| This is a discussion on Michelin's New Primacy MXV4 Tire - General Impressions within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I put Goodyear Comfort Tred's on both Prius that I have owned. I did not notice any hit on the ... |
| | #21 |
| Senior Member Join Date: Jul 2004 Location: El Paso, TX
Friends: 0 | |
| | #22 |
| Senior Member Join Date: Feb 2005 Location: San Diego, CA
Friends: 1 | I am ShOcKeD that none of you has even looked at the Conti Comfort Treads. Cost less,cget better mileage, no problem with traction, and I "think" they are quieter too. YMMV |
| | #23 |
| Junior Member Join Date: Feb 2008
Friends: 0 | Just an FYI. I was having problems with my Prius Touring 2008 pulling to the left just a smidge, so I took it to my alignment guy in Houston, who's been doing this for 30 years. He had to modify the left rear support to be able to bring the alignment within spec. Now, my car drives straight and true. Ehn you get your car aligned, to be proper, you must have weight in the car equal to how the car is weighted in most of its driving. For me, that's just me in the driver's seat; I'm 6'3", 220. When someone aligns my car without me in it, and then I sit in it, the wheels are no longer aligned. Try it. Something's wrong with Priuses that we're not being told about. You shouldn't have to jack with modifying the car to get it to run true. |
| | #24 |
| Member Join Date: Jul 2006 Location: Rural area called Powdersville, 10 miles out of Greenville, SC
My Car: 2006 Prius Model: Package: #9 Thanks: 0
Friends: 0 | Thanks, I have hope but I am still off about 5 mph off. I now have 1000 miles on the Primacy tires. The weather here has been mild for SC in Feb. |
| | #25 |
| A 2 Prius household Join Date: Nov 2006 Location: Calabasas, CA
Friends: 0 | Hi all. Based on the original post, I made the switch to Michelin Primacy MXV4s in 195/60. The tires are so much better than the Integrities. Quieter, smoother, and much better handling. My MPG does seem to be taking a small hit. I am half-way through my first tank and I am averaging about 46 MPG, down from 47-48. I also added mud guards at the beginning of this tank of gas, so they may be combining with the wider tires to drop the MPG. I will take the hit for this kind of improvement in the ride. Perhaps thing will improve as the tires break in. Thanks for the insightful review. montenido
__________________ 2005 Tideland Pearl #6 (mine), ipod adapter, stiffening plate, EV mod, mud-guards, 195/60 Michelin Primacy MXV4 2008 Spectra Blue #5 (hers) stock so far... |
| | #26 |
Friends: 0 | I now have 2500 miles in the Michelin Primacy tires. At first I dectected aboujt 3 to 4 miles drop in mileage even with 40 - 38 lbs pressure. However, the local temp is warmer now and and my mileage has returned to normal which is around 49 mph. I am happy with the Michelins. |
| | #27 |
| Junior Member Join Date: Nov 2007 Location: Carmel CA
Friends: 0 | I am glad to hear about the Michelin Primacy MXV4 tires doing well. I have been in the tire business for 40 plus years and I am trying to pick the next tire for my 2008 with 1300 miles on it. The Goodyears seem to be doing just fine, quite, smooth, handle-OK, can't really complain. Looks like I will get around 40 to 50 thousand on them. I have always replaced my OE tires with a Michlein in the past and will probably pick this tire, the Primacy MXV4. I will stick with the P185/65R15 stock size, see no reason to switch to a bigger size. On the alignment side of things there is a shim by Specialty Co. to correct camber and toe on the rear of 01-08 Prius. If anyone asks, and the alignment person can't find it, its a brand new fitment. He can get the fitment online at Specialty Products Corporate Home Page. The first thing I do when I get a new car is pass it over the alignment rack and check it out, mine was out a very small amount. The rear was perfect, camber and toe, the front was out a small amount of camber. Can't wait to hear what your tire mileage is as the Michelin Primacy MXV4 is a 60,000 mile tire, but I bet you can do better as the Prius is not that heavy. |
| | #28 |
| SilverPineMica, the green one Join Date: Dec 2007 Location: Kalispell, Montana
Friends: 2 | Here in Montana we have a similar seasonal rotation, only we refer to them as: Amost winter, winter, still winter, and Construction. |
| | #29 |
| Shuttlecraft Commander Join Date: Jun 2007 Location: Out there, somewhere
My Car: 2007 Prius Model: Package: #5 Thanks: 2
Friends: 13 | |
| | #30 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 834
Friends: 11 | Quote:
Good find. I had to add custom made shims (made by Galaxee's DH) to correct my rear toe problem. It is good to see that the aftermarket companies are starting to acknowledge this issue. | |
| general, impressions, michelin's, mxv4, primacy, tire |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-main-forum/39748-michelin-s-new-primacy-mxv4-tire-general-impressions.html | ||||
| michelin primacy | VIRGILIO Ricerca | Web | This thread | Refback | 04-22-2009 11:23 AM | |
| Quietest LRR tire for TCH - Page 2 - GreenHybrid - Hybrid Cars | This thread | Refback | 10-23-2008 11:41 AM | |
| Michelin Primacy MXV4 - Zuula Search | This thread | Refback | 10-03-2008 12:33 AM | |
| Michelin Harmony or Michelin Energy MXV4 | BH1973 | Gen II Prius Care, Maintenance and Troubleshooting | 22 | 02-08-2010 11:37 PM |
| Michelin Energy MXV4 Plus P185/65R15 discontinued | HappyPig | Gen II Prius Main Forum | 7 | 05-19-2007 10:01 AM |
| Michelin MXV4+ questions, please help | coolfire74 | Gen II Prius Main Forum | 32 | 05-19-2007 01:06 AM |
| First Impressions Michelin X-Ice | c4 | Gen II Prius Main Forum | 19 | 12-07-2006 08:33 AM |
| Michelin Energy MXV4+ Green Tires | tomdeimos | Gen II Prius Modifications | 22 | 07-24-2005 02:01 PM |
