This is a discussion on Mouse chews hybrid wiring harness and causes $1166.79 damage within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi, cyberprius, Blow up the thumbnails in syncmaster's post #37 here & also go to the PriusOnLine link he provided ...
LinkBack (7) Thread Tools
Old 04-17-2008, 01:21 PM   #51
Ct. Ken V
Default Re: Mouse chews hybrid wiring harness and causes $1166.79 damage
Hi, cyberprius,
Blow up the thumbnails in syncmaster's post #37 here & also go to the PriusOnLine link he provided in his post #35 here. Look at all the photos on all 3 pages at PriusOnLine (especially syncmaster's on pg 3). That's the same gutterguard mat'l I used & the same cutting, shaping, & fasten'g that I did. I feel fairly confident that the critters aren't going to get past that.
Because I found mouse nest evidence inside the engine air filter box, I used the same mat'l to cover the outside end of the engine air cleaner tube & formed it tightly & fastened it with screws & washers. Somebody else screened off this tube on the inside end (inside the box), but I didn't want that long weaving tube to fill up with nest'g debris from one end to the other---it would be too hard to clean out. Again, I felt safe until I saw this thread.
Thanks to "wheels" & "syncmaster" for your discovery & solutions. Now I've just got to find out where the 2 (more?) openings that Pat Wong spoke about are.
Ken (in Bolton,Ct)
Ct. Ken V is offline
Old 04-17-2008, 02:34 PM   #52
Ct. Ken V
Hi, Pat,
Yes, I agree about the engine compartment---not much you can do there. But my primary concern was to keep the critters out of the car's interior & passageways [especially since last year I found a softball-sized wad of fluffy cloth stuff (from where?) on top of my cabin air filter along with health portion of nut shells & berry husks as well as the nest'g evidence I also found inside the engine air filter box].
So you think there are 2 openings instead of one on the right rear? Isn't the thumbnail at the right end of post #37 showing the battery box vent? That is between the right rear wheel well & the right taillight & there doesn't seem to be any leftover space for another vent open'g (or any need for one).
The left vent hole (in the middle thumbnail) would provide for flow-through ventilation of the passenger cmpartment's air. The high voltage battery vent intake is in the upper portion of the right rear seatback, goes down into the battery box, & I would think exits as pictured in the right end thumbnail. As far as the vent for the 12V battery, that's just a small plastic tube exit'g through a small tight-fit'g hole in the body near the tail light, isn't it? So where would there be room for another big vent in the RIGHT rear? Are you sure it's not just 2 instead of 3?
And while we're on the subject of damaged electrical cables, Godiva's link in her post #3 (Wiring harness potential problem) doesn't work any more. Although this cable/harness has been identified as NOT being a high voltage cable, it still could cause some serious problems if punctured by the mis-placed/unneccesary tab on the starter hole cover as identified by Hobbit in this link : http://techno-fandom.org/%7Ehobbit/cars/starthole/
It is from post #1 & 48 in a 93-post thread on the subject. My cable was start'g to be cut by this tab & the dealer after romving the tab, re-taped the cable & filed a warranty claim for the time charged to do the work. You'd think after all this time that Toyota would have done something to prevent this at assembly, & they know about it from a few of us here having had it taken care of at the dealer level. Here's the 93-post link :
http://priuschat.com/forums/care-mai...-06-prius.html
Ken (in Bolton,Ct)
Old 04-17-2008, 03:44 PM   #53
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Originally Posted by Ct. Ken V View Post
...So where would there be room for another big vent in the RIGHT rear? Are you sure it's not just 2 instead of 3?
Hi Ken,
I'm not sure; I might be confusing my 2001 and 2004 since I had to install rear shocks on both. So, just look around carefully when you have the hatch trim removed, think like a mouse, and seal any holes bigger than 1/4" that you find!
Speaking of the 12V auxiliary battery, I suggest you take a look behind the battery and make sure that the right-side vent is not partially hidden back there.
Glad that you had your starter plate tab removed and the cable taped. I looked at my 2004 and the spacing between the tab and the adjacent cable seems adequate as-is.
Good luck.
2006 Highlander Hybrid 4WD-i
2000 Ford Mustang GT conv.
Patrick Wong is offline
Old 11-06-2009, 08:51 AM   #54
Rick Suddes
[Spray Rataway Fragrance it works on squirrels, rats, mice, etc...
Rick Suddes is offline
O, chews, damage, harness, hybrid, mouse, wiring
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/24224-mouse-chews-hybrid-wiring-harness-causes-1166-79-damage.html
Toyota Prius vs VW Golf TDI - CarSpace Automotive Forums This thread Refback 10-25-2009 02:17 PM
Toyota Prius vs VW Golf TDI - CarSpace Automotive Forums This thread Refback 10-19-2009 08:47 PM
Toyota Prius vs VW Golf TDI - CarSpace Automotive Forums This thread Refback 10-12-2009 05:37 PM
Toyota Prius vs VW Golf TDI - CarSpace Automotive Forums This thread Refback 10-01-2009 08:18 PM
Toyota Prius vs VW Golf TDI - CarSpace Automotive Forums This thread Refback 09-27-2009 08:14 PM
MSN Shopping This thread Refback 01-16-2009 06:16 PM
TinyURL.com - shorten that long URL into a Tiny URL This thread Refback 04-07-2008 07:13 PM
trailer wiring harness info for 2007 Pri priussoris Gen II Prius Main Forum 11 11-13-2007 12:54 PM
Fog light wiring harness dgooden8 Gen II Prius Modifications 8 08-25-2007 09:13 AM
Possible harness-damage problem for 04-06 Prius ScottY Gen II Prius Care, Maintenance and Troubleshooting 92 03-30-2007 02:40 AM
Wiring Harness for '07 non-jbl? Sillyboy Gen II Prius Audio and Electronics 3 03-14-2007 01:51 AM
Concerns in having Toyota add 12v wiring harness PsyPrius Gen II Prius Modifications 1 02-14-2006 03:53 PM
