This is a discussion on About to pull the trigger on a Prius. within the Gen II Prius Main Forum forums, part of the Gen II (2004-2009) Toyota Prius Forums category; ~smirk~ I'd be highly concerned going from 50 MPG to 47MPG! You could probably drop 20% (10MPG) and still double ...
Old 11-18-2007, 07:57 PM   #11
skguh
skguh's Avatar
~smirk~
I'd be highly concerned going from 50 MPG to 47MPG! You could probably drop 20% (10MPG) and still double what you HAVE been getting!
I recommend that you try to drive it the way you have been all along--just to realize the immediate benefits. Then, after about two tanks of gasoline, try a couple of fuel saving tips to see what a difference they make. Also, if you don't want a block heater (they're only good if you can plug 'em in), consider a low wattage drop light in the garage under the car. I used to do that when I live in Caribou, Maine, to ward off penguins....
skguh is offline
Pulled the trigger today... UPDTE- CANCELLED ORDER brentmeister Gen II Prius Main Forum 27 10-14-2007 12:40 AM
Finally pulled the trigger! ttague Gen II Prius Main Forum 3 05-28-2007 09:19 PM
Thinking about pulling the trigger in Big D Hostage46 Gen II Prius Main Forum 17 04-16-2007 02:57 PM
Using Prius to power/pull lawnmowers? littleprius Gen II Prius Main Forum 9 06-18-2006 02:51 PM
Pulled the trigger on 06... jeffn Gen II Prius Main Forum 10 10-09-2005 09:03 PM
