| This is a discussion on Hybridfest 2007 videos within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Here is my last video. Tony Schaefer, Top Five Tips For Better Mileage, From Hybrids to Hummers http://video.google.com/videoplay?docid=-1...81104&hl=en... |
| | #11 |
Friends: 22 | Here is my last video. Tony Schaefer, Top Five Tips For Better Mileage, From Hybrids to Hummers http://video.google.com/videoplay?docid=-1...81104&hl=en |
| | #12 | |
| Member Join Date: Mar 2007 Location: Tampa Bay Florida
My Car: 2007 Prius Model: Package: #1 Thanks: 0
Friends: 0 | <div class='quotetop'>QUOTE(TheForce @ Jul 27 2007, 08:04 PM) [snapback]486454[/snapback]</div> Quote:
Thank you so much for posting that lecture. I learned quite a bit about hypermiling, especially about going over sidewall max tire pressure. Does anyone run 50 lbs psi?? Wayne "sugguests" that is the optimum tire pressure. Again, thanks for posting !!!!!!!!!!! Brad Tampa Bay Florida | |
| | #13 | |
| Whaddaya mean "senior" member? Join Date: May 2007 Location: Gurnee, IL
My Car: 2005 Prius Model: Package: #2 Thanks: 2
Friends: 8 | <div class='quotetop'>QUOTE(brad34695 @ Jul 28 2007, 06:45 PM) [snapback]486832[/snapback]</div> Quote:
| | #14 |
| EPA MPG #'s killer Join Date: May 2007 Location: Elkhart, IN
Friends: 6 | I've had 65 psi in the Integrity's since the day I drove it off the lot 4K+ miles ago. I drove accross the street to a gas station, pumped up the tires, got something to eat, and headed home and have had no issues, uneven wear or otherwise since other than a 73.7 mpg average. |
| | #15 | |
My Car: 2001 Prius Model: Package: N/A Thanks: 4
Friends: 2 | <div class='quotetop'>QUOTE(diamondlarry @ Jul 29 2007, 11:49 AM) [snapback]487080[/snapback]</div> Quote:
| | #16 | |
Friends: 6 | <div class='quotetop'>QUOTE(FL_Prius_Driver @ Jul 29 2007, 06:02 PM) [snapback]487195[/snapback]</div> Quote:
| | #17 |
Friends: 2 | There are two aspect of a pressure that high. One is that it puts a larger stess on the tire than ideal. Do not know if this a real issue or not. Given the surge pressures when a tire hits a pothole, it cannot be an acute problem. Do not know if there are chronic problems with uneven wear. The other issue is road traction. Radial Tires are designed with a certain amount of contact area. Again I do not know how much this is changed going from a recommendation of 35 psi to 65 psi, but it seems to be awful high. If the MPG keeps going up as you inflate the tire, when would you stop inflating? I guess that was my real question. I am not pro or con in this discussion, I just wanted to know why set your limit at 65 psi. |
| | #18 |
| Senior Member Join Date: Apr 2007 Location: Wakefield, MA.
My Car: 2009 Prius Model: Package: #2 Thanks: 5
Friends: 6 | If you watch the video of Wayne Gerde's talk at Hybridfest '07, he talks about how there is a point where the mpg gain levels out as you inflate the tire increasingly higher, so to a point there is more advantage to higher tire pressures, but the percentage of mpg gain does not stay the same. Watch the video of his talk. It has lots of excellent information. |
| | #19 | |
Friends: 6 | <div class='quotetop'>QUOTE(Neicy @ Jul 30 2007, 06:45 PM) [snapback]487655[/snapback]</div> Quote:
| Event 2007 Hybridfest announced | TonyPSchaefer | Local Clubs, Events, and Road Trips | 24 | 12-31-2007 10:42 AM |
| Hybridfest 2007 Photos | efusco | Gen II Prius Main Forum | 35 | 08-06-2007 01:48 AM |
| Who's going to the Hybridfest 2007 and where | priussoris | Gen II Prius Main Forum | 8 | 07-24-2007 02:37 PM |
| Hybridfest 2007 - Updates & Happenings | Neicy | Gen II Prius Main Forum | 4 | 07-21-2007 09:40 PM |
| Hybridfest 2007 Registration is Now Open | honoreitiscom | Gen II Prius Main Forum | 39 | 07-20-2007 10:33 AM |
