This is a discussion on 2005 Navigation System / Adding to a non-nav Prius within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Question? I own a 2005 Prius, and it has the standard screen for climate/audio/information (4 button system). I noticed that ...
Old 09-05-2006, 09:14 PM   #1
Cloaked
Thumbs up
Question?
I noticed that Toyota does NOT do any after sales upgrades for a Navigation system. Called them today and the parts department verified this can't be done (seems foolish since Toyota could make some money off these options...).
If I can find a OEM navigation system to install in the Prius, can it be slapped in? Or is there some wiring that would be mising from the original manufacturing of the vehicle?
I know I would need the navigation system, voice recognition box and possibly the steering wheel button.
If I found these items, can it be done?
Thanks for any input!
Cloaked is offline
Old 09-05-2006, 10:53 PM   #2
hdrygas
I guess it could be done but it will not be easy. There are several sensors that you will need. The wireing harness is different. There are a few ECU's that are different. I can be done but it would take a lot of knowledge. I would go for an after market solution, if I were you.
hdrygas is offline
Old 09-06-2006, 11:23 AM   #3
sl7vk
sl7vk's Avatar
http://www.garmin.com/products/gvn52/
There's the product for you my friend.
sl7vk is offline
Old 09-06-2006, 01:50 PM   #4
newkbomb
<div class='quotetop'>QUOTE(hdrygas @ Sep 5 2006, 09:53 PM) [snapback]314948[/snapback]</div>
I would just get a Tom-Tom or Garmin... They are very small these days and mobile! I'm assuming it would be way cheaper than trying to integrate one into your MFD.
newkbomb is offline
Old 09-06-2006, 02:07 PM   #5
aaf709
Ravenpaw of ThunderClan
aaf709's Avatar
There are also some aftermarket systems that can be built in. They replace the radio (actually they become the radio, CD, XM) and the screen pulls out for use and retracts when not needed.
aaf709 is offline
Old 09-06-2006, 08:27 PM   #6
rich502
For the 2005 Prius Nav system, regular upgrades are important. I have a 2005 Prius with a Nav upgrade from Jan 2005. I called my dealer to see if an upgrade was avaialable, and they weren't sure.
Does anyone know if a later Nav upgrade for the 2005 Prius is available. Was there a Jan 2006 upgrade and do you think there will be a Jan 2007 upgrade. The Jan 2005 upgrade cost $275. What do you think future upgrades will cost?
Thanks!
Rich
rich502 is offline
Old 09-06-2006, 11:27 PM   #7
aaf709
aaf709's Avatar
<div class='quotetop'>QUOTE(rich502 @ Sep 6 2006, 05:27 PM) [snapback]315508[/snapback]</div>
Thanks!
Rich
What version number are you talking about? The latest is 5.1, I believe.
aaf709 is offline
Old 09-07-2006, 10:27 AM   #8
daniel
Cat Lovers Against the Bomb
daniel's Avatar
Rather than trying to install a system that would put NAV onto your present MFD, get a Garmin StreetPilot. It sits on your dashboard and puts the NAV screen right in your field of view (but below the bottom of the windshield) so that you can see it without looking way off to the side. I find this set-up very good. It plugs into the cigarette lighter and it gives voice directions as well as text on the screen, and of course shows you a map of where you are with arrows indicating turns.
One very high-end model can connect to your speed sensor for when you lose the satellites, but I don't think that's worth the extra cost.
Another high-end feature on some is traffic info, capable (supposedly) of routing around traffic jams, but note that this is only available (for a fee) in a very few very large metropolitan areas.
Daniel
Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph.
Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power.
Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius.
-- Emma Goldman
-- Otto von Bismarck
daniel is offline
Old 09-07-2006, 08:52 PM   #9
xbdude
opticat
xbdude's Avatar
I purchased a Garmin NUVI 350 GPS from "Abe's of Maine" over the web. It is GREAT, and mounts easily. It can be transferred to my Tacoma when needed. The touch screen and display resolution is fantastic.
xbdude is offline
Prius navigation system ohgreys Gen II Prius Audio and Electronics 30 08-24-2009 09:10 PM
Adding Starbucks to the Navigation system pbenson92025@yahoo.com Gen II Prius Technical Discussion 11 07-13-2007 01:07 PM
Adding Good Leather to a 2005 Prius osXcode Gen II Prius Modifications 4 04-19-2007 09:17 PM
Adding navigation to a non-nav model Tideland Prius Gen II Prius Modifications 0 11-03-2006 01:59 AM
Adding External Navigation System... eck34 Gen II Prius Audio and Electronics 1 03-12-2005 08:22 PM
