| This is a discussion on My Prius needs a battery, Toyota denies warranty due to EV button within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Has anyone looked at the Magnuson-Moss Warranty Act or other laws in place for warranty protection with "unauthorized" modifications? http://www.ftc.gov/bcp/conline/pubs/.../warranty.shtm ... |
| | LinkBack (20) | Thread Tools |
| | #111 |
| Member Join Date: Dec 2006
Friends: 0 | Has anyone looked at the Magnuson-Moss Warranty Act or other laws in place for warranty protection with "unauthorized" modifications? http://www.ftc.gov/bcp/conline/pubs/.../warranty.shtm http://en.wikipedia.org/wiki/Magnuson-Moss_Warranty_Act It may not be exactly the same, but figure they could make the same claim for any after market part. There is still a burden of proof that your modification lead to the failure. Here is K&N's interpretation: http://www.knfilters.com/warrantyletter.htm It is ridiculous that Toyota made a stink out of it. The button doesn't modify anything, it just tells the computer to activate a software mode that already exists. |
| | #112 | |||
| Senior Member Join Date: May 2005
Friends: 0 | <div class='quotetop'>QUOTE(diamondlarry @ Aug 5 2007, 05:51 PM) [snapback]490979[/snapback]</div> Quote:
Oh, wait - look, there's a blank plate where the EV button should go. Hey, why doesn't Toyota stop using their current dash molds, and design a completely different mold for the US Prius; one that doesn't need a blanking plate? Get it? | |||
| | #113 | |||
| | #114 |
| Senior Member Join Date: Aug 2006
My Car: Model: Package: Thanks: 4
Friends: 0 | Over here in the UK where the EV button is fitted, it drops out of EV mode at about 30mph which is annoying as the main limits are 30mph In the US where the EV button is not fitted as standard, the drop out appears to be - is it 34mph Maybe that's why there may be warranty anomolies The battery may not be ok with the extra EV use |
| | #115 |
| | #116 | |
Friends: 14 | <div class='quotetop'>QUOTE(jk450 @ Sep 12 2007, 12:50 AM) [snapback]511146[/snapback]</div> Quote:
The US emissions implications of the NHW20 EV button was actually covered quite well by Kristian Damkier 19 October 2004 in the Yahoo Prius-2G group. Message # 20928 for the curious. Prius2go, while studying up for this matter I got the impression that the difference you mention may relate to a 'conservative' speedometer setup for EU regs. And no (as likely clear from context), this would not be the sort of ECU reprog I alluded to above. Golly, sometimes it seems that we have been doing all this for a really long time. Prius 10th birthday 10th December (covered elsewhere).
__________________ DAS Tochatihu, the Hopi hummingbird kachina | |
| | #117 | |
The US emissions implications of the NHW20 EV button was actually covered quite well by Kristian Damkier 19 October 2004 in the Yahoo Prius-2G group. Message # 20928 for the curious. Prius2go, while studying up for this matter I got the impression that the difference you mention may relate to a 'conservative' speedometer setup for EU regs. And no (as likely clear from context), this would not be the sort of ECU reprog I alluded to above. Golly, sometimes it seems that we have been doing all this for a really long time. Prius 10th birthday 10th December (covered elsewhere). | |
| | #118 | |
Friends: 0 | <div class='quotetop'>QUOTE(jk450 @ Sep 12 2007, 01:50 AM) [snapback]511146[/snapback]</div> Quote:
| | #119 | |
| | #120 |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
Friends: 0 | In my mind it seems pretty clear why Toyota does not want to warrant a Prius with an EV switch in the US. Here is my reasoning. 1. One of the main worries of US customers is that the batteries will wear out, necessitating an expensive replacement. 2. The more that you charge-discharge (cycle) the battery the quicker it will wear out. Toyota has done a lot of things to increase battery life in the Prius. Mainly they restricted the battery charge range to 40-80 percent, and the computer actually tries to keep it in the middle. 3. Using the EV switch can cause you to increase the level of charge-discharge when driving the prius. That WILL make the battery wear out a bit sooner. It won't make it fail right away, but the batteries life WILL be reduced. 4. By trying to deny warranty coverage on cars with EV switches, fewer people will install the switches. Thus, overall, Prius batteries will last longer. ie. longer "mean time between failure" (MTBF). 5. The fewer Prius batteries that fail, the better reputation the Prius car has. My 02. |
| battery, button, denies, due, prius, toyota, warranty |
| Toyota denies battery woes delay next Prius | kram | Prius and Hybrid News | 3 | 10-02-2007 04:45 PM |
| Toyota denies battery woes delay next Prius | Cacti | Prius and Hybrid News | 3 | 09-30-2007 11:15 AM |
| Extended Battery warranty by Toyota | lschuste | Prius and Hybrid News | 13 | 11-21-2005 11:06 AM |
| Toyota Will Void Warranty For EV Button ~ '04 & '05 | Brian | Gen II Prius Modifications | 15 | 11-05-2004 02:45 PM |
| Battery SOC, EV Button, and Warranty: point to ponder | jrawles | Gen II Prius Main Forum | 2 | 05-27-2004 10:00 PM |
