This is a discussion on 2007 Touring Prius Navigation System within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just bought a new 2007 Prius Touring with Navigation. I'm trying to override the navigaion but doesn't seem to ...
Old 10-15-2006, 03:28 AM   #1
dcatsss
I just bought a new 2007 Prius Touring with Navigation. I'm trying to override the navigaion but doesn't seem to be working. Does anyone know if Toyota change the navigation system from 2006 and before? I try going to the volume screen and pressing upper left, lower left, upper left and lower left. It does not work. Please help!!!!
dcatsss is offline
Old 10-15-2006, 09:55 AM   #2
mrichman
In 2006, the display went from analog to digital and the volume, upper left, lower left "feature" does not work. I believe that you can enter destinations while moving through the voice recognition now or go third party for an over-ride box (Coastal Tech may have a unit that works for the 2006-2007, but I'm not certain).
Mike
<div class='quotetop'>QUOTE(dcatsss @ Oct 15 2006, 02:28 AM) [snapback]332945[/snapback]</div>
mrichman is offline
Old 10-15-2006, 05:32 PM   #3
Alnilam
The One in the Middle
Alnilam's Avatar
Package: #8
<div class='quotetop'>QUOTE(dcatsss @ Oct 15 2006, 12:28 AM) [snapback]332945[/snapback]</div>
I just bought a new 2007 Prius Touring with Navigation. I'm trying to override the navigation but doesn't seem to be working. Does anyone know if Toyota change the navigation system from 2006 and before? I try going to the volume screen and pressing upper left, lower left, upper left and lower left. It does not work. Please help!!!!
You're SOL, as Granny used to say. (Short on Luck.)
After 2005 the system, as well as certain features of the BlueTooth phone system, have been locked out while in motion except, like he said, using voice commands or pre-installed points, like "Home" or "School" that you go to a lot and saved. The Coastal override box doesn't work for us. Neither does the selective massaging of the MFD screen. Give it up. Nobody has come up with a software fix yet.
There is a modification, involving some wire cutting and dash intrusion that I'd suspect you'd feel better about doing after you get your first scratch. It's not hard. It justs sounds like insanity to start taking apart a new car, but you'll get into it after a bit.
Good luck and enjoy your new vehicle. I've never regretted getting mine and wouldn't trade it for a Ferrari.
"Mars is essentially in the same orbit...Mars is somewhat the same distance from the Sun, which is very important. We have seen pictures where there are canals, we believe, and water. If there is water, that means there is oxygen. If oxygen, that means we can breathe." Dan Quayle
W6TWA
Coastal 1 1/4" Hitch
BT Brace
Toyota XM
Robin's MFD Shade
Motion Bypass Switch
Zaino Forever!
Coastal EV Package
ScanGuage II
Beltronics Vector 985 Radar Detector
Alnilam is offline
Old 10-17-2006, 03:27 AM   #4
dcatsss
<div class='quotetop'>QUOTE(mrichman @ Oct 15 2006, 08:55 AM) [snapback]332955[/snapback]</div>
Mike
Thanks I will try them!
<div class='quotetop'>QUOTE(Alnilam @ Oct 15 2006, 04:32 PM) [snapback]333101[/snapback]</div>
Thanks for the help. It's not that big a deal yet. I'm sure someone will come out with something. The never of them trying to fix things on us!
dcatsss is offline
Prius navigation system ohgreys Gen II Prius Audio and Electronics 30 08-24-2009 09:10 PM
2007 Black Prius Touring w/Bluetooth & JBL $25k iioeo Private Sales 0 10-18-2007 03:54 PM
JBL System Upgrade on 2007 Touring Cox Gen II Prius Audio and Electronics 11 06-13-2007 07:13 PM
New 2007 Prius Touring clintbhs02 Gen II Prius Main Forum 7 05-18-2007 11:55 AM
Just bought my 2007 toyota prius touring!!! kdailey356 Gen II Prius Main Forum 10 11-14-2006 03:15 PM
