| This is a discussion on My Prius needs a battery, Toyota denies warranty due to EV button within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; <div class='quotetop'>QUOTE(FiftyOneMPG @ Jul 28 2007, 02:21 AM) [snapback]486614[/snapback]</div> It's probably something simple.. Toyota did the test bed thing with ... |
| | LinkBack (20) | Thread Tools |
| | #81 | |
| Opera singin' Prius nut! Join Date: Jan 2004 Location: San Diego, CA
Friends: 0 | <div class='quotetop'>QUOTE(FiftyOneMPG @ Jul 28 2007, 02:21 AM) [snapback]486614[/snapback]</div> Quote:
__________________ Pat 2004 Salsa #7/AM "Gracie" | |
| | #82 | |
My Car: 2006 Prius Model: Package: #6 Thanks: 18
Friends: 12 | <div class='quotetop'>QUOTE(Frank Hudon @ Jul 28 2007, 12:25 AM) [snapback]486607[/snapback]</div> Quote:
| | #83 | |
Friends: 0 | <div class='quotetop'>QUOTE(darelldd @ Jul 28 2007, 01:19 PM) [snapback]486772[/snapback]</div> Quote:
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. | |
| | #84 |
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
Friends: 6 | This certainly does sound like a case of corporate bullying. If the EV switch mod won't allow EV at anything over 34 mph or at a SoC below 3-4 bars, it is actually safer for the battery than not having it. By feathering the pedal I can actually run EV at 2-3 bars or have been on EV as high as 40 mph when the SoC was high enough. It seems that Toyota forgot about the Magnuson-Moss(sp?)Act that says that a manufacturer must prove that a modification caused the reported problem. I'd also bet that there would be some lawyer somewhere that would take the case for free since it would be an easy win and a great way to increase his reputation. |
| | #85 | |
Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Jul 19 2007, 08:26 PM) [snapback]482026[/snapback]</div> Quote:
Thanks, Tom | |
| | #86 |
Friends: 0 | No such codes exist, even in the "operational history" parameters, that I can detect either in the service manual or in fairly extensive exploring with a Mastertech. It's bullying, plain and simple. . _H* |
| | #87 | |
Friends: 1 | <div class='quotetop'>QUOTE(diamondlarry @ Jul 29 2007, 07:12 AM) [snapback]487025[/snapback]</div> Quote:
I agree with those that say the only potential problem is 'voiding' the AT-PZEV rating. At BEST that would make the car 'illegal' if it had some special status BECAUSE it is AT_PZEV. Convincing people that they shouldn't install an EV switch because it might invalidate the warranty is a lot easier than figuring out whether any individual vehicle is no longer achieving AT_PZEV due to the use of an EV switch. Frankly, I find that a hard arguement to swallow anyway. If I skate in the morning, my route to work includes a 1 mile nearly dead flat 25 MPH stretch. If I'm gentle on the pedal the entire 1 mile is EV and THE CAR IS DOING IT, NOT ME! This does NOT work in the winter when you need heat. I say both 'reasons' are bogus and the problem is related to either the battery being less than stellar to start with or some damage done to the battery after the sudden ICE failure.
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. | |
| | #88 | |
| Senior Member Join Date: Oct 2005 Location: West Central Florida
Friends: 0 | <div class='quotetop'>QUOTE(diamondlarry @ Jul 29 2007, 07:12 AM) [snapback]487025[/snapback]</div> Quote:
Find a lawyer who is willing to invest easily 6 and maybe 7 figures on a case like this to sue a foreign corporation with virtually unlimited legal resources. Rick #4 2006 | |
| | #89 | |
| Senior Member Join Date: May 2007
Friends: 0 | <div class='quotetop'>QUOTE(viking31 @ Aug 2 2007, 03:03 PM) [snapback]489457[/snapback]</div> Quote:
You are absolutely correct. You might find a lawyer to take the case, but you can bet that it won't be on a contingency fee basis. In other words, you will be able to fight only as long as you are able to keep paying the legal bills. Besides, the law is not in your favor here to begin with. The Magnusson-Moss Act says that a manufacturer may not deny warranty coverage solely because a customer has used an aftermarket part. But, if Toyota determines that the EV button is in some way responsible for the battery problem, it absolutely CAN void the warranty. Sure, you can always argue with the dealer and with Toyota, but you'll probably have to take it to court to get satisfaction.
__________________ 2006 Toyota Prius Package 4 | |
| | #90 | |
Friends: 0 | <div class='quotetop'>QUOTE(hobbit @ Aug 1 2007, 08:05 PM) [snapback]489060[/snapback]</div> Quote:
That's good to know, especially coming from someone who knows more about this car than all but a few engineers in Japan! Thanks, Tom | |
| battery, button, denies, due, prius, toyota, warranty |
| Toyota denies battery woes delay next Prius | kram | Prius and Hybrid News | 3 | 10-02-2007 04:45 PM |
| Toyota denies battery woes delay next Prius | Cacti | Prius and Hybrid News | 3 | 09-30-2007 11:15 AM |
| Extended Battery warranty by Toyota | lschuste | Prius and Hybrid News | 13 | 11-21-2005 11:06 AM |
| Toyota Will Void Warranty For EV Button ~ '04 & '05 | Brian | Gen II Prius Modifications | 15 | 11-05-2004 02:45 PM |
| Battery SOC, EV Button, and Warranty: point to ponder | jrawles | Gen II Prius Main Forum | 2 | 05-27-2004 10:00 PM |
who would've guessed? well now we know... and if we do have trouble guess what's coming out of the dashboard?
