Prius towing capacity?
| | #31 |
| Junior Member Join Date: Sep 2011 Location: Massachusetts
My Car: 2005 Prius Model: N/A Package: No Package Thanks: 0
Friends: 0 | bat4255, Prius doesn't offer a hitch. Someone else makes that one and calls it a Toyota Prius hitch. I'm looking into a tiny camping trailer I want to tow. From the replies above it sounds like I need to know the hitch weight and the total weight before I decide. I'm looking at 2 options- one has a hitch weight of 24 lbs, the other weighs 800lbs, so I'll have to find out more, but this sounds possible. Are electric brakes on the trailer a major plus? |
| | #32 | |
| | #33 | |
| Senior Member Join Date: Dec 2010 Location: Waianae, HI (Oahu)
My Car: 2011 Prius Model: V Package: Adv. Technology Thanks: 166
Friends: 4 | Quote:
| | #34 |
| Green Handyman Join Date: Jun 2004 Location: Park View, Los Angeles, CA. U.S.A
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 36
Friends: 6 | WAM2005... i don't think towing the 2nd one will be troublesome. i tow a 5x8 steal mesh trailer that "breaks" in the center to allow the bed to ramp down. it's probably a little heavier than that 2nd one. if you head over to the yahoo forums (if i recall right, it's all updates by my email for the last couple years)... there is an outrageous (imo) conversation going on about some really heavy duty towing compared to what anyone over here on priuschat has ever towed. 2000lbs+ category. i see a lot of people with the towing ball of the hitch at exhaust pipe level (for lack of better reference)... i find this kinda odd as most trailers will be leaning towards the car. this can make driving scary. if your trailer weight is perfectly centered and level, it tows amazingly. my hitch ball is about 6 inches higher than exhaust pipe level. maybe i'll snap a pic if anyone isn't sure about hitches. i eventually want a fully adjustable one. a good 12 inches tall or so. my biggest problem is noise, bounce while the trailer is empty, and a slight wiggle since my hitch sucks (imo) so the actual ball/hitch piece wiggles around inside the hitch. i want to slide feeler gauges in to make it stop. tape method doesn't hold up because there really isn't enough room... it's crappy but not that crappy. (a lot of contractors use tape)
__________________ Silver #9 '04 - over 168,000 Miles (as of 1/23/2013) Decals, BT Tech Rear Brace, coastaletech 2" receiver hitch (light connectors, the works), 215/50/17 tires, Civic Battery (moded) (PSD fluid @ 146,000) _How to Change your Key fob Battery_ -new video- Last edited by V8Cobrakid; 09-26-2011 at 02:52 PM. |
| capacity, prius, towing |
| Towing my prius behind my RV | slimwille | Gen II Prius Modifications | 37 | 10-03-2011 11:18 PM |
| Towing With Prius? | Hytec | Gen II Prius Main Forum | 46 | 04-25-2011 09:58 AM |
| Towing with a Prius | FJRCRAZED | Gen II Prius Main Forum | 21 | 10-30-2006 04:37 AM |
| Towing the Prius behind an RV | compwolf | Gen II Prius Technical Discussion | 10 | 06-28-2006 03:15 AM |
| Towing the Prius | Eugene J Young | Gen II Prius Main Forum | 7 | 08-16-2005 10:44 AM |
