This is a discussion on Oil Level/Tire Pressure MPG Myth within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(jamarimutt @ Aug 8 2006, 07:24 PM) [snapback]299960[/snapback]</div> Overinflated tires produce a harsher ride and I wonder if they ...
Old 08-09-2006, 09:58 AM   #11
dmckinstry
Overinflated tires produce a harsher ride and I wonder if they cause rattles and may cause suspension problems later on. Using less oil than recommended means that the same oil is circulating over and over, so that you may need to change it earlier.
My experience over 44,000 miles is that dyno oil and 35/33 work just fine.
When I asked someone at the Toyota dealership where I have my oil changed, I was told 42/40 would probably cause too much wear in the center of the tread, as well as cause a very rough ride. The streets in both Spokane and Cheney (where I live) are far from smooth.
Dave
<div class='quotetop'>QUOTE(john1701a @ Aug 8 2006, 08:03 PM) [snapback]299989[/snapback]</div>
Not in a Prius. 5,000 miles is actually premature. The engine simply doesn't get worked anywhere near as hard as a traditional vehicle, which have the same change interval. Take a look during the next service. It comes out surprisingly thin & clean compared to what you'd expect.
In spite of the 5000 miles being premature, every time I get my oil change at just under 5000 miles (to be certain I'm keeping my warranty) they slap on a sticker indicating the next oil change in 3000 miles.
Dave
dmckinstry is offline
Old 08-09-2006, 10:00 AM   #12
Friends: 37
<div class='quotetop'>QUOTE(dmckinstry @ Aug 9 2006, 08:58 AM) [snapback]300149[/snapback]</div>
Dave
Dave
The ride is a little rougher, but the wear business is completely wrong. To the contrary many of us have experienced outside wear (both inside and outside) issues more than center wear even with the higher pressures--those running OEM rec. pressure see this a bit worse even.
efusco is online now
Old 08-09-2006, 10:41 AM   #13
ScottY
ScottY's Avatar
<div class='quotetop'>QUOTE(dmckinstry @ Aug 9 2006, 09:58 AM) [snapback]300149[/snapback]</div>
Dave
Dave
Lots of evidence (pictures, user experiences) on this site showing that keeping tires at spec will cause more edge wears.
Dealers want you to change oil at 3000 miles because they want more business. The maintenance booklet stated 5k miles intervals. Many on this site (including myself) did used oil analysis showing the oil is still good at 5k miles and can last a lot longer.
Overfilling the oil above full mark can cause problems too. The oil can get into the intake manifold and cause engine not run properly.
You can search around the site to see the posts I mention above.
05 Millennium Silver Metallic, Package #3 (package with SKS and all airbags)
  • mud flaps
  • MFD hood
  • bumper protector
  • CAN-View with OBD-II function
  • Coastal EV mod
  • mesh grill
  • DICE iPod integration + ground loop isolated audio in
  • "Prius" license plate frame
  • Thule roof rack and snowboard carriers (winter only)
ScottY is offline
Old 08-09-2006, 02:52 PM   #14
yauman
<div class='quotetop'>QUOTE(dmckinstry @ Aug 9 2006, 06:58 AM) [snapback]300149[/snapback]</div>
Dave
Recommendation for oil change every 3K miles as a “cheap” way to protect your engine is one my pet peeves. It’s really a total waste and a way to use up oil for nothing and a way for dealers and oil change outfits to make more money by scaring the wits out of us half-witted car owners! Any – and I mean ANY dino oil is good for over 10K – maybe even 15K-20K miles. The same cars sold in the US with the recommendation of 3K or 5K oil change when sold in Europe or Japan has a recommendation of 10k miles oil change interval. I first learnt of this in the early 80’s when I worked with a visiting scholar from the UK. . He bought an Escort, identical to the one he had at home – just ‘cos he’s familiar with it – and to his surprise the dealer (and the owner’s manual) recommended oil change interval was listed as 3K miles. He couldn’t belief it, he was sure he’s being ripped off. His Escort at home had a recommended interval of 7500 miles. Now is their oil that much better? No. Is their road and driving condition less harsh – no – in fact much worse. I decided to look into this and realized that indeed we have all been ripped off. Yes, 50 years ago, 3K miles oil change interval is about right. But today’s engine technology and metallurgy have advanced and so has oil formulation. After 3K miles in ANY engine, the oil drained will test like new. In 1995 when I bought a brand new Infiniti Q45, with a recommend oil change interval of 5000 miles, I told the dealer that I will bring my car in to them for all oil changes (and all repairs) but that I’ll only do it every 10,000 miles and I don’t want any hassles. Why, because the same car sold in Japan (as the Nissan Cima) has a recommend oil change interval of 15,000 km (about 10,000 miles.) The dealer has no problem with that and never threatened to void my warrantee. When I sold the Q45 last year with 160,000 miles on it, it purred like a kitten and ran like new. I bought a Honda Civic Hybrid and it comes with a recommended oil change interval of 10,000 miles – finally I’m glad to see Honda stepping up to the plate and debunk this 3000 mile oil change interval nonsense.
Goggle info about oil change intervals and you will find many research that say that even after 20,000 miles, the oil is barely “used” – so we Americans are just so desensitized to wasting perfectly good oil that we can be easily scared into submission about changing oil every 3K miles as “cheap” insurance for our engines. Nonsense – just a way for us to waste natural recourses. But we are all scared sh**less and brainwashed to “protect” our investment and will continue to dump perfectly good oil once every 3000 miles. What would it take to deprogram us? Well how about taking the oil to a lab for analysis after 3K, 5K, 7.5K, 10K or even 15K miles and let the result show that really, the oil not contaminated, the oil molecules not sheered and viscosity not diminished even after 10k miles and we really really don’t need to waste so much oil.
Here’s some links:
http://www.nordicgroup.us/oil.htm
http://www.motoroilbible.com/pre-one.html Exposing the 3000 mile change myth
http://www.carjunky.com/news/motor_oil_myths.shtml Same article here - better layout
http://www.amsoil.com/testimonials/409000.aspx Here’s Amsoil running their syn oil in Cummings truck for 400,000 miles – but wait don’t they want to sell more oil?
http://www.practicingoilanalysis.com/artic...p?articleid=562 Built-in sensors for cars to determine when oil needs to be changed.
http://freshalloy.com/club/editorials/snake_oil.html
yauman is offline
Old 08-09-2006, 08:28 PM   #15
hobbit
hobbit's Avatar
I used to have that same eighth-inch bilge of oil at the bottom of
my intake plenum, but more recently I've run about 5000 miles with
the oil at about a quarter-inch below the full mark on the stick,
i.e. the correct level, and the bilge is *almost* gone. It's clear
that an overfill gets sucked right up the PCV hoses, and it evidently
takes a *long* time to re-vaporize out of the manifold and get
burned up. Since I had my throttle-body off today to check it out
and lube the pivots, I was able to swab out the minor remainder so
now my intake chamber is close to DRY and I hope it'll stay that way.
_H*
hobbit is online now
Old 08-09-2006, 09:26 PM   #16
wilco
<div class='quotetop'>QUOTE(yauman @ Aug 9 2006, 11:52 AM) [snapback]300344[/snapback]</div>
agreed.
wilco is offline
tire shop broke a TPMS tire pressure monitor sensor during tire change theorist Gen II Prius Care, Maintenance and Troubleshooting 32 04-08-2009 11:57 PM
Tire Pressure MPG BigusD Gen II Prius Main Forum 3 07-23-2007 07:34 AM
Tire Pressure kcoruol Gen II Prius Technical Discussion 11 05-30-2007 04:06 PM
Tire Pressure Firefighter Gen II Prius Technical Discussion 1 06-21-2006 12:25 PM
Tire Pressure Tripod137 Gen II Prius Main Forum 19 04-18-2006 11:23 PM
