| This is a discussion on 2006 Brake Pad Thickness? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Just finished the 5000mi oil change/checkup. They measured 10mm on the front pads, and 5mm on the rear shoes, said ... |
| Senior Member Join Date: Mar 2006 Location: Cambria, CA, USA
Friends: 0 | Just finished the 5000mi oil change/checkup. They measured 10mm on the front pads, and 5mm on the rear shoes, said all's well. What is the initial thickness of the pads and rear linings? |
| Senior Member Join Date: Mar 2005 Location: Las Vegas, Nevada
Friends: 0 | I don't know what my thicknesses are, but I have changed the brakes on other Japanese cars about half a dozen times and on my Honda motorcycle about a dozen so I know how pads wear and what they look like when they need replaced. For the first 6 tire rotations I had the brakes checked and always the same "they look good". So I didn't think anything of it. Now on my last wheel rotation I finally did it myself (approximately 60,000 miles) and I thought I'd check the pads. Well damn, it doesn't even look like they have been used!!!!!! I mean they are brand new looking, probably 3/8 of an inch worth of material on the front, and no adjustment needed in the back! So from my simple observations I think these pads could go 150,000 to 200,000 miles! Now granted most of my miles are highway so the motor/generator does most of my braking, so your results may be different. |
Friends: 26 | at 5k miles you should have 99.9%-100% brake pads remaining. i think it was at the 15k that DH mentioned he could still see factory machining marks on ours. |
Friends: 0 | Yeah, I expect the pads to last forever, but since they're specifying the depth in millimeters, it'd be nice to know where I am. |
| ABS brake warning on 2007 Prius leading to brake failure | adk235 | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-05-2008 07:02 PM |
| Brake job | silfey | Gen II Prius Technical Discussion | 26 | 05-22-2008 03:36 PM |
| 2006 PULLS TO THE LEFT ON BRAKE | icemanjrperu | Gen II Prius Main Forum | 39 | 03-12-2008 03:10 PM |
| Bra thickness | grasshopper | Knowledge Base Articles Discussion | 4 | 12-02-2007 04:57 PM |
| Brake Pad Thickness specs | mossypete | Gen II Prius Care, Maintenance and Troubleshooting | 1 | 10-06-2004 01:30 AM |
