| This is a discussion on My Prius needs a battery, Toyota denies warranty due to EV button within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; In my mind it seems pretty clear why Toyota does not want to warrant a Prius with an EV switch ... |
| | LinkBack (20) | Thread Tools |
| | #121 |
| Senior Member Join Date: May 2007 Location: SF Bay Area, California
Friends: 0 | In my mind it seems pretty clear why Toyota does not want to warrant a Prius with an EV switch in the US. Here is my reasoning. 1. One of the main worries of US customers is that the batteries will wear out, necessitating an expensive replacement. 2. The more that you charge-discharge (cycle) the battery the quicker it will wear out. Toyota has done a lot of things to increase battery life in the Prius. Mainly they restricted the battery charge range to 40-80 percent, and the computer actually tries to keep it in the middle. 3. Using the EV switch can cause you to increase the level of charge-discharge when driving the prius. That WILL make the battery wear out a bit sooner. It won't make it fail right away, but the batteries life WILL be reduced. 4. By trying to deny warranty coverage on cars with EV switches, fewer people will install the switches. Thus, overall, Prius batteries will last longer. ie. longer "mean time between failure" (MTBF). 5. The fewer Prius batteries that fail, the better reputation the Prius car has. My 02. |
| | #122 |
| übergeek Join Date: Sep 2007 Location: Mesa, AZ
Friends: 9 | Toyota USA makes no secret of it's view of the EV button: Reference http://www.toyota.com/prius/faq.html " 25. Does Toyota support the modification of my Prius to be a plug-in Hybrid and run on electric mode only with a switch? Any such alterations, modifications or tampering with the vehicle voids the warranty and is likely to be counterproductive for air quality and Prius’ durability and safety." Still, for most it's not a matter of air quality or trying to get a higher mpg. There are times I don't want the ICE to kick on unnecessarily when moving the vehicle short distances. I plan on adding it to mine even though it's still under warranty. I'm putting a quick disconnect connector behind the EV button and popping it out before it goes in for any dealer service. If anyone wants to donate a JDM button for my mod, let me know.
__________________ 2005 Driftwood Pearl Package #6 Current mods: Curt (U-Haul) square receiver hitch :: Privacy tint front/rear :: Dual ScanGauge :: "Batteries Included" license plate frame :: Scosche AXIPTA Ipod interface :: JDM EV button :: Fog Light mod :: LED Turn signal mirrors :: Cyron interior lighting :: 3M CAF Upcoming mods: LED license plate and interior lighting :: HID Fog Lights :: PHEV |
| | #123 | |
| Senior Member Join Date: May 2005
Friends: 0 | <div class='quotetop'>QUOTE(Frank Hudon @ Sep 12 2007, 10:28 AM) [snapback]511249[/snapback]</div> Quote:
| | #124 | |
| Junior Member Join Date: Jun 2007 Location: EU/Austria/Graz
My Car: 2006 Prius Model: Package: C Thanks: 0
Friends: 0 | <div class='quotetop'>QUOTE(priusmaybe @ Jul 20 2007, 12:32 PM) [snapback]482137[/snapback]</div> Quote:
i always thought the ev button we have here in the EU is nice but may damage the battery. how often did you use it? and even more important: how intensive did you use it? meaning: did the system have to activate the ICE after a "long" electric ride or did you just use it to drive a few silent meters? thx and kind reg. wogue | |
| | #125 |
| Member Join Date: Sep 2005
Friends: 0 | WoW reading the first post I am left wondering... When I bought my 2005 Prius the dealer said a replacement battery was $500 when it goes bad...... |
| | #126 | |
Friends: 37 | <div class='quotetop'>QUOTE(Virodeath @ Sep 18 2007, 07:18 AM) [snapback]514213[/snapback]</div> Quote:
| | #127 |
Friends: 0 | Well that BS I didn't go with the extended warranty because the battery was so cheap to replace should it go bad (not the only reson ofcoarse) and was told that it would be good for 150k miles atleast...... Now I am pissed... Viro |
| | #128 | |
| Member Join Date: Jul 2005 Location: Philadelphia, PA
Friends: 0 | <div class='quotetop'>QUOTE(Virodeath @ Sep 18 2007, 08:44 AM) [snapback]514221[/snapback]</div> Quote:
So you made the right decision for the wrong reason. | |
| | #129 | |
| Opera singin' Prius nut! Join Date: Jan 2004 Location: San Diego, CA
Friends: 0 | <div class='quotetop'>QUOTE(HeyKB @ Sep 18 2007, 09:34 AM) [snapback]514329[/snapback]</div> Quote:
| | #130 | |
| Junior Member Join Date: Dec 2007 Location: Turtletown TN
My Car: 2003 Prius Model: Package: Base Thanks: 0
Pardon me for the question, but where were you able to find and purchase the factory EV mode button from? I would like to install one if I can get it, as I really want this to look factory for aesthetic reasons. If I have to, I know I can just drill a hole for a pushbutton in one of the blank cover plates, and run a wire to the ECU connector. But I know it won't look as good ;-) I just aquired this 2003 Prius on sunday, and it is out of warranty at 110K miles. I hate to have the engine start and warm up for short trips to the mailbox and back, and I know that the battery bank would get plenty of charge from the once or twice weekly Dr appt trips. Being disabled makes walking to the mailbox and back something that I just can't do. I have plans to convert this to a plug-in hybrid, so I will be doing a lot of reading. Would love to charge this car from the PV solar power system that runs my house. Thank you in advance Bob | |
| battery, button, denies, due, prius, toyota, warranty |
| Toyota denies battery woes delay next Prius | kram | Prius and Hybrid News | 3 | 10-02-2007 04:45 PM |
| Toyota denies battery woes delay next Prius | Cacti | Prius and Hybrid News | 3 | 09-30-2007 11:15 AM |
| Extended Battery warranty by Toyota | lschuste | Prius and Hybrid News | 13 | 11-21-2005 11:06 AM |
| Toyota Will Void Warranty For EV Button ~ '04 & '05 | Brian | Gen II Prius Modifications | 15 | 11-05-2004 02:45 PM |
| Battery SOC, EV Button, and Warranty: point to ponder | jrawles | Gen II Prius Main Forum | 2 | 05-27-2004 10:00 PM |
