| This is a discussion on Max speed of Prius within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; beautiful vette!!!!!!! i heard that the car is governed at 107 mph on the pri... |
Max speed of Prius
| | LinkBack (8) | Thread Tools |
| | #71 |
| Senior Member Join Date: Jun 2009 Location: nashville
My Car: 2010 Prius Model: II Package: N/A Thanks: 0
Friends: 0 | beautiful vette!!!!!!! i heard that the car is governed at 107 mph on the pri |
| | #72 |
| Junior Member Join Date: Jul 2009 Location: Bay Area
My Car: 2005 Prius Model: N/A Package: No Package Thanks: 0
Friends: 1 | I heard on the radio theres a celebrity that was drunk driving and he was going 120 mph and was caught by a cop. ![]() |
| | #73 |
| Member Join Date: Feb 2008 Location: New Jersey
My Car: 2008 Prius Model: Package: #2 Thanks: 3
Friends: 0 | |
| | #74 |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Model: Package: #5 Thanks: 1
Friends: 25 | Al Gore's son is correct, and if I recall his speed was about 105 !!! Wonder what his mileage read out was? Last edited by Rangerdavid; 07-10-2009 at 08:01 PM. |
| | #75 |
| Custom User Title Join Date: May 2007 Location: Stockholm, Kingdom of Sweden
My Car: 2007 Prius Model: N/A Package: N/A Thanks: 3
Friends: 0 | |
| | #76 |
Friends: 0 | I've earlier stated that the top speed is limited to 180 km/h (according to the speedometer of the car). I've also learned that if you accelerate up to top speed while going downhill, you can momentarily reach higher speeds, but you will eventually slow down to 180. Well, today I learned that if you set the cruise control to just below 180 and use the CC's function to increase the speed, 181 on the speedometer is possible and this is not just momentarily. I couldn't get the speed up any higher than that and I tested this on three different occasions during the day. |
| | #77 | |
| Senior Member Join Date: Sep 2007
My Car: 2005 Prius Model: Package: Base Thanks: 3
Though if the inverter output voltage for the drive system can be doubled, MG2 might still be able to provide full torque well into 140kph and in phase advance mode provide some percentage of full torque up to about 260 kph... but that torque will not be enough to really add any significant speed at 180 kph. So to really up the top speed you would need a high voltage (1500 volt) inverter. It would have to have triple the input current capacity and instead of hooking it up to the traction battery, you would need some super capacitors. This would allow MG2 to provide full torque up to 210 kph, that would probably up the top speed to over 200 kph, until the capacitors are drained... But you should be able to go from 0-100 kph (about 60mph) in about 7-8 seconds. Making the prius a sports car... | |
| | #78 |
| Senior Member Join Date: Oct 2007 Location: Quebec
My Car: 2005 Prius Model: Package: Base Thanks: 27
Friends: 2 | |
| | #79 |
| Junior Member Join Date: Oct 2008 Location: Toronto, Canada
My Car: 2008 Prius Model: Package: Base Thanks: 1
Friends: 0 | My brother-in-law just got back from Germany where he got his rented Prius (Gen II) up to 190 Km/h. Showed me a photo of the speedo to prove it. Said his wife took the photo. I'm not sure I'd want to drive a Prius at that kind of speed, myself! |
| | #80 |
Friends: 0 | If you haven't changed the balance of the car with too much luggage and have decent tires with proper pressure, the car is still stable at those speeds. At 190 km/h, the Prius is coasting with the engines disengaged and will eventually get back down to 180. |
| max, prius, speed |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/2419-max-speed-prius.html | ||||
| Prius self aware: Started driving itself to skynet - Page 16 - NASIOC | This thread | Refback | 03-15-2010 02:18 AM | |
| Prius self aware: Started driving itself to skynet - Page 16 - NASIOC | This thread | Refback | 03-14-2010 05:39 PM | |
| Did Toyota Prius Driver Fake Unintended Acceleration?, page 1 | This thread | Refback | 03-12-2010 08:55 PM | |
| Untitled document | This thread | Refback | 03-09-2010 09:02 PM | |
| Untitled document | This thread | Refback | 03-09-2010 03:40 PM | |
| Untitled document | This thread | Refback | 03-09-2010 01:55 PM | |
| Untitled document | This thread | Refback | 03-09-2010 01:09 PM | |
| Netflix Changes Its Mind, Will Keep Profiles Feature | This thread | Refback | 07-01-2008 07:21 PM | |
| 07 Prius Top Speed | PriusTouring07 | Gen II Prius Main Forum | 5 | 07-31-2007 08:28 PM |
| Break in speed for new Prius | blackprius2007 | Gen II Prius Technical Discussion | 9 | 04-28-2007 12:44 PM |
| Top speed your Prius has gone? | Locust43 | Gen II Prius Main Forum | 32 | 12-12-2006 03:11 PM |
| Prius Speed | Prakash | Gen II Prius Main Forum | 32 | 04-12-2006 01:53 PM |
| Ok.. whats the top speed of you prius? | windstrings | Gen II Prius Main Forum | 23 | 11-10-2005 01:17 PM |
