Monitor eaflorida Gen II Prius Main Forum 0 12-03-2005 07:47 AM
