| This is a discussion on Jump Start Prius Via Accessory Outlet? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; The aux battery of our 2007 (1,500 miles) was dead this afternoon. Car won't go "ready", electric door locks don't ... |
| Member Join Date: Nov 2006 Location: Portland
My Car: 2007 Prius Model: Package: #5 Thanks: 0
Friends: 0 | The aux battery of our 2007 (1,500 miles) was dead this afternoon. Car won't go "ready", electric door locks don't work, etc. Multi-tool reads 3 volts at the jumper post in the engine compartment. Not sure how it could have happened, as the car was only parked for 4 hours since my wife had last driven the kids to school. Can't imagine leaving an interior light on could drain the aux battery in that short a time. Called Toyota dealer who said we could recharge the battery. Anyway, my battery charger appears to be defective, it is electronically controlled and will not "charge" - not a Prius issue, I've had problems w/ it before. But I also have one of those "battery boosters" that plug into a 12v cigarette/accessory socket to jump start a car. Will this work on the Prius? Or will it damage the car, so that I shouldn't even try? |
Friends: 0 | <div class='quotetop'>QUOTE(John L. @ Jan 5 2007, 10:08 PM) [snapback]371625[/snapback]</div> Quote:
They may have changed it in the 2007 models, however this has been the general mode of operation on Toyotas - and other imported cars for years. | |
Friends: 0 | Costal Tech has a mod that keeps one of the aux power sockets ("cigarette lighter") live. If you installed that mod you might be able to use a charger there. But if your battery is healthy and there are no current leaks in the car, you should not need to use a charger on a regular basis. |
| Senior Member Join Date: Oct 2004 Location: Dallas TX
Friends: 0 | <_< I advise CAUTION in modifying a Prius to make the 12v accessory outlet [AKA "Cigarette Lighter"] on without the Prius being in "Ready" mode. Potentially, you could accidentally leave a 12v accessory [Cellphone, Tomboy, etc.] plugged in and deplete the 12v accessory battery. On the other hand... If your memory is perfect you wouldn't need to be concerned. |
| Junior Member Join Date: Dec 2006
Friends: 0 | My first post at Prius Chat. I just purchased a 2007 Prius (package 2). In just case, would this be a useful item to have? Black and Decker Simple Start. http://www.blackanddecker.com/ProductGuide...ProductID=16346 Joanne |
Friends: 0 | <div class='quotetop'>QUOTE(Joanner @ Jan 7 2007, 10:11 AM) [snapback]372098[/snapback]</div> Quote:
The B&D device will not work on a stock Prius because the cigarette-lighter outlets are not connected when the car is off. As I noted in my earlier post, there is a mod sold by Costal Tech that will cause one of them to stay live, so you could use the B&D gadget. However, as Charles warns, this could be risky, because a device left plugged in and turned on could drain your 12-v battery. However, the Prius is so reliable that your chances of needing a jump start are very small.
__________________ Daniel Primary car: 100% Electric 2003 Porsche 911 Carrera. Estimated range at 55 mph: 81 miles total or 64 miles to 80% discharge. Top speed 70 mph. Secondary car: Zap Xebra SD, also 100% electric. 1.9 cents per mile. Range: 40 miles total, or 32 miles to 80% discharge. Top speed 35 mph. Faster downhill. Both EVs use electrons generated from water power. Gas guzzler for when I have to travel farther than 60 miles: 2004 Prius. "If voting changed anything, they'd make it illegal." -- Emma Goldman "Anyone who has ever looked into the glazed eyes of a soldier dying on the battlefield will think long and hard before starting a war." -- Otto von Bismarck | |
Friends: 0 | Thanks, Daniel. Now I can spend the $$$ on other goodies for my car! I'm learning a lot here, although most of it is over my head. I will probably be asking some pretty stupid questons. Joanne |
Friends: 0 | Well, as predicted, the cigarette light battery booster did not work. However, seems to me having an easy way to jump start the car could be a useful thing. So I am planning to get the Coastal mod to keep the front accessory outlet "live" and then carry the booster in the under-floor compartment. Anyway, I bought a conventional battery charger, a couple hours on 2 amps, and problem solved. I am still puzzled at how the aux battery could have been drained so quickly, so will keep an eye on it. Perhaps I have a slightly defective battery. BTW, given how smart the Prius is in other ways, I am surprised it doesn't automatically shut off power to whatever is draining the aux battery (dome light, accessory socket, etc) when the aux battery voltage is getting dangerously low. |
Friends: 0 | wow I didn't know about this either. I was going to buy one awhile back to jump start my car, but I am glad I came back to the forums! |
Friends: 10 | <div class='quotetop'>QUOTE(John L. @ Jan 8 2007, 12:53 AM) [snapback]372364[/snapback]</div> Quote:
Tom | |
| Jump start another car FROM a Prius? | davebrownbass | Gen II Prius Care, Maintenance and Troubleshooting | 12 | 11-18-2009 12:11 AM |
| Jump starting from portable jump start units | justifyd | Gen II Prius Technical Discussion | 29 | 11-12-2009 07:39 PM |
| Jump start with portable? | vikx | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 09-09-2007 02:19 AM |
| Minimum amperage needed to jump start a 2006 Prius... | samuraikm | Gen II Prius Technical Discussion | 7 | 07-28-2006 09:30 PM |
| Prius Wont Start without a Jump | badab1ng | Gen II Prius Care, Maintenance and Troubleshooting | 13 | 07-26-2005 12:52 PM |
