This is a discussion on I got rear ended today, do I need to replace the bumper? within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Hi everyone, I got rear ended in my 2007 Prius today. However, it was a minor/soft impact (my car and ...
Old 03-20-2007, 03:00 PM   #1
narutorenji
Hi everyone,
I got rear ended in my 2007 Prius today. However, it was a minor/soft impact (my car and the car behind me were stopped at a red light...and the car behind me got rear ended, causing the car behind me to bump me from behind).
There is no visible damage, a small scratch maybe...but no dents. My question, do I need to replace the bumper. I read somewhere on this forum that the bumper is made up of a styrofoam that absorbs impacts, that needs to be replaced even with minor impacts.
Any feedback or suggestions would be much appreciated. Thanks.
Naruto
narutorenji is offline
Old 03-20-2007, 03:45 PM   #2
Charles Suitt
Charles Suitt's Avatar
Howdy... the "bumper" to which you refer is actually a "bumper COVER" made of a foam-like material witha plastic surface painted to match your car. You can remove the "tow eye plug" {that little round plug on the driver's side of the front bumper cover} to take a look at the construction. The actual bumper is behind that piece which is more cosmetic than structural. There would be no need to replace it unless it retained permanent scars or dents... even then it would be a "looks" element. If the scratches are slight, you could rub them out like any section of the body.
Never pleasant to be 'bumped' but it sounds as if little damage resulted.
Charles Suitt
Dallas Texas
2007 Touring Edition
(Former Prius: 2004)
Charles Suitt is offline
Old 03-20-2007, 03:59 PM   #3
narutorenji
<div class='quotetop'>QUOTE(Charles Suitt @ Mar 20 2007, 04:45 PM) [snapback]409176[/snapback]</div>
Charles, thanks for the reply...that's good info! Yeah, I was a little rattled coming into work today.
Thanks again for your feedback. Much appreciated!
Old 03-20-2007, 04:28 PM   #4
NoMoShocks
Electrical Engineer
NoMoShocks's Avatar
<div class='quotetop'>QUOTE(narutorenji @ Mar 20 2007, 02:59 PM) [snapback]409182[/snapback]</div>
The heavy styrofoam behind the painted platic is actually an energy absorber that is a safety feature, not just cosmetic, but I doubt it has lost any sognificant part of its effectiveness if there is no visible damage on the outside. It might be advisable to have it inspected. If the absorber is cracked, it could provide less protection in a more severe crash.
NoMoShocks is offline
Old 03-20-2007, 06:05 PM   #5
narutorenji
<div class='quotetop'>QUOTE(NoMoShocks @ Mar 20 2007, 05:28 PM) [snapback]409203[/snapback]</div>
Thanks NoMoShocks for your feedback. This is all good stuff to know. Anyone have an idea in regards to the cost of repairing a small scratch on the rear bumper cover?
Old 03-21-2007, 12:59 AM   #6
Orf
Orf's Avatar
Package: I-Tech
I backed into a rough stone wall (mind in neutral istead of reverse) and dented, split and scratched the bumper.
Took it to a car repair shop that specialises in plastic repairs.
They removed the bumper and repaired the split and the dents (2) and repainted the bumper. It looks brand new.
The repairer said that there were no signs of damage to the parts behind the plastic.
Therefore, narutorenji, as you do not have any visible signs of damage I would say that you are lucky and the only thing required would be to try and polish out the scratch marks or touch up with paint.
Australian 09 Gen 3 I-Tech Prius with side strips and rear bumper protector.
Orf is offline
Old 03-21-2007, 10:20 AM   #7
c4
In my case, when someone hit me from behind last year, it cost the insurance company over $3000 at the Toyota repair shop to have a new bumper cover, new absorber, new bumper mounts as well as work on the quarter-panels (panel damage was all but invisible- a bit of bulging around the wheel wells if you looked for it, and the gaps around the doors became uneven, but the whole set of panels did move, which is testament to how hard the guy hit me, even though the bumper cover only showed a scratch and a tiny crack).. Definitely call your insurance company and have it checked out- the other guy is at fault and his insurance will pay for any damage.
c4 is offline
Old 03-21-2007, 11:25 AM   #8
JayGoldstein
A month ago, I got hit by a pickup truck while I was stopped at a red light. Luckily, the damage was confined to the corner of the bumper, as can be seen below:
Repairs involved replacing (and repainting) the bumper cover, and some very minor body work on the rear quarter panel.
JayGoldstein is offline
Old 03-22-2007, 03:13 AM   #9
moolman
I got hit on the rear corner bumper, a car behind me tried to make a right and was to close and clipped me. It was pure cosmetic damage, 3 scratches enough to see the black color underneath the bumper. The body shop told me they had to just remove, sand the part and repaint the whole rear bumper. Total cost was $810, this includes the price of the clear bumper aplique. I took the cash from the insurance company and covered the scratch with the CA HOV stickers.
Alex
moolman is offline
Old 03-29-2007, 09:54 PM   #10
s.e.tx_parrothead
s.e.tx_parrothead's Avatar
On 3/3, a Ford Escape got up close and personal with Maggie and pushed her into a Chevy Pickup. The damage was confined mainly to the bumpers, however there was damage to the hatch lock assembly. They had the car in the shop for 18 days and the bill was just under $4200 not including the rental car. I have a post floating here somewhere with pics of the "owie".
s.e.tx_parrothead is offline
Internal Bumper Damage? Just got rear-ended exhuman Gen II Prius Main Forum 9 02-19-2010 12:48 PM
rear - ended JustDrooling4Now Gen II Prius Main Forum 6 09-05-2007 12:37 AM
My wife got rear ended in the Prius today... TJandGENESIS Fred's House of Pancakes 15 08-01-2007 08:05 PM
Need to replace black trim around rear bumper woemcats Gen II Prius Main Forum 3 02-28-2007 12:40 PM
Rear bumper damage. How much to replace?? leeki4321 Gen II Prius Main Forum 4 04-23-2006 10:38 PM
