This is a discussion on Traffic Jam, Battery Goes South within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I agree, there is no need to intervene, let the car handle itself and you'll be fine. I also find ...
Old 04-24-2007, 08:16 AM   #11
daronspicher
daronspicher's Avatar
I also find the Prius (2006) to do poorly in the traffic jam situation. I've only been in one really bad jam for a little over an hour. Probably 20 minutes into it, the battery was bottomed out, so now the ICE is flailing around wildly with every 'creep ahead' for the next 40 minutes.
In this situation where you might think it would do great on mpg, it does it's worst.
I'm a little surprised it doesn't decided to regen the battery at some point and run the engine at some efficient rpm level for 4 or 5 minutes to bring the battery up to a usable level so the ice can kick on and off a lot less for the next little while.
Then, when you break out of the traffic jam, your mpg is in the toilet as the battery eventually recovers.
They have some basic parameters around protecting the battery, but I don't think they did a lot of tinkering to make it do anything cool in this situation.
My Lifetime MPG is: Lifetime Stats
Down with VFTW, KeepTheBestIdol.com instead...
daronspicher is offline
Old 04-24-2007, 10:00 AM   #12
nyprius2007
same thing happened to me last night infact while waiting to cross the tz bridge..
battery went down to two bars and stayed there. Got the worst milage ever after that for a good 5 min. Nothing to worry about .. the computer will take care of it
nyprius2007 is offline
Old 04-24-2007, 11:22 AM   #13
richard schumacher
Destination: Eschaton
Further point: the main battery and associated electronics are cooled using *cabin* air, not outside air. That's the vent at the right end of the rear seat. You should use the A/C instead of opening a window, to avoid the possibility of the battery system getting too warm. If it does get too warm it will throttle itself and cause the car to run less efficiently. (Keeping the windows up also reduces infiltration of dust into the battery compartment.)
richard schumacher is offline
Old 04-24-2007, 01:43 PM   #14
Walker1
Walker1's Avatar
<div class='quotetop'>QUOTE(PaneInTheGlass @ Apr 23 2007, 09:05 PM) [snapback]428730[/snapback]</div>
Hi folks, I'm brand new to this forum as is my new Prius, only three days and 300 miles old. I love this new vehicle and the fact that I'm already averaging 45 mpg out of the box.
Quick question: I was in a huge traffic jam on the way home from work this afternoon, it's 85 degrees, and traffic is inching along for more than five miles.
I begin monitoring the battery out of curiosity to see what will happen as I creep along for 45 minutes. The radio is on, the a/c is on (fan cut back to a notch above low speed). The battery level begins to drop from around 75% and continues to drop further around every 10 minures. Seeing this, I cut off all ancillary power, meaning, the radio gets turned off, the a/c is turned off, and the windows opened. Good thing there was no humidity.
Finally, traffic gets moving, but my battery has dropped to 25% (2 notches from the bottom). Is this a normal state for the Prius in traffic jams that are barely moving, or would I have been dead in the water within another 45 minutes?
Your responses are much appreciated. Other than this question, the vehicle has been perfect in all respects, I have package #5.
Thanks, Harv
Yes, mine will do the same thing when heavy electrical demands are made on the battery. I shut off the A/C & headlights the other morning. The battery is supposed to go up & down depending on the load.
Walker1 is offline
Old 04-24-2007, 04:15 PM   #15
jamarimutt
It's actually quite bothersome when you're in a traffic jam, the battery charge drops very low and the ICE starts cycling on/off each time you move an inch forward and stop. To avoid this, step on the brake and press the gas pedal half way; the ICE will turn on, keep doing this until you get a couple of blue bars, take your foot off the pedal and the ICE will now stay off for a longer period of time.
A few folks have actually drag raced their Prius. They do the above, flooring the gas until the battery charges almost completely to obtain the best time.
jamarimutt is online now
Old 04-24-2007, 04:59 PM   #16
neilw
<div class='quotetop'>QUOTE(jamarimutt @ Apr 24 2007, 04:15 PM) [snapback]429232[/snapback]</div>
It's actually quite bothersome when you're in a traffic jam, the battery charge drops very low and the ICE starts cycling on/off each time you move an inch forward and stop.[/b]
I'm glad someone finally said this. When I first had the traffic jam experience, I was not so much concerned about the low battery, but driven nuts by the ICE cycling on and off. I mean, it was really monstrously annoying.
To avoid this, step on the brake and press the gas pedal half way; the ICE will turn on, keep doing this until you get a couple of blue bars, take your foot off the pedal and the ICE will now stay off for a longer period of time.[/b]
Is this a documented feature? I'll have to try this...
neilw is offline
Old 04-25-2007, 04:22 PM   #17
auricchio
auricchio's Avatar
Package: #8
Be advised that the ICE/charge/battery behavior will also change depending on the temperature of the battery. You may never see the exact same behavior again.
auricchio is offline
Old 04-25-2007, 05:22 PM   #18
hobbit
hobbit's Avatar
Recall that you get down to "two pink bars" territory if the car's
sitting powered up in Park, too. That's the default state when *not*
actually driving, and apparently when just creeping along too [but
then the juice is actually being used for propulsion]. Still a bit
of a mystery why the sitting-in-park state doesn't seek the 60%
level instead, but that appears to just be how it works.
_H*
hobbit is offline
Is it possible to completely drain your main battery in stop/go traffic? Starbug Gen II Prius Main Forum 28 08-20-2007 11:58 AM
Almost battery death in traffic nncyang Gen II Prius Care, Maintenance and Troubleshooting 18 06-15-2007 11:22 AM
5 Minutes of Stealth (using HV Battery) with Prius in Traffic Congestion usbseawolf2000 Gen II Prius Main Forum 12 03-09-2007 12:22 PM
MFD Went South hdpigott Gen II Prius Care, Maintenance and Troubleshooting 1 12-14-2004 02:01 PM
Low Battery in slow traffic priusjunky Gen II Prius Main Forum 5 09-24-2004 10:43 PM
