12 volt battery cost 275.00 2005 Prius W
Old 03-05-2007, 01:44 PM   #1
Smile
2005 Prius With 95 k miles on it any better idea
k4141222 is offline
Old 03-05-2007, 02:00 PM   #2
Model: V
Package: Adv. Technology
<div class='quotetop'>QUOTE(k4141222 @ Mar 5 2007, 01:44 PM) [snapback]400446[/snapback]</div>
Would like to know as well.. got 94K on a 2004.. so mine might need replaceing soon..
p626808 is offline
Old 03-05-2007, 03:07 PM   #3
F8L
Protecting Habitat & AG Lands
F8L's Avatar
My Car: 2012 Prius
Model: Three
Friends: 75
*edited due to bad information*
F8L is online now
Old 03-05-2007, 03:14 PM   #4
Toyota quoted me about $180 to replace the battery in my 4Runner - I also took the $60 Autozone route. Nothing special about the 12 V battery in the Prius that I am aware of.
Mike
Stringmike is offline
Old 03-05-2007, 03:58 PM   #5
Charles Suitt's Avatar
My Car: 2012 Prius
Model: Four
Package: Navigation
<_< As frequently discussed in PriusChat, the Prius 12v auziliary battery is unusual. It is sealed to prevent emission of gasses since it is located within the passenger cabin, it is small in size and capacity since it's primary function is to close the relay to connect the traction battery and only temporarily provide power to other Prius elements. It is easy to deplete by simply leaving interior lights on for a long period and it is normally kept in a state of proper charge by the traction battery through the onboard invertor.
Actually, the Prius 12v battery is more like a motorcycle battery than 12v batteries found in ordinary cars. I've never heard of a Prius owner finding a proper replacement 12v Prius battery at Sears, AutoZone or similar stores. I have read that some Prius owners have adapted Miata 12v batteries to the Prius with minor modifications. I hope that some aftermarket battery manufacturer will provide competition as the Prius population increases.
The good news: I drove my 2004 Prius for over 2½ years, leaving it unattended, undriven for 15 days at a time without 12v auxiliary battery problems. I did make sure that no interior lights were accidentally left on and that the SKS {Smart Key System} was off when we left on our trips.
Charles Suitt
Dallas Texas
Prius #3: 2012 Four Display Audio/Nav (May 2012)
Prius #2: 2007 Touring Pkg 6 (Nov '06) Still driving
First Prius: 2004 (Oct '04) Traded for '07
Charles Suitt is offline
Old 03-05-2007, 04:45 PM   #6
F8L
F8L's Avatar
My Car: 2012 Prius
Model: Three
Friends: 75
<div class='quotetop'>QUOTE(Charles Suitt @ Mar 5 2007, 12:58 PM) [snapback]400528[/snapback]</div>
I don't see much of a difference between the Prius battery and any other sealed gel-cell type battery like the Optima or Stinger car audio batteries. Could you lead me to something that would show where those kinds fo batteries won't work? The Optima style batteries shouldn't be more than $130.
F8L is online now
Old 03-05-2007, 05:24 PM   #7
Item Number MSRP, Core Price, Price
2880021050 $138.70, $0.00, $110.96
BATTERY, PRIUS
This is from http://www.toyotapartscheap.com/, I'm sure there are others
luckyboy is offline
Old 08-21-2008, 02:37 PM   #8
Little Lou
Default Re: 12 volt battery cost 275.00 2005 Prius W
Re: 12v battery: please tell me what the:
o TOYOTA part number is;
o about how many miles or years is this battery's typical life with normal use and care;
o is the replacement battery a STANDARD or non-standard auto battery (the previous responses seem to say yes AND no);
o is the replacement done about as easily as other typical autos?
LRP114 is offline
Old 08-21-2008, 03:47 PM   #9
David Beale's Avatar
The only difference in -battery type- for the Prius battery is it has a vent tube, which vents gases outside in case of some kind of failure. This is -different- than a "sealed lead acid" battery. They can still suffer from some kind of failure, and if they do they vent. As the battery is in the cabin this venting can be considered "dangerous". The Prius battery type IS very similar or the same as some motorcycle batteries. This has nothing to do with whether the battery is a "gel cell" type or "AGM" type. They are all lead acid batteries, and that is what the system is designed for.
What you want in the Prius is a "deep discharge sealed and vented lead acid battery".
There is an Optima available for the Prius with an install kit that puts a vent tube on it and converts the battery terminals. The yellow top Optima is a deep discharge battery. Search this forum for Optima Battery to find the thread. Cost is just under what you were quoted from your stealer, er, dealer. The Optima is a better quality battery, but whether it is "better" in a Prius is debatable. It shines in "rough service". The Prius application is not "rough service".
Edmonton Alberta
"Pearl" was a 2007 Driftwood Pearl Prius.
"Pearl S" is coming and is a Seaglass Pearl Tech. package Prius.
David Beale is offline
Old 08-21-2008, 07:33 PM   #10
Little Lou
Thanks for the info, and for clarifying the issue for me.
LRP114 is offline
2005, battery, cost, prius, volt
Prius battery life and replacement cost? morris Gen II Prius Care, Maintenance and Troubleshooting 69 04-23-2012 02:12 PM
Reconditioned Prius Battery: one quarter the cost Eric Nothman Prius, Hybrid, EV and Alt-Fuel News 7 10-05-2007 04:23 PM
Volt Will Cost Less Than $30,000 Volty Prius, Hybrid, EV and Alt-Fuel News 59 05-23-2007 10:31 AM
12 volt aux battery for prius priussoris Gen II Prius Modifications 0 04-07-2007 08:58 AM
12 volt Battery kkayser Gen II Prius Technical Discussion 4 03-15-2007 12:33 PM
