This is a discussion on Took the Prius Drag Racing! within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(Ray Moore @ Aug 28 2006, 05:57 AM) [snapback]310486[/snapback]</div> When we ran ours we turned 17.8 seconds at 87 ...
LinkBack (5) Thread Tools
Old 08-28-2006, 01:03 PM   #21
F8L
Collecting Data on Nature
F8L's Avatar
Friends: 35
When we ran ours we turned 17.8 seconds at 87 mph. We force charged to 8 bars as we were getting ready to make our run. This was at night at the Houston Raceway. Each time got slower. We think the inverter and battery were getting hotter and that was increasing the internal resistance and reducing the amount of electrical power we could utilize. We thought about letting it rest so the electrical components could cool but the engine would have cooled too. I guess a can-view would help figure all this out.
The ET sounds about right but the MPH is about 10mph too fast 87mph in the 1/4 would mean a 15sec ET.
I'll go out on a nice cool night and try testing the heating idea by simply letting it get nice and cool after a few hot laps. I know wheelspin wasnt an issue so traction control wasnt engaging.
F8L is offline
Old 08-28-2006, 02:56 PM   #22
240sxer
It must have been 78. I did a 18.1@78mph out here (2800ft) with a DA of 8000 or something like that.
Charging the battery seemed to do nothing, I think having it around 1/2 will do the best. From what I noticed the more charged the battery was the longer the delay for when it engages the ICE off the line. There is a delay when you launch and for a second or so you are ONLY on the electric which makes the car 60ft horrid (2.6-2.8). I never got a chance to test it at the track but I think if you have the battery worn down a bit maybe to 1/3 or 1/2 you can charge it at the line so the ICE Is on then just lift the brake when the light turns green, so the ICE will already be on and there will be no delay waiting for the ICE to turn on. That might help it get a 2.4 60ft or so which will bring the ETs down by .4-.6
For an example, my 91 240sx ran a 17.0@79mph. Only 2mph faster but 1.1 second faster in the 1/4.
It's all about the 60ft.
My 95 240sx 2jz turbo ran a 13.2@107 (2.2 60ft) with stock turbos that spooled quickly the car had 330whp at that point
hp from et = 309
hp from mph = 344
I upgraded the turbo a gave it some more boost for 440+whp and I ran a 13.3@118mph with a 2.8 60ft. the car gained 11mph of trap but lost .1 in et because of the much slower 60ft.
hp from ET = 302hp
hp from mph = 461hp
Getting the 60ft down to a 1.7 got me a 11.3@123mph 1/4 mile with the EXACT same setup minus a different trans/stall. Same power.
Prius
Calculating a 3200lbs (prius+driver+gas) car with a 17.6 = 116whp/139hp
based on trap 3200lbs car with a 79mph trap = 123whp/147.7hp
So if you could 60ft the car better, you *should* be able to run a 17.2 or so.
Sorry for the long post, i'm a drag racer guy.
http://www.s-series.org/htm/calc/hpcalc.htm
2006 Prius Package 6
-50% tint all around
-Currently about 41,500mi
1995 240sx SE
-2JZ-GTE 600hp
-10.8@136mph
-22mpg
-Street Driven
-No Catalytic Converters
1992 Sentra XE
-33mpg
1985 Lincoln Towncar
-19mpg
-14" Daytons
Previous Cars: 1996 Viper GTS, 2002 Corvette z06, 91 240sx, 2005 Accord EX-L, 2006 Accord EX-L, 2002 Nissan Sentra, 83 Lincoln Towncar, 1997 Nissan Pickup..
240sxer is offline
Old 08-28-2006, 03:06 PM   #23
F8L
F8L's Avatar
Friends: 35
LOL, no applogies needed. I race my 4x4 fullsize truck, my T/A, my C5 and my old 9sec 87' Mustang
Here is a video segment that illustrates exactly what you mentioned above:
2.1 60'
Trubo Z71 vs Turbo Buick GN (I didnt pre-spool and got a terrible 60'
1.8 60' cant remember exactly but 1.8 something
Turbo Z71 vs N/A Mustang LX
The trick is figuring out how to get these cars off the line quicker. Its all in the 60' and it doesnt look good
Ohh, that 240 sound awesome
F8L is offline
Old 08-28-2006, 04:41 PM   #24
240sxer
Yeah, the 240 is pretty quick. It should be in the 9s soon. I'm going wish a standalone and bigger injectors. Right now my fuel is maxxed out @ around 500whp on pump gas. The Buick GN is pretty similar to the supra... big laggy turbos... (my 240sx has a supra engine)
I also have a C5. A 02 Z06. Best I can do in that is in the 12.3 range, it's bone stock though.
Ahh, an STS turbo, I was thinking about one of those either for my 06 Chevy Singlecab with the 4.8liter V8 or putting one on the vette. I think the vette can do around 550whp with the system@5psi or so which is good since I put down 350whp stock that's a ncie increase. What turbo does the truck have? I have a A BorgWarner T70 with a .86 A/R on the 240. It's supposed to be good for around 800hp but it's a laggy mofo.
60ft is everything... My 240 still does not 60ft well for having 28in ET Street tires on it, but it's not too bad. I've got a 4000rpm stall and a Transbrake (TH400). I really need nitrous to get it off the line better but I don't want nitrous on the car. It's more impressive all-boost pump gas to me. (91 octane Cali pump gas at that).
240sxer is offline
Old 08-28-2006, 04:42 PM   #25
F8L
F8L's Avatar
Friends: 35
I knew you were cool form the first post. hahaha
F8L is offline
Old 08-28-2006, 04:54 PM   #26
240sxer
I try to avoid modding the Vette since I got it to be my *legal* car. I can go to the street races and such and not worry about being bugged or getting caught since the car is 100% stock, yet I can still run with some of the quick cars. The 240 is the beast that runs around on slicks and skinnies and hardly ever leaves the garage. It's a Nissan 240sx with a Toyota 2JZ-GTE engine and a Chevy TH400 trans. lol..
Here it is... It's quick for not really being crazy modified.
Toyota 2JZ-GTE
Cheap Ebay Turbo Manifold
Borg Warner T-70 Turbo
550cc Stock USDM Injectors
3in Downpipe
3in Exhaust
QTP Exhaust Electronic Cutout
Hybrid Front Mount intercooler
Chevy TH400 Transmission w/Brake
Pro Torque 4000rpm Conveter
Only dyno i've done with this turbo was 440whp/460tq@15psi, I usually race it at 18-20psi
[attachmentid=4658][attachmentid=4659][attachmentid=4660]
Took the Prius Drag Racing!-2jz240sx_021.jpg   Took the Prius Drag Racing!-2jz240sx_031.jpg   Took the Prius Drag Racing!-2jz240sx_033.jpg
240sxer is offline
Old 08-28-2006, 05:09 PM   #27
tnthub
tnthub's Avatar
<div class='quotetop'>QUOTE(Lola'05 @ Aug 27 2006, 08:47 PM) [snapback]310334[/snapback]</div>
This drag racing has got to be a male thing.
Actually, a very good movie called Heart Like a Wheel was just re-issued on DVD. It is the story of Shirley Muldowney. You should watch it.
Drag racing is one of very few athletic contests where men and women not only compete equally but also there are no hard and fast rules that require a specific type of physique in order to excel. Angelle Sampey is a multi time Pro Stock Bike champion, Melanies Troxel is currently in the top five in points in top fuel, and Shirley Muldowney was a multi time top fuel champion.
Upper body strength is not a major factor in drag racing. Teamwork, driver ability, focus and knowledge typically separate the best from the proficient. The driver has a lot to do with winning, especially at a local level where the vehicles are often handicapped.
2002 Champion New England Dragway
2001 GM High Tech Shootout Winner
1999 Champion Oxford Dragway
http://www.tntdragracing.com
tnthub is offline
Old 08-28-2006, 05:16 PM   #28
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
<div class='quotetop'>QUOTE(Lola'05 @ Aug 27 2006, 05:47 PM) [snapback]310334[/snapback]</div>
Tell that to Shirley Muldowney or John Force's three daughters.
tumbleweed is offline
Old 08-28-2006, 06:07 PM   #29
Randy G.
<div class='quotetop'>QUOTE(Lola'05 @ Aug 27 2006, 07:47 PM) [snapback]310334[/snapback]</div>
For the seriously uninformed:
Women's Sports Foundation "Sportswoman of the Year" Melanie Troxel
Randy G. is offline
Old 08-28-2006, 09:10 PM   #30
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
I wonder if you actually kept the engine in the Prius running to minimise the lag, would that help? Say, stay in B so that the engine doesn't shut off.
Tideland Prius is offline
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/23047-took-prius-drag-racing.html
AMD Meet: 9/20/2009 biitches! - Page 64 - Maxima Forums This thread Refback 08-31-2009 02:29 AM
One Less Prius - Page 3 - CleanMPG Forums This thread Refback 08-25-2009 02:29 AM
Drag Racing Thread from the Prius site.....WTF? - Cedar Valley Muscle Cars This thread Refback 04-30-2009 08:34 AM
Drag Racing Thread from the Prius site.....WTF? - Cedar Valley Muscle Cars This thread Refback 04-29-2009 07:26 PM
Drag Racing Thread from the Prius site.....WTF? - Cedar Valley Muscle Cars This thread Refback 04-29-2009 07:04 PM
Prius Coefficient of Drag SureValla Gen II Prius Main Forum 22 11-24-2008 08:23 PM
Why Is The Prius Such A Drag? Smooth Operator Gen II Prius Main Forum 29 11-21-2008 06:41 AM
My Prius is going Drag Racing Skraut Gen II Prius Main Forum 15 05-05-2005 05:14 PM
Drag Racing with a Hummer hdrygas Gen II Prius Main Forum 1 03-11-2005 02:26 PM
